tallen4392
tires
tallen4392
does anyone use ag tires on there machine all year around to cut the grass and push the snow without damaging the lawn ??  i have them on my charger for snow removal work good for that
ri702bill
Nope!! AG's are OK for the summer - tried once to plow with them - they were wide and just rode up on top of the snow - no grip.
Winter I use turf tires with 2 link chains - and weight - a lot of weight.
kpinnc
Yes you can use them for mowing. "Normal" use is no problem. Where you have issues is when the ground is wet and soft. When you spin a tire, you instantly have a hole to fix.
You just have to be careful. Several of mine run ags year round. But mine never see snow duty. Never used a set of chains...
  • Like 4
ri702bill
Chains do not "fit" ag tires well. The cross links always seem to fall into the wide grooves - no improvement in traction.
Tonytoro416
Not to mention they tear up bar tires really bad
Tonytoro416
The Carlisle versa turf tires are the best I have experienced for plowing.  They are a radial tire so they have some squat and flex to help grab and bite
  • Excellent 2
Ed Kennell
                                       :text-yeahthat:
    2 link veebar chains on turf tires and weight
  • Excellent 3
ri702bill
pfrederi
If you have frozen ground or packed snow/ice underneath then narrow tires with 2 link chains and weights are a great solution.
Edited by pfrederi
  • Like 4
Handy Don
Speaking of tires and chains....
How many links are in the cross-links for well-fitting 2- and 4-link chains on the different tire sizes (not counting the hooks that attach the cross chains to the circumferential chain)?
It seems like it's one or two links more than the width in inches.
Is it: 8 for 6x12’s, 10 or 11 for 8.5x23, and 12 or 13 for 10.5x23?
ineedanother
I think it depends on your lawn. Most tires will damage sod if they spin and Ags don't lose traction as quickly so in some instances are a good choice for mowing. I agree with others that chains don't fit well on them so ground-engaging might be served better with chains and turf tires.
tallen4392
Thanks for the tips i have a charger 12 for snow plowing with ag tires and lots of weight work great never a issue and my driveway is on a good hill   i picked this machine up for my sons new house wanted a tire for year round to mow and move snow ..
ri702bill
Don - I replaced all the cross links on the rear tires for the C81 - they were 4 link and I wanted more crosslinks. The old ones were vee bar, great grip on ice, but left gouges in the top surface of the driveway. Bought a 75 foot roll of 1/0 (as I recall) twisted link chain on the 'Bay. Also bought 100 new crosslink connectors. Both were slightly different than what I already had.
The twisted links were slightly longer, maybe by an 1/8th of an inch each. The connectors at the end were also longer, by about 3/8ths - actlally ended up with one less crosslink.
You can see the differences from both sets in my photo above.
Bill
Handy Don
Bill
Hmmm.
At the moment we have two sets for 8.5” tires--both 2-link. One in good shape and one that has a lot of wear with a few broken links in the cross-chains (a couple are using heavy zip ties!).
My son is running 10.5” turfs, the camp tractor has 8.5” Ags (we don’t expect to run chains on this), and the 854 has 6” original “all purpose” so nothing matches up!
I’m thinking of taking the worn 8.5" set and re-working it down to run on the 6” tires if there are enough good links left. So I guess the tactic should be to measure across the tread of the tire once the circumferential chains are in place to determine the right number of links and go from there.
We are also on the lookout for a used set for the 10.5’s. I’m trying to avoid a significant new investment in something that won’t get a lot of use :)
pfrederi
8 minutes ago, Handy Don said:
Hmmm.
6.00 x 12 old tires are great in winter with chains.  One set has some really slick German zigzag chains  the other has Army surplus Jeep chains 6.00 x 16 shortened up.
ri702bill
Good idea... two things come to mind.
You will more than likely need to fiddle with the length of the side chains. May need to either lengthen or shorten.
Invest in a pair of meduim truck chain pliers. They are used to both open and close the crosslink connectors. Picked mine up at the local indoor flea market for $12. Patented in 1929 I recall - used but still quite useable. The guy had 2 pair, those and a larger 18 wheeler pair.... Same pair I got being sold as "vintage" on the 'Bay for $129....
Do wear gloves doing this - it is tough on the hands...
Edited by ri702bill
Handy Don
I'm counting on this!
Invest in a pair of meduim truck chain pliers. They are used to both open and close the crosslink connectors. Picked mine up at the local indoor flea market for $12. Pattented in 1929 I recall - used but still quite useable. The guy had 2 pair, those and a larger 18 wheeler pair.... Same pair I got being sold as "vintage" on the 'Bay for $129....
Yep, H.K. Porter Linkmaster from Everett, MA. Up to to 13/32” wire. Patent Pending. $20 at an estate sale a few weeks back. Awesome tool!
Am hoping to use the side chains unaltered, since the tire diameters are the same, but we’ll see!
ri702bill
I found in adding crosslinks to convert from 4 link to 2 link, the side chains rode closer to the tread and I had to add a link on the inner and outer...
ri702bill
Yup - mine are similar double acting (?) or is it compound? lever system on the handles like a bolt cutter. Worth every penny, even if you only use them once...
