Red Dart 4 #1 Posted February 17, 2023 On my mower deck 48" 5-1483 the center spindle shaft # 5875 along with lower needle bearing are ruined. Does anyone have parts #10, 3, 4 or the whole spindle as shown on attached drawing? 1 Share this post Link to post Share on other sites
Ed Kennell 39,177 #2 Posted February 17, 2023 to the I may have these spindles. I'll check some buckets tomorrow. 1 Share this post Link to post Share on other sites
Blasterdad 2,734 #3 Posted February 17, 2023 The bottom link has complete assembleys. https://wheelhorsepartsandmore.com/ https://www.wheelhorseforum.com/forum/169-a-z-tractor/ https://www.wheelhorseforum.com/forum/177-kb-horse-parts/ Share this post Link to post Share on other sites
Lane Ranger 11,028 #4 Posted February 17, 2023 4 hours ago, Red Dart said: On my mower deck 48" 5-1483 the center spindle shaft # 5875 along with lower needle bearing are ruined. Does anyone have parts #10, 3, 4 or the whole spindle as shown on attached drawing? I think those a like the 953/1054 58 inch mower deck spindles. Share this post Link to post Share on other sites
daveoman1966 3,762 #5 Posted February 17, 2023 These are the older 'Double D' spindle shafts taken from a Cast Iron spindle like 5-1483...as in your pic and schematic. The TOP ends...pulley end... are all good to go. All flats on TOP are crisp...not worn. The LOWER end of shaft 'A' is worn...but not terrible like yours. Pulley FLAT is 1-1/2" The LOWER end of shaft 'B' is better...but not perfect. Pulley FLAT is 7/8" Threaded ends are all good too. BOTH are 6-1/4" full length. $20 each... $30 for BOTH... add $8 ship for either or both. PAYPAL money as 'FRIENDS' 1 Share this post Link to post Share on other sites
daveoman1966 3,762 #6 Posted February 17, 2023 The lower bearing is #1508... I likely have one and will include it for only $5 more. 1 Share this post Link to post Share on other sites
peter lena 8,876 #7 Posted February 18, 2023 @Red Dart dare I ask what kind of lubrication n / grease are you putting in those bearings ? opportunity is the word , you are right there , hi heat / angular stress , makes those bearings fail / and get whiny noisy . lucas marine grease is available , look at the specs on it , use it on all related bearings , only a suggestion , pete 1 1 Share this post Link to post Share on other sites
peter lena 8,876 #8 Posted February 18, 2023 @oldlineman having done this lubrication detailing / building on all my , pto belt driven attachments , the ease of quiet operation is very different from the norm. you can easily note the gain of usage , no rusty , dry , attempted power hand off , of belt , regularly slowly engage my pto lever , solid / smooth , mule drive is quiet / smooth , deck spins up with out , screaming clutch , and no hi pitched whining noise . look at every issue with a plan to make it go away , the difference of the neglect on a recently acquired horse , is staggering . the exact opposite to my 3 horses . probably the last one I will help out , pete 1 1 Share this post Link to post Share on other sites
Red Dart 4 #9 Posted February 19, 2023 Pete, thankyou for the advice for type of grease lubricant 1 1 Share this post Link to post Share on other sites
