pfrederi
WHCC 2023 Show Buy Sell Trade
wheelhorseman
9 minutes ago, squonk said:
WH Front weights with bolts. $250
8" Horse Head hubcaps. Small dent in one $30
Nice drop spreader $30
IMG_20210322_150430697.jpg.42cc5ea101dc3625828e667a6e1d5cac.jpg.c3c054ad469d57c0e34578bc630e82ef.jpg
Squonk I will take the hub caps
squonk
Ok Lowell
stevebo
Nicest original condition tub cart 🛒 have ever seen with only minor touch up done by po. I only used this a few times as it is very very clean. Will haul to big show. $400. Sorry it is only pic o have of it now.
whfan74
Slowly boxing things up for the show.
This is just a tiny teaser as I have so much more buried to dig out.
  • Excellent 6
stevebo
Scott,
are you gonna set up a vendor space?
whfan74
That is the plan.  Still working out details on my end.
cafoose
Bervac snow thrower WO46D off my 520-HC, rear tiller 7-1211, also a single stage snow thrower for parts details listed in post #52. Moved to Tennessee and no longer needed, make a reasonable offer or trade for ???? and it's yours. Must move soon, located in PA between Lancaster and York. I'm bringing it to the show.
rjg854
I'd like to trade these weights,
for a set from a D series, that has the notch for the air nozzle.
Sparky
 You’re in luck! I have two pair of that style sitting around here. I’ll do the trade :handgestures-thumbupright:
  Let me know which color you prefer.
 Gray primer or Linen Beige
  • Like 4
rjg854
The gray primer will be fine.  I'll see you at the Show.  :text-bravo:
Sparky
Sounds good! I usually arrive late Friday Morning (10:30am or so)
  I’ll message you my cell #
squonk
You know where we'll be. At the "Hospitality " tent! :banana-dreads:
  • Haha 2
elcamino/wheelhorse
You providing food and drinks this year? Should I invite everybody ?
  • Haha 1
squonk
I was told you're bringing Va. BBQ!
elcamino/wheelhorse
Don't think so , Carolina BBQ is better .
squonk
Then bring that. Just leave on Tuesday! :auto-car:
rjg854
A few items that have been sitting here that maybe some one can use..
16 and 12 hp engine tins $15 each set
Cylinder head 16&12 hp $25 each
Flywheels $15 each
Bearing plate $10
Oil pans big block $10 each
16 hp cam $20
SOLD
12 hp head, tins, and flywheel.
Dan got a n oil pan.
Edited by rjg854
Add
rmaynard
Pair of 6-12 AG Lug tires. Firestone. Nearly new. Barn find. Not made in China. $150.00.
Sale pending.
Edited by rmaynard
adsm08
On 4/7/2023 at 9:57 PM, CB520HC said:
so I've been trying to figure out where the show is located? i figured out its weekend after fathers day and i believe its in New York if I've been reading properly. but not sure where exactly it is looking to find out how far to see if i can make it happen. Any help is much appreciated.
On 4/7/2023 at 10:17 PM, Mike'sHorseBarn said:
The show is in arendtsville Pennsylvania. Here is a Google map link to the grounds.
South Mountain Fairgrounds
https://maps.app.goo.gl/QSi7qwmJGUYisrB27
Arendtsville is not far from Gettysburg.
adsm08
What does the tiller fit?
I'm thinking it does not work on my 855, otherwise I might be interested.
Pullstart
Any desire for a 37” deck?  It’s dark in the barn, but if there is interest I can bring it out in the daylight.  Spindles turn easy and quiet.
cafoose
Looks like it's not listed to fit but you can get another :wh: besides, 8HP may be a little too small to handle it
oliver2-44
Flywheels $15 each
Bearing plate $10
16 hp cam $20
@rjg854Would you consider shipping a set of engine tins, cylinder head and oil pan. They might all fit in one USPS flat rate box
adsm08
But it lists for the 875, which is the same unit with a hydro trans. Between that and the setup/install instructions I'm betting it's more because the manual transmission has no way to power the unit.
As for getting another WH, I'm trying to get rid of tractors. If I could get rid of all my other tractors except the 855 and find a short-frame hydro at a reasonable price I might think about it.
I know where there is a short frame just sitting, but looking at the way it sits I think it has no transaxle in it.
cafoose
With the show coming up, I'll bet you can find a hydro for that short frame. Maybe you can get rid of some :wh: at the show? I may be interested in a trade for the tiller depending what you have. Tillers are getting scarce so maybe you should get this while you can :eusa-think:
