peter lena 9,087 #51 Posted April 23, 2023 @Blackm84 enhance your engine grounding for related . rectifier cooling tin front mount. usually corroded , and related to funky amperage reading . battery ground bolt point , add a battery cable from that bolt to engine corner / frame area engine cooling intake side . makes amperage snap to attention , and secures related rectifier ground point , also loosen those 2 rectifier bolts , like dielectric grease , this ground also enhances the headlight grounding , check out multi point connections , often stress cracked , powdery , film will verify that . pete Share this post Link to post Share on other sites
Blackm84 97 #52 Posted June 8, 2023 Update: Got the tractor tore down almost completely but didn't take any pictures. Been busy with work, National guard and my basement flooding. I have my annual training next week but will update with lots of pictures when I get back. Going to be prepping everything for sand blasting. 1 1 Share this post Link to post Share on other sites
ebinmaine 70,718 #53 Posted June 8, 2023 5 hours ago, Blackm84 said: National guard for serving! 1 Share this post Link to post Share on other sites
Pullstart 64,524 #54 Posted June 8, 2023 Thank you for your service! Let me know if you still need any parts we talked about in February 1 Share this post Link to post Share on other sites
Blackm84 97 #55 Posted June 10, 2023 On 6/8/2023 at 8:49 AM, Pullstart said: Thank you for your service! Let me know if you still need any parts we talked about in February Yes I still do !! just trying to get some time to get over there. Share this post Link to post Share on other sites
Blackm84 97 #56 Posted June 27, 2023 Quick question is there an assembly manual or service manual with part breakdowns finding alot of stuff questionable going to start sandblasting and painting soon will update with lots of pics after 4th of July. Trying to figure out new phone. Share this post Link to post Share on other sites
ineedanother 1,394 #57 Posted June 27, 2023 19 hours ago, Blackm84 said: Quick question is there an assembly manual or service manual with part breakdowns finding alot of stuff questionable going to start sandblasting and painting soon will update with lots of pics after 4th of July. Trying to figure out new phone. Try this... Share this post Link to post Share on other sites
WHX?? 50,712 #58 Posted June 27, 2023 On 6/7/2023 at 9:33 PM, Blackm84 said: National guard On 6/8/2023 at 7:49 AM, Pullstart said: Thank you for your service! Ask the mods to get you a service emblem. 1 Share this post Link to post Share on other sites
Brockport Bill 1,824 #59 Posted June 28, 2023 On 2/19/2023 at 8:37 PM, c-series don said: @Blasterdad Not to contradict you,😂 but I’ve never ran my tiller on the outside groove. It simply wouldn’t line up with the mid mount pulleys. Yes the outside is for the generator. Here’s a few pictures, the first three are the tiller and the last is obviously the generator.🙂 here is my Rototiller owners manual photo showing inside pto groove slot - i run it on 312-8 1 Share this post Link to post Share on other sites
