Blackm84
C145 restoration
Blackm84
Well started restoration of a 1983 or 84 c145 started disassembling I have a few hours everyday my wife is working.  Forgive me if its kind of weird im posting from my phone until I can get a cable to connect to my pc.
  • Like 9
ebinmaine
Welcome!
Don't sweat the phone.... 99% of my own activity is from my phone.
Blackm84
So far its missing some bolts but really greasy.  Also I am missing some of the engine tin covers and the bolts to them.  Too bad its winter as I would have already had this degreased and power washed.  Big shoutout to Pullstart as he is helping me with some of my questions and missing panels.  I am going to replace the cracked fender pan with a metal one and try to find some of the missing parts.
Edited by Blackm84
  • Like 7
Tonytoro416
Everything I post is from my phone. Don’t worry about that as EB said.  Take your time and do it once. The weather we want is coming
  • Like 4
Blackm84
10 minutes ago, c-series don said:
Welcome to Red Square, keep the pictures coming! Hope it ends up looking like this…..
I hope so too!! mine will have the rear discharge deck.
  • Like 5
Pullstart
Glad to help :handgestures-thumbupright:  Also, if you’d like to tag someone, use the “at” sign and start typing.  @Blackm84
Brockport Bill
those are certainly some dirty tranny fins - I call it black glue !!!
Handy Don
2 hours ago, c-series don said:
Bell Bottoms and penny loafers and a pork pie hat. High fashion mowing there.
  • Haha 6
WHX??
Sames woes here.
:handgestures-fingerscrossed:
  • Like 4
953 nut
:WRS:
Toss it on a trailer and take it to the self service car wash, well worth the effort.               :twocents-02cents:
squonk
C-145 well worth the effort.
  • Excellent 2
ebinmaine
Like that color combo!
  • Like 4
Blackm84
@squonk wow that looks nice!!
Does anyone know if my hydro is supposed to have a fan on it?
Handy Don
ALL hydros need a fan--they get really warm when being worked.
Where depends on the model.
squonk
Your c-145 has the Eaton Hydro and there is supposed to be a plastic fan on that pulley off of that gooey finned thingy.
Blackm84
Yea tonight I am going to soak it down with some dawn and some other degreasers as soon as it warms up I am going to spray it off and get it cleaned.  Definitely will be a PITA
ebinmaine
2 hours ago, squonk said:
gooey finned thingy
There goes Mike using those big technical words on us backwoods people again.....
  • Haha 3
Handy Don
Bodes poorly that there is no sign of the fan that should be there AND that the hydro pump/motor cooling fins are totally coated with gunk. If that tractor was worked hard, it may already have excess wear in the hydro. Certainly, at least, the oil has been way stressed.
Blackm84
Well started working again gettin it tore down.  I quit because I smashed my hand and saw i needed snap ring pliers.  Found the brake pedal way loose on the band not really moving anything.  How do you remove the pedal?  Also hit a road block on removing the steering wheel how does that come off? Almost looks like a roll pin?
Blackm84
Got the hydro soaking in dawn will get some stronger degreaser tomorrow. Found one spot where the metals broke. Soaking the rest of the greasy spots to get an idea of just whats going on or leaking.
Handy Don
A setscrew in that collar secures the brake pedal on its support rod.
There is definitely a hardened roll pin holding on the steering wheel. Search for “remove steering wheel” on this forum and you’ll find lots of threads on this topic. It is one of the tougher challenges in restoring these old horses. Strong suggestions:
1) your favorite penetrant applied often over several days or even weeks (implies mucho patience!)
2) use a roll pin punch not a flat-end punch to prevent mushrooming the top of the roll pin (and making the removal vastly more difficult),
3) make sure the steering column is extremely well braced to something NOT on the tractor (I use a 2x4 attached to the wall of the garage) BEFORE attempting to punch out the pin,
4) accept that it may be impossible to remove the pin without damaging the steering wheel -- some members cut the shaft on an angle and then on re-assembly weld it back together with a coupling with the beveled ends realigning the two pieces
Edited by Handy Don
c-series don
I definitely agree with searching steering wheel removal here. I also think that I remember someone saying that they used a masonry/tile bit and drilled the roll pin out?
ebinmaine
@Achto trick?
oliver2-44
Yes I use a carbide tile/glass bit and drill them out. Works excellent. A regular bit won’t touch them.
  • Excellent 3
