quent pye
Any one got a part number for a hub for the tire
quent pye
I need a new hub for for my wheel the key way is stripped I also need a brake thing
Edited by quent pye
Photos
Ed Kennell
:text-welcomeconfetti:to the :rs:      We need a model number to answer your question as there are several different hubs.
3 hole
4 hole
5 hole
1" axle
1.125" axle
Pullstart
@WHX?? might could fix that hub.  He has a broach set to cut a new keyway.
Pullstart
Pictures from the other post tell me it’s a 3 speed in a mid 60’s square hood, so a 1” hub and a brake drum needed too?
Ed Kennell
Looks like it needs more than a new keyway.
quent pye
Ya I need a drum brake it has high and low with 3 forward gears and one reverse gear
quent pye
3 hole
4 hole
5 hole
1" axle
1.125" axle
Its a five bolt hub
Pullstart
Oh, ok.  Measure the axles and report back to us.  Is the axle ok, or will that need replacing?
Achto
:WRS:
quent pye
The axle is fine it's just the hub
Pullstart
ok.  Still need the diameter :handgestures-thumbupright:
Ed Kennell
Can you post the tractor model number?    It may be below the dash plate.
quent pye
Yep I will
quent pye
Yep just heading out now
Pullstart
Did you get stuck in a snow drift?  :lol:
WHX??
:WRS:
Yes most hubs can be saved if not wobbled out and fit fairly snug on the axle. Check the keyway and axle for damage. While your at it check the outer axle bearing and seal.
Edited by WHX??
oldlineman
Looks like you could use the brake material also Bob Maynard has them check our vender section.
quent pye
Edited by quent pye
Pictures
quent pye
I found the drum in my laneway
