"Manic-Mechanic" 1,194 #1 Posted February 15, 2023 Has anyone built a Cat 0 Quick Hitch and are they for sale? 2 Share this post Link to post Share on other sites
Pullstart 62,813 #2 Posted February 16, 2023 That’s a good idea, would the quick attach be a universal size? It seems the attachments for a cat 0 would generally be smaller.. 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,194 #3 Posted February 16, 2023 I talked to Ballard Fabrication, he said it would be reduced in size for Cat 0 and that he has been kicking the idea around. I seen this set up used, all the implements would need a piece that slides over the pins, other than that it should work for all the implements with the same spacing @ 22" I wonder though if the 3 pt would go low enough to get under the pins... 1 Share this post Link to post Share on other sites
