quent pye 16 #1 Posted February 14, 2023 I have a wheel horse tractor and I'm trying to figure out where the spring goes for the clutch 2 Share this post Link to post Share on other sites
Sparky-(Admin) 21,402 #2 Posted February 14, 2023 The spring goes on the arm in your first picture. The other end goes to a gusset on the top of the transmission axle housing, it has a small hole in it for the loop on the end of the spring. 7 1 Share this post Link to post Share on other sites
quent pye 16 #3 Posted February 14, 2023 Does it have to be a strong spring? 2 Share this post Link to post Share on other sites
953 nut 55,742 #4 Posted February 15, 2023 37 minutes ago, quent pye said: Does it have to be a strong spring? Yes, the spring is what applies tension to your drive belt. Here is a link to the correct spring, https://wheelhorsepartsandmore.com/product/1014-spring-for-wheel-horse/ 2 1 Share this post Link to post Share on other sites
Handy Don 12,438 #5 Posted February 15, 2023 (edited) 1 hour ago, 953 nut said: Yes, the spring is what applies tension to your drive belt. Here is a link to the correct spring, https://wheelhorsepartsandmore.com/product/1014-spring-for-wheel-horse/ I put a loop of wire very tightly clamped in a pair of vise grip pliers and then over the end of the spring to give myself a good hold when installing the spring. Learned this after the very strong spring shot off when my plain pliers lost their grip. Edited February 15, 2023 by Handy Don 2 1 Share this post Link to post Share on other sites
quent pye 16 #6 Posted February 15, 2023 Ok thanks so much 2 Share this post Link to post Share on other sites
Pullstart 63,081 #7 Posted February 15, 2023 @quent pye 1 Share this post Link to post Share on other sites
peter lena 8,719 #9 Posted February 15, 2023 @quent pye notice nothing mentioned about lubrication ? second picture , note end of lift arm bushing ? bone dry , no aerosol lubricant in / on the bronze bushings / both sides ? would also bet that any related linkage to that entire clutch set up is rusty / dry . consistently hiding in plane site , is rusty drag , dust , grinding / creaking , binding . especially like the , clutch pedal , jumping bind. also notice the tiny bearing in the idler pulley ? loose fitting trunnion on related linkage ? last photo ? this and more adds up to , a collection of disfunction . only my opinion , but none of those areas / opportunities , exist on my horses . currently bringing back another one , every movement point , actually moves , greasy , pete 1 Share this post Link to post Share on other sites
peter lena 8,719 #10 Posted February 15, 2023 @Sparky noting your response to the clutch spring issue , notice that ill fitting trunnion / linkage ? great spot for a screw on heim joint , bombproof and smooth , also rusty dust on slide spring side to linkage ? little bit of tweaking , make that free and smooth , like a wire wrap and silicone grease , also do that on plow lever connection wire , pete 1 Share this post Link to post Share on other sites
peter lena 8,719 #11 Posted February 16, 2023 @Horse Newbie suggestions made to replies above , found more than often than not , COLLECTIVE ISSUES TO A PROBLEM, not just on an obvious spot . linkages are loaded with collective drag , add them all up and you , have poor response or failure . recently doing over a horse , practically anything I look at is neglect , and poor function . thats why I stay after my 3 horses , everything works easily / reliably like it should . regular look arounds , keep me in touch with horse coditition . pete 1 Share this post Link to post Share on other sites
