Mark siebenaler 93 #2 Posted February 14, 2023 Could someone please verify this is the correct length obviously someone else put this in at some point. I usually make sure the oil is up to the o. In oil? 1 Share this post Link to post Share on other sites
Ed Kennell 38,624 #3 Posted February 14, 2023 What hydro ? Share this post Link to post Share on other sites
Mark siebenaler 93 #4 Posted February 14, 2023 It is on a c160 1 Share this post Link to post Share on other sites
ebinmaine 68,259 #5 Posted February 14, 2023 So a mid-70s Sundstrand transmission. I can get a pic with length in an hour or two if somebody doesn't do it sooner. You want to make sure this type of transmission is NOT overfilled per @daveoman1966 but I don't remember the technical reason. Share this post Link to post Share on other sites
Mark siebenaler 93 #7 Posted February 14, 2023 Ohch 1 Share this post Link to post Share on other sites
Mark siebenaler 93 #8 Posted February 15, 2023 4 hours ago, ebinmaine said: Do you think mine is very much incorrect I've had it for a very long time and it always worked good.but it also has always been in the back of my mind? 1 Share this post Link to post Share on other sites
Ed Kennell 38,624 #9 Posted February 15, 2023 Eric, is it possible Mark's Sundstrand has a riser pipe requiring the longer dip stick? I don't have any Sundstrands left...only Eatons in my barn. There are three different Sundstrand models. I don't remember if they had different length dips. Share this post Link to post Share on other sites
Mark siebenaler 93 #10 Posted February 15, 2023 4 minutes ago, Ed Kennell said: Eric, is it possible Mark's Sundstrand has a riser pipe requiring the longer dip stick? I don't have any Sundstrands left...only Eatons in my barn. There are three different Sundstrand models. I don't remember if they had different length dips. Thanks when I get a minute I will check the length on my riser . And compare... 2 Share this post Link to post Share on other sites
Ed Kennell 38,624 #11 Posted February 15, 2023 I just noticed, the C-160 used both the Sundstrand 1140 and the 1137. I'm not sure if they have different length dips. Share this post Link to post Share on other sites
ebinmaine 68,259 #12 Posted February 15, 2023 9 minutes ago, Ed Kennell said: Eric, is it possible Mark's Sundstrand has a riser pipe requiring the longer dip stick? I don't have any Sundstrands left...only Eatons in my barn. There are three different Sundstrand models. I don't remember if they had different length dips. Definitely a possibility. Mine has a riser... But... I can't prove it's original or correct. It seems to be about the right set-up. Share this post Link to post Share on other sites
Mark siebenaler 93 #13 Posted February 15, 2023 1 hour ago, ebinmaine said: Definitely a possibility. Mine has a riser... But... I can't prove it's original or correct. It seems to be about the right set-up. My riser looks very much original. Is there an obvious way to tell between three different transmissions 1 Share this post Link to post Share on other sites
Ed Kennell 38,624 #14 Posted February 15, 2023 59 minutes ago, Mark siebenaler said: Is there an obvious way to tell between three different transmissions The tow/ bypass valves are located at three different locations. One is a slotted screwdriver slot in front of the left fender. One is a petcock like valve on the top left center of the transmission. One is a hex head bolt on the left rear back of the transmission. I'm not sure what number goes with the valve location. @daveoman1966 probably has this info. Share this post Link to post Share on other sites
Mark siebenaler 93 #15 Posted February 15, 2023 Without removing fenders or top covers I can not see a relief valve so I'm sure it's some sort of bolt or something hidden? 1 Share this post Link to post Share on other sites
ebinmaine 68,259 #16 Posted February 15, 2023 4 hours ago, Mark siebenaler said: Without removing fenders or top covers I can not see a relief valve so I'm sure it's some sort of bolt or something hidden? Might be a bit tough to see but you shouldn't need to remove any sheet metal. Can you please post pics of your tractor so we can see what you're seeing? Share this post Link to post Share on other sites
Ed Kennell 38,624 #17 Posted February 15, 2023 Here is a pic of the tow/push valve that is on the transmission on many of the C-160s 2 Share this post Link to post Share on other sites
Mark siebenaler 93 #18 Posted February 15, 2023 Yep same exact spot 1 Share this post Link to post Share on other sites
Ed Kennell 38,624 #19 Posted February 15, 2023 SUNDSTRAND Automatics Schematics / Parts # ref - Transmissions - RedSquare Wheel Horse Forum This may help to ID the different Sundstrand hydro models. The C-160 should have a 90-1140 unless it was replaced. The tow valve should be as shown in the picture. 90-1136 90-1137 90-1140 90-2046 90-2062 Share this post Link to post Share on other sites
