Blackm84
Which one to buy and restore?
SylvanLakeWH
:eusa-clap:
953 nut
2 hours ago, Blackm84 said:
I'm going to power wash the C model and get it in the garage and start working on it,
Glad you made the purchase, you will be amazed at the work a "C" will do.
Prior to pressure washing I would suggest yo remove the engine tins and clean up the cooling fins too. Never know what may be in there including rodent nests and insect nests.
  • Excellent 2
Blackm84
I am going to do a complete disassemble and rebuild of the whole tractor.  That will be my main mower and tractor and I will retire my lt1000.  I've come to the conclusion that the wheelhorse will be better then anything I buy brand new.  Only thing that concerns me is cutting my ditch and starving the engine of oil but I also heard that is only a problem in the briggs with opposed cylinders and the oil slinger.
Blackm84
Well got them home here is some pics
  • Excellent 2
Blackm84
Here is one of the blower and deck
Blackm84
So the c145 needs a fuel pump rebuild, starts on carb cleaner.  I want to get it running and and change oil and see what kind of shape the motor is in.  But in the meantime I have to start trying to find a new seat or seat repair kit and a rear bumper the plastic one is cracked.
Blasterdad
Nice! It looks like a 42" RD deck.
By what I can see I don't think the snowblower is for the "C", looks like a "B" set up.
Interesting "drift buster" on the front of it, just when I thought I've seen it all, Lol.
Not sure about the plow either, the mount looks fabricated? :dunno:
It also looks like the hitch housing on the back of the transmission is busted on the "C"
She should clean up nice! :thumbs:
Blackm84
yea it looks like its partially cracked for the hitch mount, I am going to ask my buddy to see if I can try and weld a piece on there if not the only thing its going to pull is a small yard dump cart.  I need a service manual or parts break down especially for the front tie rods, it needs new ones but I am unsure which ones to get.  I really like the b-165 both models the tags are no longer legible so there either an 83 or 84.
Edited by Blackm84
SylvanLakeWH
wheelhorsepartsandmore.com has them. He's a vendor here... Good stuff and good people...
Blackm84
million dollar questions is the seat and rear panel/fender/bumper going to have to check ebay.  If I am not mistaken the 3,4,5 series rear panel/bumper will fit correct?
Blackm84
Here is a top pic of the deck
Blasterdad
That goes to the "C" :thumbs:
Did you get the mule drive for the deck with it?
Blackm84
I might have it has a bucket full of parts.  what is the mule drive?  Sorry if its a dumb questions I am new to these machines.
Pullstart
Awesome scores!  You might be soon looking for an 8 speed C series for the tiller… it may push the hydro more than you like.
I have a steel C series fender pan that I have no use for…. Shipping would be a killer though..
Blasterdad
Best pics I have at the moment, they're the PTO drive pulleys that mount on the front Tach-A-Matic...IMG_0401.JPG.bdd61f6dd8645fe83655ef3afa2acfd7.JPGPYWJ5536.JPG.4c0490cd80880022ebf8cd2207ca3c3d.JPG
Blackm84
Sending a pm.
Blackm84
Yes i think i saw that in the bucket by chance does it have 2 pulleys?  I might be hunting a new one of those as one of the pulleys was really bent up.
Blasterdad
Yes, that's it, 2 pulleys...:thumbs:
Blackm84
yea then I might have to hunt one down as one of the pulleys was bent really bad.  Will any mule drive fit on the c-145?  or are they really specific?
Blasterdad
Any C, 300 400 500 should work, the mule for a 520 H 60" deck being the exception, ( won't work ).
I think the 37" deck had a funky mule too...
Edited by Blasterdad
Brockport Bill
suggest you consider sand blast to clean bottom rust and corrosion -- get to clean metal, then prime and paint -- i did that and made major improvement - adds many years to lnogevity - - also installed delector flange on rear ( use cariage bolt with rounded head ) Cuttings do not discharge to rear underneath of tractor onto wheel rims, tires and tranny --- i used kitchen cabinate vinyl kick plate that has natural curve on edge
Blackm84
I will see if I can find it tomorrow and take a picture.  Maybe the pulleys are removable?
Blasterdad
Yes they are :thumbs:
Pretty easy to replace...:)
Blackm84
I plan on total disassembly and rebuild with stainless bolts and to rebuild the spindles.  That vinyl cabinet kick plate is genius!
Horse Newbie
Buy new ends from McMaster-Carr and build your own… they will be better than factory. That seems to be the trend around here.
Edited by Horse Newbie
