rmaynard 15,450 #1 Posted January 28, 2023 I'm thinking of putting an electric fuel pump on my 416-H. Has anyone had any experience with one of these? Share this post Link to post Share on other sites
953 nut 55,215 #2 Posted January 28, 2023 If you get a good one it will last a long time as one of mine has, the others gave up in less than a year and you are never near the barn when that happens. I have had good results with these over the past five years. 1 1 Share this post Link to post Share on other sites
rmaynard 15,450 #3 Posted January 28, 2023 Thanks Dick. The only reason that I suggested the one in my post is that my brother has used these on his Cub Cadets with success. All opinions welcomed. 1 Share this post Link to post Share on other sites
WHX?? 48,815 #4 Posted January 28, 2023 Used the same one on a customer's Cub ZT. Worked great and he didn't come back to complain so 2 Share this post Link to post Share on other sites
squonk 41,099 #5 Posted January 28, 2023 Carbole and Facet same pump with a different tag. It's what I use. I have seen the all metal round ones fail a lot. Share this post Link to post Share on other sites
pacer 3,169 #6 Posted January 28, 2023 I started out using that 'type' with good luck, but on about the3rd/4th one it failed too quick, tried another with quick failure so I switched to the type shown or this type---- had no more early failures... Share this post Link to post Share on other sites
pacer 3,169 #7 Posted January 28, 2023 Something to consider in using an electric pump on an Onan..... I had the B43m Onan and was having some crappy running conditions and I tried adding a lectric pump chasing the problem. I immediately had the carbs needle not holding and getting flooding, tried another 'Facet' type with same results, ended up using a new pulse pump which the Onan came with. (Problem turned out to be Ignition related) Now, as mentioned this was the B43 Onan and the P's may not be as sensitive, but if you go the lectric route, be sure and get a low pressure one (Ive never had a problem with the lectrics flooding on any Kohler) 1 Share this post Link to post Share on other sites
peter lena 8,622 #8 Posted January 28, 2023 @rmaynard agree with @953 nut on the pump, years now , no problems , added an LED dash light to verify on operation , comes on with key switch , also a good opportunity to add a vertical evil energy fuel check valve , constantly works and holds fuel from pump to carb , making for quick starts , pete Share this post Link to post Share on other sites
rmaynard 15,450 #9 Posted January 28, 2023 Thanks for all the good information. Share this post Link to post Share on other sites
lynnmor 7,305 #10 Posted January 29, 2023 8 hours ago, pacer said: Something to consider in using an electric pump on an Onan..... I had the B43m Onan and was having some crappy running conditions and I tried adding a lectric pump chasing the problem. I immediately had the carbs needle not holding and getting flooding, tried another 'Facet' type with same results, ended up using a new pulse pump which the Onan came with. (Problem turned out to be Ignition related) Now, as mentioned this was the B43 Onan and the P's may not be as sensitive, but if you go the lectric route, be sure and get a low pressure one (Ive never had a problem with the lectrics flooding on any Kohler) Your B43m probably had a fuel pump integral with the carburetor, all bets are off when adding a second fuel pump. Th Performer series have a separate pulse type of fuel pump. Share this post Link to post Share on other sites
kpinnc 12,017 #11 Posted January 29, 2023 12 hours ago, 953 nut said: I have had good results with these over the past five years. Got a link by chance? I have a Facet, but $70 each is a bit steep. 1 Share this post Link to post Share on other sites
RED-Z06 2,221 #12 Posted January 29, 2023 Ive removed quite a few electric pumps off customer mowers to return to or add-on a pulse type pump, common problems are lifespan...if you arent spending $60+ on a pump it may not last long. Going over bumps can cause momentary flooding/sputtering..because of the constant pressure and higher flow behind the seat...if the float drops it can rapidly overfill the bowl for a few moments. Most onans have a 20a charging system but some mowers only have 3a to 5a charging systems..the 2 to 2.5amp draw can be taxing on some mowers. Ive never had any problems with pulse pumps myself, ive added many to swapped engines and they have always performed well for me...you dont even really think about them because they just work. The original 1993 pump on my 416-H failed in 2020...started dripping out the vent indicating the dry side of the pump was wet. $25 pump and 2 minutes..back in business. If i run it dry by mistake its generally fires up in 8 seconds of cranking...nothing excessive. Oddly though..ive had 5 FD kawasakis that had a factory electric pump and never had any problems out of those..im not sure if they are just designed to work with the pump they have...but they work well. Share this post Link to post Share on other sites
953 nut 55,215 #13 Posted January 29, 2023 9 hours ago, kpinnc said: Got a link by chance? I have a Facet, but $70 each is a bit steep. https://www.ebay.com/itm/254470209464 Share this post Link to post Share on other sites
pfrederi 17,738 #14 Posted January 29, 2023 10 hours ago, kpinnc said: Got a link by chance? I have a Facet, but $70 each is a bit steep. Look other places for Facet. Last one I bought still made in USA. Do not think Carbole are made here 1 Share this post Link to post Share on other sites
pacer 3,169 #15 Posted January 29, 2023 14 hours ago, lynnmor said: B43m probably had a fuel pump integral with the carburetor My 2 B43's did not have the integral pump, and the particular parts manual I had showed the external pump mounted on the air shroud. ! didnt even know there was an integral type til I started prowling the bay and saw them. The plate was on the carbs, but it served no function. I've never had one of the P series Onans, but that 43 was VERY picky in tuning - carb just right, points very picky on setting, etc, but when that thing was dialed in just right it was a beautiful thing!! Share this post Link to post Share on other sites
RED-Z06 2,221 #16 Posted January 29, 2023 38 minutes ago, pacer said: My 2 B43's did not have the integral pump, and the particular parts manual I had showed the external pump mounted on the air shroud. ! didnt even know there was an integral type til I started prowling the bay and saw them. The plate was on the carbs, but it served no function. I've never had one of the P series Onans, but that 43 was VERY picky in tuning - carb just right, points very picky on setting, etc, but when that thing was dialed in just right it was a beautiful thing!! If you want to see a bad carb, look for the accelerator pump carb they used on some P series, it deleted the adjustable Idle bleed screw and replaced it with a diaphragm that on acceleration squinted fuel into the carb. Meant they ran lean as hell and the squirt kept it from bogging out. Share this post Link to post Share on other sites
lynnmor 7,305 #17 Posted January 29, 2023 7 minutes ago, RED-Z06 said: If you want to see a bad carb, look for the accelerator pump carb they used on some P series, it deleted the adjustable Idle bleed screw and replaced it with a diaphragm that on acceleration squinted fuel into the carb. Meant they ran lean as hell and the squirt kept it from bogging out. Wheel Horse only used them in the last year or so of production, thank the EPA for that nonsense. The best fix is to find an older carburetor and rebuild it. Share this post Link to post Share on other sites
RED-Z06 2,221 #18 Posted January 29, 2023 10 minutes ago, lynnmor said: Wheel Horse only used them in the last year or so of production, thank the EPA for that nonsense. The best fix is to find an older carburetor and rebuild it. Whats funny is, Kohler had to go to a pumper carb on Command Twins because they had such an awful off-idle bog...and those carbs fixed the problem and ran like tops. The onans didn't like it. I wish my onans had an adjustable main...ive made adjustable mains for a few engines but never for an onan. Share this post Link to post Share on other sites
