TractorEd
‘79 C-161 - Parts?
TractorEd
One of the steering wheel spokes is broke   :angry-banghead: right at the outer ring/grip, where the PO had installed a wheel spinner.  The spinner was gone when I got it, so I got a new spinner and installed it. :auto-driving:
It stiffened that broken joint up a bit, but is far from ideal.
I only just started putting penetrating fluid :coffee: to it last night.  Pin is basically seized.  It’s a 3-spoke wheel, hard plastic and doesn’t have a removable center cover on top.
Should I leave it well enough alone?
Should I get that wheel off there? :tools-hammerdrill:
Blasterdad
                         :text-yeahthat:
My vote.
c-series don
I think we’re going to need pictures 😂
  • Like 4
WHX??
:text-yeahthat:I like saving old things...now @c-series don... all his stuff is NOS...:ychain:
  • Haha 2
oliver2-44
I don’t spend more than a few minutes to try to drive pins out.  I learned from  @Achto to use a carbide glass/ceramic drill bit. I spray some penetrant as I drill to keep bit cool. Works great!
TractorEd
@Blasterdad I probably should have left well enough alone, but I didn’t.
I started with liberal amounts of penetrating fluid for about 12 hrs.
Then went at the pin with a hammer and punch.  I had a bar wedged between the wheel collar and the work bench which is against the wall.
I cracked the plastic base of the wheel in the process.  Then I used a wood chisel to finish splitting that crack open.  With the pin and metal wheel base now fully visible I can see that I had mushroomed the pin and that’s why it wouldn’t move anymore.
So, I ground the pin down to the metal wheel base and then used an air hammer to drive it most of the way out.  A few hits with the punch and it was free.
I took the metal wheel base off the steering shaft with a puller.
So, I do’d it.  If it looks like this when ur dun then u dun gud.
Wrecked my back, but after a good nights sleep I feel fine.  Glad I don’t have to keep working on that again today!  Good riddance!
I bought another original wheel from @A-Z Tractor and it’s out in the barn waiting to go on, but I don’t think I want to put a roll pin back in there.  I might replace the roll pin with a bunch of toothpicks.
@oliver2-44 I just bought a set of carbide ceramic/glass drill bits a few months ago.  I didn’t think they would work on steel.  Maybe should have researched some more!
Edited by TractorEd
  • Haha 4
c-series don
I think you did the right thing by replacing the wheel. A cracked one would drive me crazy(er) ! I’d apply copious amounts of anti-seize to the pin and the shaft so if there’s a next time it’ll be a bit easier!
TractorEd
Anti-seize!  You bet!!!  Thanks!
ebinmaine
19 minutes ago, TractorEd said:
PENETRATING FLUID
The 2 on the left ARE.
The two on the right are cans with another substance in them.
  • Haha 2
TractorEd
But, I did follow your advice with the Seafoam and Liquid Wrench!  I would have Kroil in that pic too but I couldn’t find it locally (where I looked anyway).
I left the other 2 in there just for the jeers.
:teasing-poke:
ebinmaine
:teasing-poke:
Kroil is great stuff but it's three times the price of Liquid Wrench 🔧 and that keeps me from buying it or even looking for it.
A friend of mine who's a truck tech gave me a spray can a few years ago and it worked great.
Handy Don
In my experience with how far this stuff goes, a "copious amount” is about ½ of a water drop!
And be ready with rags to wipe it off unintended surfaces!
  • Haha 4
WHX??
Why don't you like the blaster? I use it with decent results.
The guy that invented the adjustable spray nozzle on it should be made a saint!
SylvanLakeWH
:text-yeahthat: :confusion-confused:
I use it and liquid wrench... similar results... :twocents-twocents:
ebinmaine
Disclaimer:
I'm NO scientist and have never set up a true equal test.
I firmly believe that successfully removing rusty bolts is a result of patience,  time and care in movement.
I've tried several name brand penetrating oils over the years.
In my own experiences...
Kroil was the clear winner.
Liquid Wrench Penetrating Oil and WD-40 PENETRATING FLUID were similar in results.
PB as a penetrant has given me poor results from the get go.
Looking at the bolts as they come out there's very little actual fluid penetration from it.
For the record I do use and recommend another PB product that's an engine/carb  cleaner degunkerizer. Great for diagnostics.
TractorEd
2 hours ago, ineedanother said:
Agreed. And koozies are the best solution I've found for those danged red tubes. :thumbs:
Well I’ll be.  That’s slick!
kpinnc
That's hilarious. Having broke a steering wheel last week myself, I completely understand.
I think I'll use a long 1/4 bolt next time. At least it can be drilled out! :rolleyes:
ebinmaine
7 hours ago, kpinnc said:
I think I'll use a LONG 1/4 BOLT next time. At least it can be drilled out! :rolleyes:
Interesting old trick.
I've done so too.
Find a bolt that has an UN-threaded portion equal to the place you need to "pin".
If the threads are too long when done you can cut that part off.
We just did that on my 75 Automatic.  The hood hinges were replaced by a PO with regular threaded bolts. I didn't like having the threads in such a position that they could dig in to the holes so I found longer grade 8 bolts with nyloc nuts.
Cut 2 more threads and... Perfect length!
:handgestures-thumbupright:
kpinnc
2 hours ago, ebinmaine said:
I've done so too.
Scary! I use bolts and nylocks on the hoods all the time. Improves alignment when closing and eliminates hood rattling too. There's no more wear in the pivot afterwards either.
TractorEd
I've done so too
@kpinnc @ebinmaine
I received the bolts I ordered for this yesterday.  I already have some nylok’s.
I was concerned that the bolt wouldn’t be as tight a fit as the pin, but we’ll see.
I didn’t find a 1/4-20 with a shoulder for this application; so I have a fully threaded one.  At least I’ll be able to steer again!
Edited by TractorEd
TractorEd
Right after I posted above I did another search and found the shouldered ones I wanted.  So, they’re on their way. :lol:
Searched for:
1/4-20 x 3” SS partially threaded bolts
Found them on an online auction site.  2.2” shoulder (0.8” threads)
Edited by TractorEd
pfrederi
The 1/4" Clevis pin and hair clip have worked pretty well on my Lawn ranger for 56 years...Comes out easy...
kpinnc
Look at capscrews. They typically have longer shoulder lengths.
TractorEd
Finally have the hardware and time to get the steering wheel on.
2 3/4” seems ideal so I cut 1/4” off that 3” bolt.
Fits good.  No play using that bolt, so job done!
Edited by TractorEd
  • Like 6
  • Similar Content
    • D_Mac
    • D_Mac
      By D_Mac
      Well fellas since I had to sell off my Wheel Horses I felt like I didnt belong anymore. The Lambert and the Speedanza are cool but THIS IS a Wheel Horse Fourm. Well guess what....... Im back in ! Picked this up a little while ago. Saw it on CL and jumped right on it. Not a model I know anything about but it does say Wheel Horse on the side of it ! I am so excited to have it and the best part is that it runs and drives!!! It does need some work... I think the hydro is leaking as a saw a puddle of oil on top of the deck. Checked the dip stick and was hardly any in there. When you raise the deck it seems to come up higher on one side then the other. Seat is horrible, someone glued vinyl on it. Front head light lens busted, rear one is busted and no lights work. came with wheel weights for the rear but nothing else. Still trying to figure it out. I just got it home and off the truck. As usual any info I would love to hear about it. I dont know the year, I believe thats a 16 hp Kohler, not sure but it runs really good. Not a fan of driving it by a stick, seems like something you have to get used to then maybe like. Right now it just seems funny but I only did a little lap in my yard. I think I got a smoking good deal on it that makes me even happier.
    • Ritter
      By Ritter
      Greetings All,
      Really nice site, and I am a new member.   As I kick back and eat my lunch,  I could not have imagined that Wheel Horse Tractor owners would have such a cool and well-organized place to ‘meet’ despite being out of production for so long.  My name is Ron and I have a 1979 C-81.   It has a WH pull-behind cart as well as a snow plow with chains, weights, etc..
      The tractor belonged to my grandfather, who purchased it new in 1979 for just over $1,100.00.  Some of my best memories are learning to drive it (barely reaching the pedals) and trying to understand the difference between the clutch and brake.   I believe at one point it had a lawn sweeper, which eventually just dragged and made skid marks across the lawn until it was retired.
      My grandfather drove this tractor year-round for 7 years until he passed away.  In the winter it was plowing and hauling logs to the house, in the spring it aerated,  fall it mulched, summer it mowed.   The C-81 always remained at his house and in my family.
      The most interesting part (or at least interesting to me) is that for the last 39 years, this mower has been in-service without missing one season.  It has never been out of commission.   To this day, we have it picked up for service every year and it is still running on its original 8hp Kohler Engine and cuts just over an acre of lawn.  The only major replacements were pulley bearings for the blade deck and a starter motor.   It is ultra-quiet and never strains while performing its tasks. So, when you look at the picture,  you probably see a beat up old machine, but I can assure you that is a tried-and-true Wheel Horse used year-round for nearly 4 decades and maintained as best we thought possible.  It’s a testament to a reliable and powerful brand.
      That said,  I have decided to lessen the workload on this machine and perhaps get another Wheel Horse as a tribute to my Pop.    The main issue is that the cutting deck on this machine is between 32-34” (I believe) and it takes a long time to cut the lawn.  (although I enjoy the peaceful feeling of doing it, it’s not conducive with my day job).   The secondary issue is that this is a rear-discharge deck.  I’d like to somehow bag the clippings for most of my cuts in order to feed my mulch/compost pile.   I’m open for suggestions as to what model would be best.   I do have some hills (a few steep).
      One final note…
      I’d love to crown this C-81 with a new (or comparable) seat.   My goal is to get one as close to original as possible, with the same bolt patterns.  I can provide photos if needed.  Any help would be appreciated.   Again, glad to be a part of this community, and please bear with me as I get used to navigating this site.
      Thanks for reading.
    • tpuppo3
      By tpuppo3
      Hello all.  I spent about 30 minutes sorting through thousands of topics related to "high idle" but none of which answered my question, so apologies to all if this is a repeat.
      I recently bought a C161 (8 speed manual) with a Briggs & Stratton 18hp twin.  According to Briggs' manual they recommend idle to be set at 1400rpm.  I'm not claiming to be smarter than the engineers who designed it, but this seems incredibly high and wasteful on gas.  Realistically, a tractor engine isn't spending a lot of time idling (not like a car stuck in traffic or at a light) but it's more of an annoyance than anything.
      My question is, does anyone know 1.) why it's idle is so high, and 2.) has anyone tinkered with it to get it lower-without compromising other performance aspects of the engine?  All my personal preferences in relation to idle speed aside, the engine runs like a top (knock on wood).
      Thanks to all for your help.
    • wheelhorse-c-161-1979
      By wheelhorse-c-161-1979
      My 21.5 foot 3,500lb SeaRay is an easy park in my tight driveway thanks to my '79 C-161. Before going out or after coming back. I just use my C-161 with 16HP B&S to park it or pull it out for my truck.
