TractorEd
‘79 C-161 - Parts?
Blasterdad
5 hours ago, TractorEd said:
  I can see why the snow doesn’t want to fall near you!
It scared it away for a while, :occasion-snowman::violence-fencing: but it's still Michigan, the snowman will always have the last laugh...
Your :wh: is looking good !!!
TractorEd
  • Like 4
TractorEd
New Lift Handle!
  • Like 4
ebinmaine
Lookin' shahp!!
TractorEd
Picked up rims today!
PPG RAL 1013 Oyster White
  • Excellent 6
Blasterdad
Those turned out BEAUTIFUL !!!
What size / kind of tires ya gonna put on them?  :popcorn:
TractorEd
Carlisle Tires
Versa Turf 23 x 8.5 R12 rear
Turf Saver 16 x 6.5 R8 front (4-ply)
To be honest, I was going to put 10.5’s on the rear but I really like these Versa Turfs! And they don’t make them in that size.
I put the same on the C-100 and like that tread for my yard which is nearly all hills.
Edited by TractorEd
Blasterdad
Nice! gotta love new shoes!!! :thumbs:
TractorEd
Now I just have to find time to go get them mounted.
Edited by TractorEd
  • Heart 1
TractorEd
I learned with the C-100 that when you put fresh powder coated rims on wheel hubs they tend to stick together really good.
This time around I made these “protectors” to hopefully avoid that again.
I cut them from a plastic divider for binders (folders).  I hope they work!
Edited by TractorEd
  • Excellent 3
ohiofarmer
On 1/28/2023 at 10:17 AM, ebinmaine said:
:ROTF:
@Achto is having fun with Seafoam Deep Creep lately.
@AHS is using a very particular WD-40 Company product.
NOT the original formula but a penetrant.
I've used Kroil. Expensive but good.
My preference the last couple years has been good ole fashioned
Liquid Wrench Penetrating Oil.
Inexpensive.  Effective.  Readily available.
Patience is the key!!
   I will throw a few more penetrating oil thoughts into the ring. It's called In force by BG products.it is sold by vendor shops that will try to sell you other things which I will not comment on. I think that different penetrating oils are better on different applications. i applied it to a Wheel horse deck at the aluminum blade towers that were at least forty years old. Six weeks later they came off with no snapped bolts, and the product was coating all the threads with a wet look. This is with one application only because i simply had other things to do. Never would have believed that could happen with one application. So for spray and forget it, quite the one application product
FreezeOff works great on motorcycle aluminum cases that have slowly bonded to the case screws. it is thin, but can crawl a long distance up bolt fine threads if applied over many days twice a day for a week or two. One other thing it excels at is to penetrate and loosen gasoline varnish where nothing else will do it. i have seen this stuff producing a bubbling reaction for an hour on gas varnish. i doubt that the manufacturer even knows this.Ignore the instructions on the can. Freeze off will cool down to frost on the metal it is sprayed on for thirty seconds.  Who wants to waste product and money like that?
  Kroil is great stuff , but the propellant leaks away over time and that is expensive, i called the company and they were so kind to replace the can for me.
Edited by ohiofarmer
TractorEd
One of the front rims is leaking air out the hole where the grease fitting threads into.
Anyone have a fix for that?  Pipe dope?
May be in the market for a front rim or pair of rims.
  • Sad 2
Blasterdad
I'd try teflon tape first, maybe a spot weld or JB weld on the inside of the rim ? Can you see a hole inside the rim?
TractorEd
Tires were just mounted today, I don’t want to break the bead, not yet anyway.
TractorEd
If this pipe dope doesn’t work I’ll try Teflon tape.
ebinmaine
Tubes
  • Like 5
kpinnc
Inner tube.
TractorEd
45 minutes ago, ebinmaine said:
Tubes
43 minutes ago, kpinnc said:
Inner tube.
Yeah tubes for sure if it’s still leaking tomorrow.  I’ll get back on it this weekend and see if it drives.
Thanks!
ebinmaine
Thanks!
Ed, I've gotten to the point where ALL the tires I swap/deflate/install get a tube.
No more trying with 3 men and a boy to get the bead to seat and situations like yours are eliminated.
  • Like 4
TractorEd
I’m happy to announce that, she’s a runner!
And a mover!
And the hydraulic lift works!
Money well spent!
I like exclamation points!!!
Edited by TractorEd
  • Excellent 6
ebinmaine
:ROTF:
  • Haha 1
TractorEd
I still have work to do, but my other work has been consuming all my time!
Anyway, here’s a rando pic.  Does this routing look proper for a C-161 ( fuel line and ground for headlight/hood)?
c-series don
I’ve never seen the fuel line clamped to the shaker plate before. Usually clamped to the blower housing using the housing bolts. The ground wire was added as an additional. Personally I like the idea because the lights were grounded through the hood, which was grounded through the hood hinge pin and the hood latch. Just my observations over the years. Not that I worked at the factory or anything, although sometimes I wish I did!
  • Like 5
TractorEd
Thanks for the info!  The fuel line is clamped the same way on the other side of the shaker plate too.  I thought it was an interesting choice; maybe partially due to one of the blower housing bolt holes being strippped out (which I blue loctited that bolt in place for now).
Edit: These pics, and some other pics in other posts, were taken before I started working on getting it running and cleaned up.  I don’t want anyone thinking she’s being neglected!
Edited by TractorEd
  • Excellent 2
TractorEd
I installed the front tubes and now she’s able to trot.
Then I greased all the fittings while she was still in the air.
And thanks to @A-Z Tractor she has a mule drive, too.
Edited by TractorEd
  • Excellent 4
  • Similar Content
    • D_Mac
    • D_Mac
      By D_Mac
      Well fellas since I had to sell off my Wheel Horses I felt like I didnt belong anymore. The Lambert and the Speedanza are cool but THIS IS a Wheel Horse Fourm. Well guess what....... Im back in ! Picked this up a little while ago. Saw it on CL and jumped right on it. Not a model I know anything about but it does say Wheel Horse on the side of it ! I am so excited to have it and the best part is that it runs and drives!!! It does need some work... I think the hydro is leaking as a saw a puddle of oil on top of the deck. Checked the dip stick and was hardly any in there. When you raise the deck it seems to come up higher on one side then the other. Seat is horrible, someone glued vinyl on it. Front head light lens busted, rear one is busted and no lights work. came with wheel weights for the rear but nothing else. Still trying to figure it out. I just got it home and off the truck. As usual any info I would love to hear about it. I dont know the year, I believe thats a 16 hp Kohler, not sure but it runs really good. Not a fan of driving it by a stick, seems like something you have to get used to then maybe like. Right now it just seems funny but I only did a little lap in my yard. I think I got a smoking good deal on it that makes me even happier.
    • Ritter
      By Ritter
      Greetings All,
      Really nice site, and I am a new member.   As I kick back and eat my lunch,  I could not have imagined that Wheel Horse Tractor owners would have such a cool and well-organized place to ‘meet’ despite being out of production for so long.  My name is Ron and I have a 1979 C-81.   It has a WH pull-behind cart as well as a snow plow with chains, weights, etc..
      The tractor belonged to my grandfather, who purchased it new in 1979 for just over $1,100.00.  Some of my best memories are learning to drive it (barely reaching the pedals) and trying to understand the difference between the clutch and brake.   I believe at one point it had a lawn sweeper, which eventually just dragged and made skid marks across the lawn until it was retired.
      My grandfather drove this tractor year-round for 7 years until he passed away.  In the winter it was plowing and hauling logs to the house, in the spring it aerated,  fall it mulched, summer it mowed.   The C-81 always remained at his house and in my family.
      The most interesting part (or at least interesting to me) is that for the last 39 years, this mower has been in-service without missing one season.  It has never been out of commission.   To this day, we have it picked up for service every year and it is still running on its original 8hp Kohler Engine and cuts just over an acre of lawn.  The only major replacements were pulley bearings for the blade deck and a starter motor.   It is ultra-quiet and never strains while performing its tasks. So, when you look at the picture,  you probably see a beat up old machine, but I can assure you that is a tried-and-true Wheel Horse used year-round for nearly 4 decades and maintained as best we thought possible.  It’s a testament to a reliable and powerful brand.
      That said,  I have decided to lessen the workload on this machine and perhaps get another Wheel Horse as a tribute to my Pop.    The main issue is that the cutting deck on this machine is between 32-34” (I believe) and it takes a long time to cut the lawn.  (although I enjoy the peaceful feeling of doing it, it’s not conducive with my day job).   The secondary issue is that this is a rear-discharge deck.  I’d like to somehow bag the clippings for most of my cuts in order to feed my mulch/compost pile.   I’m open for suggestions as to what model would be best.   I do have some hills (a few steep).
      One final note…
      I’d love to crown this C-81 with a new (or comparable) seat.   My goal is to get one as close to original as possible, with the same bolt patterns.  I can provide photos if needed.  Any help would be appreciated.   Again, glad to be a part of this community, and please bear with me as I get used to navigating this site.
      Thanks for reading.
    • tpuppo3
      By tpuppo3
      Hello all.  I spent about 30 minutes sorting through thousands of topics related to "high idle" but none of which answered my question, so apologies to all if this is a repeat.
      I recently bought a C161 (8 speed manual) with a Briggs & Stratton 18hp twin.  According to Briggs' manual they recommend idle to be set at 1400rpm.  I'm not claiming to be smarter than the engineers who designed it, but this seems incredibly high and wasteful on gas.  Realistically, a tractor engine isn't spending a lot of time idling (not like a car stuck in traffic or at a light) but it's more of an annoyance than anything.
      My question is, does anyone know 1.) why it's idle is so high, and 2.) has anyone tinkered with it to get it lower-without compromising other performance aspects of the engine?  All my personal preferences in relation to idle speed aside, the engine runs like a top (knock on wood).
      Thanks to all for your help.
    • wheelhorse-c-161-1979
      By wheelhorse-c-161-1979
      My 21.5 foot 3,500lb SeaRay is an easy park in my tight driveway thanks to my '79 C-161. Before going out or after coming back. I just use my C-161 with 16HP B&S to park it or pull it out for my truck.
