pacer
Banged finger nail treatment???
pacer
No doubt all of us have had what @gt14rider is showing in his post on cutting a keyway....
So, my question is -- how do you handle this rather painful event??  Small drill twirled, sharp point of a knife twirled??? these work ... OK, but wow, is it painful!
So, I'll share MY method in case you havent tried it, MUCH less painful.
I like a paper clip but anything small metal (1/16" drill bit?) and using any heat source (I like a barbecue lighter) and heat the tip and quickly/gently press it in the blood area, may take 2-3-4 times but it will pretty quickly melt through and release the blood with much less pain...... Ahhhhh!
  • Like 4
  • Sad 2
Skwerl58
Mashed fingers are painful! I also use the heating of a needle or paper clip to release the pressure.
  • Like 3
Red-Bovine
I have used that method, but prefer the small drill bit.
ri702bill
I tend to choose the procedure as to where the blister is. If it is in the thin part of the nail near the cuticle as pictured - the heated pin or needle.
Out front or on the side where the nail is thicker - the drill is a better choice.
A word of advise - there is pressure built up causing the discomfort - do either method outside - it will spray blood once it has a path to follow !!
CCW
Years ago as a young man went to doctor with this problem.  He heated a small pith and melted right through.  Relief was immediate.
Last July I cracked the nail of my middle finger from side to side.  It has been 24 weeks and is almost completely grown out.
gt14rider
It hert like hell when I did it, but thumb was still attached, couple of choice words, it hert 1st day, doesn't hert at all, but will try your methods if necessary  thanks for all your advice.
Truck mechanic for 40 years, that thumb has been hit so many times.
  • Haha 1
  • Sad 1
lynnmor
Since we were talking speeds and feeds, here is what I do for a nail like that.  I run a sterilized .028" drill at several thousands RPM and feed the nail into the drill.  Instant relief.  If you have a Dremel, clamp it down so it can't move.
gt14rider
(Clamp it down so it can't move?)
The dremel or the thumb?:jaw:
  • Haha 4
Ed Kennell
Calling the pain Guru....you out there Kev?  @Pullstart
  • Haha 4
Pullstart
Hey!  I spent a few hours in the shop today and no smashed thumbs!  Just a few burns from TIG welding! :lol:
I prefer the small drill bit method.  I can control the twist and relief better than pushing a hot object towards my under skins.
  • Excellent 1
  • Haha 2
  • Heart 1
19richie66
Elevator door :D
  • Sad 4
lynnmor
I actually said “If you have a Dremel, clamp it down so it can’t move”
  • Thanks 1
varosd
Medico here
The condition is known as a Subungual Hematoma
evacuating the blood will prevent possible loss of fingernail, a paperclip, drill point etc are fine.
if you wait a day or two, the blood with coagulate so sooner is better
I have a disposable electrocautery unit here in the clinic.  heats up the looped tip red hot.
pacer
Yes, the quick loss of heat using a paper clip, etc is a factor, in that with the loss of heat, it has to be repeated until it goes through the nail .... but, in a way thats good because you dont have to put much pressure onto that ... VERY tender spot. When using a drill bit it needs a fair amount of pressure to penetrate the nail, and that can seem like its taking forever:scared-eek:
953 nut
I just wrap the finger/thumb tip in multiple layers of gauze for a few days. Never lost the nail and in a couple days the pain is about gone.
19richie66
Like a country song. The pain is gone but the memories remain….. for a while
  • Haha 3
ri702bill
And I thought that was a "blues" song....na..na..na..na.
Edited by ri702bill
  • Haha 1
gt14rider
Looking good
peter lena
@pacer been there done that , tried  both a tiny drill bit and a  match heated needle , both pretty rough , sharp tiny bit , got to the leakage stage pretty easy , that hot needle was , like the tower of London !  got a wrist cut that was a beauty , had a socket adaptor break , on a brake caliper , wrist to fender edge , 6 stitches,  pete
Ed Kennell
Made by ............?
peter lena
@Ed Kennell  think it was a snap on , broke at the female side , actually split . got a new one , but still  broke when doing the job it was saposed to do . that fender edge made a nasty cut , pete
  • Sad 1
