TractorEd 637 #1 Posted January 22, 2023 (edited) I’m trying to determine the routing that was originally used on the taillights of a rear gas tank mounted model with 2 taillights. Or advice on how others have routed it from the taillights to the 3-way connector in the cavity below the fender/seat pan. I’ve never seen this tractor put together. The most obvious routes for the positive leads would lay against the plastic gas tank in the rear; either across the top of it or against the sides/corners. Also, the parts diagram shows the ground wire going from one taillight to the other and then runs to a ring terminal, but not sure where that ran to either. Pics? I’m working on a ‘79 C-161 but it could be just about any model/year rear tank Horse with dual taillights. Thanks, Ed Edited January 22, 2023 by TractorEd 1 Share this post Link to post Share on other sites
Blasterdad 2,779 #2 Posted January 22, 2023 Mine just lay on top of the tank & plug into the connector, you can see it next to the dipstick in the pic. You can ground it pretty much anywhere... 1 1 Share this post Link to post Share on other sites
TractorEd 637 #3 Posted January 22, 2023 1 minute ago, Blasterdad said: Mine just lay on top of the tank & plug into the connector, you can see it next to the dipstick in the pic. You can ground it pretty much anywhere... Thank you for the info, Blasterdad. 2 Share this post Link to post Share on other sites
peter lena 8,970 #4 Posted January 22, 2023 @TractorEd used TYE WRAP STICK ON MOUNTS , and spiral wire wrap , also did a reroute of original wire set up . also enhance engine grounding , for related electrical connections . verify as you set it up for function , original ground area s typically rust / paint make for trouble spots , pete 1 Share this post Link to post Share on other sites
TractorEd 637 #5 Posted January 22, 2023 53 minutes ago, peter lena said: @TractorEd used TYE WRAP STICK ON MOUNTS , and spiral wire wrap , also did a reroute of original wire set up . also enhance engine grounding , for related electrical connections . verify as you set it up for function , original ground area s typically rust / paint make for trouble spots , pete Thanks for the info! I’d like to see how you routed it. I may do the same. 1 Share this post Link to post Share on other sites
peter lena 8,970 #6 Posted January 22, 2023 @TractorEd ED typically when I do over any wire set up , l eliminate tight stressed wiring , chafed areas , set up a out of the way area. the wire wrap contains it / protects it , those tye wrap mounts like any clean paint . the added grounding is basically an added ground cable from battery ground bolt point to frame / engine corner , that insures any related connections to engine are grounded , also on to head lights , a few other improvements I have also added . note 4 th picture down , yellow electrical lug from rectifier base to headlights . solid bright , because the block is grounded to frame , springs assist choke and throttle cables , to close . use SUPER LUBE OIL in those cables , smooth / easy . ideas that work , lots of hours , and no failures , pete 1 Share this post Link to post Share on other sites
c-series don 9,261 #7 Posted January 22, 2023 I believe from the factory there’s one wire that runs over the top of the gas tank and the lights are grounded through the fender pan. 2 1 Share this post Link to post Share on other sites
TractorEd 637 #8 Posted January 23, 2023 15 hours ago, c-series don said: I believe from the factory there’s one wire that runs over the top of the gas tank and the lights are grounded through the fender pan. Thank you c-series don! 2 Share this post Link to post Share on other sites
peter lena 8,970 #9 Posted January 23, 2023 @TractorEd regularly use https://www.bing.com/images/search?q=mechanical+electrical+lugs&id=46B5B352C3AA85C1343D901346F975C312472B68&form=IQFRBA&first=1&disoverlay=1 only as a type of connection for reference , but you can easily add to it . would be in the contractor section , especially good in a new grounding layout . easy access / addition . also regularly go after any , repetitive issue areas . example , linkage function areas , fuel issues , charging , starting ,TAKE ADVANTAGE OF A FAILURE , can you make it act up anytime ? thats how I go after any issue . but then I will also detail it in for function / operation . every one of my chronic problems , is now a strong point , eliminate / improve every stage . this is only my view of problem solving . make it reliable , pete 1 Share this post Link to post Share on other sites
TractorEd 637 #10 Posted January 26, 2023 (edited) @Blasterdad @peter lena @c-series don Appreciate all your help! I don’t like running these wires on top of the fuel tank, but that’s the best route to take so I’m going to. 😀 But I’ve just ordered some of this fire retardant and abrasion resistant sleeve material that I’ll run the wire through. PET Expandable Braided Sleeving 100Ft-1/8 inch Wire Loom, Aibole Braided Cable Sleeve Wire Wrap,Black&Red https://a.co/d/8N3rcF8 I really appreciate all the feedback! Thanks again, Ed Edited January 26, 2023 by TractorEd Spelling correction 4 Share this post Link to post Share on other sites
c-series don 9,261 #11 Posted January 26, 2023 @TractorEdPlease keep us updated with your progress. 1 Share this post Link to post Share on other sites
TractorEd 637 #12 Posted January 27, 2023 7 hours ago, c-series don said: @TractorEdPlease keep us updated with your progress. @c-series don You prompted me to create a thread just for that purpose. Your collection is awe inspiring! Really incredible looking machines! 1 Share this post Link to post Share on other sites
c-series don 9,261 #13 Posted January 28, 2023 @TractorEd Thanks Ed, I’ve added a few more to my collection since I last took a group photo! This summer I hope to take them all out for a new photo. 1 Share this post Link to post Share on other sites
