jagco
Looking at buying 315-8
Lagersolut
I own a 315-8 from new . It's a good machine but I had to make a few adjustments - leaked oil after a couple few years from the overhead valve cover - thinking this was an easy fix went to the parts list - long story short there isn't gasket - Kohler did what we use to do years ago for a short term fix - called them smear gaskets - run a bead of form a gasket on the cover channel re-install . I ordered gasket material cut my own installed a real gasket - 10-12 years later still dry . Next , the engine has an air induction tube from the blower housing to the air cleaner - mow the grass ( my acre ) 3 times the air cleaner was packed full of dirt and grass - to me this was designed to self destruct so the tube was eliminated , closed off the opening on the housing and air cleaner with sealant and sheet metal . Unlike my Kohler K's these aluminum jugs accumulate a lot more grass under the tins around the jug and fins - regular trips to the air compressor to blow out debris is highly recommended   . Exhaust - Kohler is proud of that muffler - 1 month off warranty cracked off the flange-  repeated trips to get it welded - kept cracking behind each repair bead - 3-$400  for a new one - fast forward to last year #2 muffler had a crack at the flange -long story short I put the problem on anther forum- found a tig welder who said these needed a delicate touch you can't overheat the metal - his number is now stored in my phone - talk about a pro bead - this guy knows his weld/metals  -     I don't mow much at all with the 315 anymore it's a dedicated blade tractor for snow -mulch -ground etc etc , I'm hooked on the 416-8 with a 4ft deck for mowing and blowing duties .
Would I go 5300 on it - probably not - new or not these tractors have a very limited audience - sitting all these time without oil moving around coating the gears and seals would be a major concern - something tells me oil leaks right out of the gate with dry cracked seals - these cast iron cases like moister half the gears are above the oil - I once rebuilt a Troy built  horse that sat for years - the main drive shaft that sat out of the oil from non use was .......toast ....just my 2 cents
Thor27
Sorry, zero help from me on the 315.  I just got to say that little truck looks like a lot of fun.  What 4 sp is that?   How do the mopar purists react to seeing a sbc?
jagco
On 1/20/2023 at 5:08 PM, Blasterdad said:
Sorry to hear your tractor was stolen. :(
"C" Series are good mowers too, basically the same tractor as the 300-400's but with less wiring....
Personally I would not start out with a 520, way more complicated & Onan parts are pricey...
This is my "go to girl" for mowing, 1976 C-120 with a 48" deck. She ticks like a swiss watch...
One of my C-81's with a 36" rear discharge deck, I use it for cutting in around tree's and close to the house & smaller parts of the lawn.
thanks for the info
jagco
Thanks to all for your help,  I do get few jokes like 1/2 breed. Trans is tex racing out of a nascar. Clutch-less shifting only take off. I had mazda rx7 with mopar 372 motor 727 dana 60 rear sold it few years ago.
re-moving the th350 trans I had in the truck. The arrow is my old drag race truck.
kpinnc
On 1/21/2023 at 10:49 AM, clueless said:
Two acres plus eight more to cut, take the $5300 and buy a good Z-turn, you won't be disappointed and you'll have way more time to work on the truck :handgestures-thumbupright:.
If you want just a mower, I have to agree. I genuinely love my Wheel Horses, but my zero turn cuts my mowing time by hours. There is just no comparison.
John c
the price would be enough to put me off, that later model OHV engine would be all it took for me to walk away. Hold out to find a 312 or 314 if you want another "garden" tractor. the 2 guys ahead of me are right, buy a ZTR to cut the grass with
