peter lena 8,589 #1 Posted January 20, 2023 https://www.northshorecommercialdoor.com/li22gadoopst.html?msclkid=941f00ea8d2414682148632028460a40&utm_source=bing&utm_medium=cpc&utm_campaign=ECI - Google Shopping - , just moving stuff around , had a spare , was thinking about a bracket make up point , add a male / female heim joint , hook up a chain , etc paint it red , pete 5 Share this post Link to post Share on other sites
ebinmaine 67,330 #2 Posted January 20, 2023 Depending on length that could be a replacement for a solid plow link eh? 2 Share this post Link to post Share on other sites
peter lena 8,589 #3 Posted January 20, 2023 @ebinmaine, yup thats what I was thinking , could easily , make that into something , made to lift a garage door , so you know its solid and already hole drilled . regularly make things up from a what if idea , I won't tell anybody you might dare to create a fix , pete 3 Share this post Link to post Share on other sites
Racinbob 11,045 #4 Posted January 20, 2023 Yup. I've had and still have a couple of those. Repurposed several. I never get rid of them. 4 Share this post Link to post Share on other sites
19richie66 17,500 #5 Posted January 21, 2023 I have three of them laying on my table. Son is in the garage door business so when he swaps out a opener, I have him save them for me. 1 1 1 Share this post Link to post Share on other sites
peter lena 8,589 #6 Posted January 21, 2023 @19richie66 when you think about it , if you cut out the hole drilled section of that bar , elastic lock nut bolted to the , upper lift arm , that would make it smooth / solid ,grease from there , eliminating the trunnion sloppy play / wear spot . then add chain / heim make up easier at lower connection . just an idea , always experiment with easy function / hook up / durability / you can make attachments hook up and work easily , if you do that , the you cant do that starts , have that on my horses , pete 1 Share this post Link to post Share on other sites
peter lena 8,589 #7 Posted January 21, 2023 @ebinmaine as you know , when you set up anything , repeating its intended function , gives you other improvement ideas , smooth short shank bolt at top connection washers , eclectic lock nut , grease, would make the start of the lift , easy / solid. also detail related connection points , lubricant . make it feel like butter , once I started that on my linkage areas , now its a regular thing , I won't tell any one , pete 1 Share this post Link to post Share on other sites
