WHX?? 50,758 #76 Posted February 2, 2023 11 hours ago, Pullstart said: 1” axles Uncle Jim? We need to make it a package deal and trade hubs too? If you need the hubs they can go with the 10" rims. I'm 1" hub heavy. What do you have for rubber tho? 2 Share this post Link to post Share on other sites
Pullstart 64,577 #77 Posted February 2, 2023 2 minutes ago, WHX?? said: If you need the hubs they can go with the 10" rims. I'm 1" hub heavy. What do you have for rubber tho? I’ll have to take inventory… 1 Share this post Link to post Share on other sites
WHX?? 50,758 #78 Posted February 2, 2023 (edited) 11 hours ago, Darb1964 said: I think the plate should go behind the starter bracket Good catch Darbs I'll try that. 11 hours ago, Handy Don said: That would put the starter even further from the flywheel. That's where the hack saw blades were Don. About the same thickness of the plate too. Anyone have a pic of how it should be? A B-80 should be the same. I can't seem to find a IPL for one. Edited February 2, 2023 by WHX?? 1 Share this post Link to post Share on other sites
WHX?? 50,758 #79 Posted February 2, 2023 5 minutes ago, Pullstart said: I’ll have to take inventory… I'll put my order in for 12" ags if yer heavy... 1 2 Share this post Link to post Share on other sites
ebinmaine 70,781 #80 Posted February 2, 2023 41 minutes ago, WHX?? said: Good catch Darbs I'll try that. That's where the hack saw blades were Don. About the same thickness of the plate too. Anyone have a pic of how it should be? A B-80 should be the same. I can't seem to find a IPL for one. @OldWorkHorse Steve's got my old b80. 1 Share this post Link to post Share on other sites
WHX?? 50,758 #81 Posted February 3, 2023 22 hours ago, Handy Don said: That would put the starter even further from the flywheel. Right again Don. I tried to move the coil mounting plate behind the starter @Darb1964 but it made it worse. Only thing that worked was adding shims like the PO did... gotta be the wrong starter...runner... 2 2 Share this post Link to post Share on other sites
WHX?? 50,758 #82 Posted February 4, 2023 Cleaned & regreasy Pete the PTO bearing & replace the noisy thrust bearing. Different seat & springs underneath it. Gonna call it done. Needs a bath yet... still road salt on it from the score. Some small items yet. Make a strap for the battery box. Install a slot hitch & cable. How's inventory on rubber Kev @Pullstart? I think I'm gonna take the ags & tri ribs off a Raider 12 that is going on the auction block but I will need some run of mill turfs to put on it. Aunt B is gonna be another house plow mule ... eight on a eight... I fell in love with it so can't flip it now. Thanks guys for all yer help on it. -5 here but got seat time ... she didn't mind. 3 6 Share this post Link to post Share on other sites
953 nut 57,965 #83 Posted February 4, 2023 12 hours ago, WHX?? said: Aunt B is gonna be another house plow mule If only they would respond to voice commands you could have all eight Wheel Horses fitted with plows and marching along behind one-another. 3 1 Share this post Link to post Share on other sites
