moe1965 749 #1 Posted January 15, 2023 (edited) I purchased a new rectifier but there are no markings on what wire goes where I know two of them go to the AC side and the other goes to the back of my key switch marked R. Unfortunately I do not have the old one to look at which did have the markings but for the life of me I can't find it... I think the two circled in red are the rete marked AC. Thanks in advance Edited January 15, 2023 by moe1965 More info 1 Share this post Link to post Share on other sites
squonk 41,650 #2 Posted January 15, 2023 (edited) Two leads side by side (red circle) are AC Power from stator. It doesn't matter which wire goes on either terminal. Terminal by itself goes to the switch. Edited January 15, 2023 by squonk 1 1 Share this post Link to post Share on other sites
peter lena 8,888 #3 Posted January 15, 2023 @moe1965 don,t forget to enhance the mounting bolt point for grounding , usually engine to frame corrosion and metal duct work are weak areas for ground ,suggest an alligator clip test wire from battery ground cable ground bolt to that rectifier mount bolt , area on initial testing . if that ground makes your amperage gauge stand at attention , and charging is solid , thats what you want . don,t count on original ground areas , too erratic . pete 1 Share this post Link to post Share on other sites
mike avad 41 #4 Posted January 20, 2023 so this is what this part is called? I have a 1988 or 89 wheel horse that has one. how to tell if they go bad? here what happen to me just a few day ago I went to start my tractor and the starter lock up and melded the post of the solenoid so I replace both part's new and more ignition switch all new clean all the ground check wires for bad spots with tester. seat switch brake switch still no turn over? bat good, went out to day and took off the steel dash plate so I turn on the pot switch and rub the plater on the tractor and it spark?would it be that part called RECTIFIER. everything work fine until this happen.is that part is bad what the price of one and where a good place to buy it?this my number 2 tractor iv work on and am NEW at this am STUCK here. trying to keep the old horse alive. THANK'S for any help and info 1 Share this post Link to post Share on other sites
mike avad 41 #5 Posted January 20, 2023 sorry forgot my tractor is a 252-H also 1 Share this post Link to post Share on other sites
moe1965 749 #6 Posted January 20, 2023 I got mine on Amazon for $31.00. This is what was wrong with my issues. I also found out PO switched some wires around which probably burned up my old on . 1 Share this post Link to post Share on other sites
mike avad 41 #7 Posted January 21, 2023 did you buy one the same as your old one?I seen one just like mine but it was for Kohler engine and my wheel horse has a briggs&stration intek 17.5 HP was trying to fine out if that I found will work on my wheel horse with a briggs on it? thank's for your reply on this also. Share this post Link to post Share on other sites
moe1965 749 #8 Posted January 22, 2023 I took the part number off my old rectifier and Google searched that to find my replacement. My tractor has a Kohler engine on it. I would say you will have to research what is specific to your engine being a brigs and download a wiring diagram and trace each wire to make sure it's all connected to the correct terminals etc... Share this post Link to post Share on other sites
mike avad 41 #9 Posted January 22, 2023 (edited) OK THANK YOU Edited January 23, 2023 by mike avad add more info 1 Share this post Link to post Share on other sites
mike avad 41 #10 Posted January 23, 2023 got mine to turn over had to put alittle gas in the carb. and safety switch next thank you all for replys 1 Share this post Link to post Share on other sites
