Sparks58
1970 Electro 12 Model 1-7255
Sparks58
On 1/11/2023 at 1:43 PM, Cub fan said:
I am reading your article on electro 12, I have one and a owners manual it has a wiring diagram in it. I can copy each page or take pictures and send them. Do you need all pages or just wiring. I do not have a parts catalog. Jim
Please do. I can use all the info I can get
Blasterdad
9 hours ago, Sparks58 said:
The other one doesn't quite match the outer pulley size. What do you want for yours?
How about just trade for one that fits....:thumbs:
Blasterdad
Anyone know where I can find a parts list for the 5-1422 deck? I have a diagram but no numbers to go with it.
Cub fan
Cub fan
Sparks 58, sorry this is late, if you want to call me or give your mailing address I can sent a copy of owners manual. Phone is 317  450  2647 Jim
Sparks58
1520 N 26th St, Kal Mi 49048
953 nut
We have a download copy of the Owner Manual with wiring for free on this site.
Sparks58
On 1/11/2023 at 3:32 PM, Pullstart said:
For the PTO?  Is it not an electric PTO?
I located the original wire for the E-PTO. Apparently, it was modified. I do need an electric clutch or replacements for the Hub and friction plate.
Edited by Sparks58
Sparks58
On 1/11/2023 at 4:58 PM, Blasterdad said:
Looking good!
That pulley bell is torched! The rivets ate it up, is the one behind it in your pics good?
If not I have one...
The one behind it good but the diameter of the outer pully is smaller. Is that not the one for the rotary deck drive? If the inner is it, I'm covered on the bell.
Blasterdad
Inner pulley is for the deck, outer is for snowblower...:thumbs:
Sparks58
Great news! I have a replacement for the bell then. Looking for disc or new friction surface now. Thank you.
Sparks58
Received it yesterday! Awesome! Thank you my friend.
Sparks58
On 1/14/2023 at 11:22 AM, Sparks58 said:
Blasterdad
Looking good! :thumbs:
I rebuilt a deck just like yours last year, I converted it to a newer Tach-A-Matic carrier system.
Those decks are SOLID & mow great!
It'll be headed for the paint booth in the spring.
The only problem was the fully enclosed belt gaurd design. It traps dirt, grass, & moisture, which eats up the tensioning bar's plastic bushings & guides.
The newer style decks had a 3 piece guard system which allows you to be able to blow / wash all that out.
I leave the cover off my older decks so I can clean them after each time I mow, (I'm the only one who operates my tractors & don't have kids or pets around to worry about).
I'm not suggesting you do the same, just take the cover off occasionally, or in the fall when you're done mowing for the season & clean it out good.
The :wh: is looking good too...:)
Edited by Blasterdad
kpinnc
1 hour ago, Blasterdad said:
leave the cover off
I leave the covers off of all of mine (except the 60) for the same reason. Tractors with full steps pretty much cover the spindles anyway so far as where feet can go.
If you decide to leave it on, just be sure to remove it and clean the spindle area regularly. On the 42SD, the grass isn't the only problem. That stamped depression acts like a swimming pool for condensation and it will rust no matter what you paint it with.
Sparks58
Same reason I don’t put the covers on my JD. I’ll pass on the wisdom of owners to the SIL. Thank you my friends. I’ve also told him he needs to join.
Sparks58
