Brockport Bill 1,773 #1 Posted January 7, 2023 Was wondering if when people obtain engines with old "black" oil, if people do an engine oil "flush" with fresh oil, and then drain and then put in the "final oil"?? I know oil sits in the sump and can accumulate residue, shavings etc. So was thinking a "flush" with new oil, run engine to get warm, jack up front, -- then draining and put in final oil. I am using "winter" oil of synthetic Kohler 10w30 with zinc additive. 4 Share this post Link to post Share on other sites
lynnmor 7,471 #2 Posted January 7, 2023 5 minutes ago, Brockport Bill said: Was wondering if when people obtain engines with old "black" oil, if people do an engine oil "flush" with fresh oil, and then drain and then put in the "final oil"?? I know oil sits in the sump and can accumulate residue, shavings etc. So was thinking a "flush" with new oil, run engine to get warm, jack up front, -- then draining and put in final oil. I am using "winter" oil of synthetic Kohler 10w30 with zinc additive. I have flushed dirty engines with cheap oil. The Kohler oil already contains the proper amount of zinc, adding more can make it acidic. 2 Share this post Link to post Share on other sites
Achto 28,166 #3 Posted January 7, 2023 14 minutes ago, Brockport Bill said: So was thinking a "flush" with new oil, run engine to get warm, jack up front, -- then draining and put in final oil. This sure will not hurt any thing. 3 Share this post Link to post Share on other sites
Brockport Bill 1,773 #4 Posted January 7, 2023 18 minutes ago, lynnmor said: I have flushed dirty engines with cheap oil. The Kohler oil already contains the proper amount of zinc, adding more can make it acidic. i am not adding zinc -- the Kohler syn 10w30 comes with zinc additive 4 Share this post Link to post Share on other sites
953 nut 56,715 #5 Posted January 8, 2023 Sounds like a good idea to me. The first thing I do with a newly acquired is give it an oil change. Never had one that had black oil but if I did a second oil change would be done. 4 Share this post Link to post Share on other sites
ebinmaine 69,683 #6 Posted January 8, 2023 Another vote for change it, run it, change it again. 5 Share this post Link to post Share on other sites
lynnmor 7,471 #7 Posted January 8, 2023 34 minutes ago, Brockport Bill said: i am not adding zinc -- the Kohler syn 10w30 comes with zinc additive All motor oils have zinc, some more than others. When you said additive it appears as thou you were adding something. Share this post Link to post Share on other sites
Brockport Bill 1,773 #8 Posted January 8, 2023 56 minutes ago, lynnmor said: I have flushed dirty engines with cheap oil. The Kohler oil already contains the proper amount of zinc, adding more can make it acidic. here is the "zinc" oil i located recently - a prior thread from few weeks ago i read here provided excellent discussion about the zinc - - so after much searching i located the Kohler label oil -- i ordered 30w, and 10w30 - should provide the benefit to older Kohlers as has been discussed here on RSq. 1 Share this post Link to post Share on other sites
Brockport Bill 1,773 #9 Posted January 8, 2023 4 minutes ago, lynnmor said: All motor oils have zinc, some more than others. When you said additive it appears as thou you were adding something. i did lots of google work a few weeks ago to find the actual measurments of zinc -- and this was a formula higher than typical - - thanks for the insights 1 Share this post Link to post Share on other sites
lynnmor 7,471 #10 Posted January 8, 2023 3 minutes ago, Brockport Bill said: here is the "zinc" oil i located recently - a prior thread from few weeks ago i read here provided excellent discussion about the zinc - - so after much searching i located the Kohler label oil -- i ordered 30w, and 10w30 - should provide the benefit to older Kohlers as has been discussed here on RSq. Good deal, I have been using the same for a few years now. I did notice that the price went way up and there are considerable differences between suppliers. @ebinmaine found another brand that was fairly priced, maybe he can chime in about current pricing, brand and stores. I wouldn't doubt that it is the same oil with a different label. 3 Share this post Link to post Share on other sites
ebinmaine 69,683 #11 Posted January 8, 2023 12 minutes ago, lynnmor said: Good deal, I have been using the same for a few years now. I did notice that the price went way up and there are considerable differences between suppliers. @ebinmaine found another brand that was fairly priced, maybe he can chime in about current pricing, brand and stores. I wouldn't doubt that it is the same oil with a different label. Lyn the oil I found is called Kinetix. It was at the dealer where I bought the new commercial grade Ariens snowblower a few years ago. Used and recommended by them. Their price wasn't too bad and I found it available online by the case lot delivered to my house. We use either straight 30 or 10W30 depending on machine needs and season/temperature. 3 1 Share this post Link to post Share on other sites
Brockport Bill 1,773 #12 Posted January 8, 2023 for the first time this season my plow tractors will be stored in outside temps -- i have always plowed since 1989 with my 312-8 - kept in 55 degree garage -- but now i plan to use 2 C175 hydros with a plow and another c175 with a blower - - both stored in outside shed -- so winter here in Hudson River Valley, NY usually overnight in teens and 20s............can go to single digits, but rarely below Zero so i will use the 10w30 Kohler with their zinc additive for outside storage tractors - then switch to the straight 30w this spring/summer. -----------------the prices for the Kohler with zinc in it ranged from 9-13 dollars when i searched 2 weeks ago - much dependent on quantity purchased -- i had seen prior post couple weeks ago from Eric or someone about the Kinetix -- and i also have seen the Amsoil apparently has a higher zinc. thanks for info !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 2 Share this post Link to post Share on other sites
Wild Bill 633 862 #13 Posted January 8, 2023 (edited) New rebuild, Shell Rotella 30 wt, until hot, drop oil refill and after 50 hours of break in with conventional oil. https://amsoilcontent.com/ams/lit/databulletins/g2217.pdf Oil change every fall irregardless of hours. Edited January 9, 2023 by Wild Bill 633 2 Share this post Link to post Share on other sites
SylvanLakeWH 26,556 #14 Posted January 8, 2023 2 hours ago, Wild Bill 633 said: Oil change every fall irregardless of hours Never more than 15-20 hours on my C 105. always drain when fully hot... front end up as high as can... Rotella 30 wt. More than enough "flush"... 2 Share this post Link to post Share on other sites
Brockport Bill 1,773 #15 Posted January 9, 2023 14 hours ago, SylvanLakeWH said: Never more than 15-20 hours on my C 105. always drain when fully hot... front end up as high as can... Rotella 30 wt. More than enough "flush"... how long to get engine or hydro oil "fully hot" -- 5-10 minutes run time??? Should oil be hot/warm to the touch when touching it when it drains out? 1 Share this post Link to post Share on other sites
lynnmor 7,471 #16 Posted January 9, 2023 2 hours ago, Brockport Bill said: how long to get engine or hydro oil "fully hot" -- 5-10 minutes run time??? Should oil be hot/warm to the touch when touching it when it drains out? I would say 15 minutes for the engine and much longer for the hydro. I think that the most important thing is to have your tools and drain pan at the ready in order to drain immediately after shut down so the crud doesn't settle. 1 Share this post Link to post Share on other sites
SylvanLakeWH 26,556 #17 Posted January 9, 2023 (I don't know about hydro, I only do manual) 1 Share this post Link to post Share on other sites
953 nut 56,715 #18 Posted January 9, 2023 23 hours ago, Wild Bill 633 said: after 50 hours of break in Did you mean five hours? Norm al oil change interval is twenty five hours. 1 Share this post Link to post Share on other sites
Wild Bill 633 862 #19 Posted January 9, 2023 (edited) 34 minutes ago, 953 nut said: Did you mean five hours? Norm al oil change interval is twenty five hours. I edit my post above. On a new motor or fresh rebuild, I run conventional oil for 50 hours, with multiple oil changes, to break in the rings before switching to fully synthetic. Also, one benefit of having many tractors is, none of them see 25 hours in a year. The man with the most spark plugs wins! Edited January 9, 2023 by Wild Bill 633 2 Share this post Link to post Share on other sites
Brockport Bill 1,773 #20 Posted January 9, 2023 4 hours ago, Wild Bill 633 said: I edit my post above. On a new motor or fresh rebuild, I run conventional oil for 50 hours, with multiple oil changes, to break in the rings before switching to fully synthetic. Also, one benefit of having many tractors is, none of them see 25 hours in a year. The man with the most spark plugs wins! curiosity question --- does it make a difference if "conventional oil" is mixed in an engine with synthetic oil --- i assume not since they sell "syn blend" ??????? 2 Share this post Link to post Share on other sites
peter lena 8,968 #21 Posted January 9, 2023 @Brockport Bill do you use your pto lever drive , even without driving anything during this heat up ? think the slight added side thrust adds to the oil usage . another thing I make sure of is a thorough heat up of the oil , reading of the condensation issue that appears to be common should be addressed , been using 5-30 over winters the oil temp changeover is faster , also reducing cold start smoking . my oils start changing color about 20 hrs , keep a regular look see on everything . using rislone zink to every oil change , has made a very solid gain to my engines running easier , and smoother . just stay after anything , always snoopin around , for another change , pete 2 1 Share this post Link to post Share on other sites
peter lena 8,968 #22 Posted January 9, 2023 @johnnymag3 brought a few engines back from the neglect zone , usually gently run them in on a separate gallon of heavily treated fuel . after a carb bowl drop / clean . heat them up for a more thorough oil drain , adding rislone zink and fresh oil makes a very noticeable smooth sounding engine and running ease . done this enough to make this my regular oil change lubrication set up . have this on my 3 kohler magnums , very happy with it , running ease is like night and day . think its the way to go . using a measuring cup for zink , no condensation , no crud on the dip stick . STA -BIL in all my fuel . it just works and gives me no problems , think I, ve found the right combo . pete 2 Share this post Link to post Share on other sites
johnnymag3 2,558 #23 Posted January 9, 2023 Pete.... I am just like you..over the top...every aspect....through and pure... The only way.,trouble free, and always at the ready....complete success, not a bit less !!! 1 1 Share this post Link to post Share on other sites
Brockport Bill 1,773 #24 Posted January 10, 2023 4 hours ago, peter lena said: @johnnymag3 brought a few engines back from the neglect zone , usually gently run them in on a separate gallon of heavily treated fuel . after a carb bowl drop / clean . heat them up for a more thorough oil drain , adding rislone zink and fresh oil makes a very noticeable smooth sounding engine and running ease . done this enough to make this my regular oil change lubrication set up . have this on my 3 kohler magnums , very happy with it , running ease is like night and day . think its the way to go . using a measuring cup for zink , no condensation , no crud on the dip stick . STA -BIL in all my fuel . it just works and gives me no problems , think I, ve found the right combo . pete Peter --- when you say .... "makes a very noticeable smooth sounding engine and running ease" .? What should i look for, or listen for ??? Is it just a quieter engine - - or less sputter, less vibration, or is it smoother idle - - my ear probably isn't that well trained to hear the nuances of an engine - - Any tips are appreciated. I know this sounds weird, or wishful thinking based on just reading your posting .... but actually after i changed the engine oil to the 10w30 syn that has the zinc additive in it - ( plus new fresh 10w30 hydro oil in trans) i actually imagined the engine/tractorto be quieter and smoother - - but i then convinced myself it was my imagination and wishful thinking... maybe not based on your insights??????????? 1 Share this post Link to post Share on other sites
lynnmor 7,471 #25 Posted January 10, 2023 Did you check the amount of zinc in other oils? I said before that they all have it, just some has more than others. ZDDP is in motor oil to reduce wear, I can’t imagine that there are any noticeable changes in the short run. 1 Share this post Link to post Share on other sites
