Joker72 64 #1 Posted January 6, 2023 Is there any manuals available that would show me how to change the transaxle/hydro fluid on my new 75 C160 Automatic? 1 Share this post Link to post Share on other sites
daveoman1966 3,752 #2 Posted January 6, 2023 Remove the HEX plug on the trans case bottom. Replace it...change the filter, then use this no-spill method to refill... Don't over-fill it as the fluid will foam up resulting in poor performance. Run it for a little while, then recheck fluid lever...DO NOT OVERFILL. 3 2 2 Share this post Link to post Share on other sites
Achto 27,594 #3 Posted January 6, 2023 11 minutes ago, Joker72 said: transaxle/hydro fluid on my new 75 C160 Automatic? Note - if the fluid that you remove is red then use ATF to refill it. If the fluid that you remove is tan, use 10w30 to refill it. And as with manual tranny's jack the front of the tractor up as high as you safely can to get the fluid to drain over the hump. 4 Share this post Link to post Share on other sites
ebinmaine 67,553 #4 Posted January 6, 2023 13 minutes ago, Joker72 said: transaxle/hydro fluid Should be standard issue 10w30 engine oil in there. General consensus on the filter is use a Wheelhorse/Toro brand or get a wix 51410 which is a NAPA Gold 1410. I'd recommend installing a magnetic drain plug. 8 minutes ago, daveoman1966 said: then use this no-spill method to refill Dave AWESOME write up and fast. Neat idea on the funnel/straw. 2 1 Share this post Link to post Share on other sites
Joker72 64 #5 Posted January 6, 2023 (edited) This is the part that takes 5.5 quarts, correct? Edited January 6, 2023 by Joker72 1 Share this post Link to post Share on other sites
Blasterdad 2,692 #6 Posted January 6, 2023 The manual says 6. I would put in 5.5 & check it as to not overfill it. Use the straw trick that @daveoman1966 posted, otherwise you will make a mess if you dont... 1 Share this post Link to post Share on other sites
Blasterdad 2,692 #7 Posted January 6, 2023 4 minutes ago, Blasterdad said: I would put in 5.5 & check it as to not overfill it. That is assuming you're changing the filter too. Some oil will always stay in the lift cylinder & lines, you can put 5 in it and run it to work it through the system, then check it to top it up. 5 Share this post Link to post Share on other sites
