tmix61
D200
tmix61
Okay guys a little help this is the VIN on my tractor what does it all mean? And what kind of rear end is in it I have a problem with it where would I find manual to take it apart. From a couple of people that looked at the crack something got wedged between the gear and the case and pushed it out might be a bolt that broke off and got caught between the rain gear and I pushed it open.
Edited by tmix61
Added another picture
  • Sad 2
The Freightliner Guy
@stevasaurus what do you think youre the vin guru lol
tmix61
Not sure what you mean it's been years since I've been on this site not sure how to get around to find the right year for the tractor with this vin
Blasterdad
1977 D-200
Kohler K532S-53105-A 20 hp
Sundstrand 90-1137 transmission
  • Thanks 1
Blasterdad
Handy to Bookmark. :thumbs:
oliver2-44
@tmix61 This should be the manual for your transmission
Transmission Hydro Sundstrand SM #492-4206.pdf
Also if you search for 90-1137 you will find 50 threads referencing that transmission. Sort through them and there are some good rebuild ones
  • Thanks 1
Horse Newbie
@tmix61 ,
I think what @The Freightliner Guy was trying to say was “What do you think @stevasaurus ? You’re the vin number guru .
Edited by Horse Newbie
tmix61
8 minutes ago, Horse Newbie said:
@tmix61 ,
I think what @The Freightliner Guy was trying to say was “What do you think @stevasaurus , You’re the vin number guru ?”
Oh I wasn't quite sure what he meant thanks for clearing that up
daveoman1966
I have prepared a REBUILD .pdf file for overhaul of the 90-1137 Sundstrand hydro unit in the D-200.  The .pdf file is SUNDSTRAND Piston-Piston PUMP & MOTOR Refurb.pdfattached here.
I can also replace the BROKEN trans housing....$60 + shipping from my zip 16433 to you...
 There really isn't very much inside of the Auto trans gearbox...  faily easy to swap out.  Here is a pic of the Auto trans gears:
  • Excellent 1
tmix61
I'm only taking the rear end apart where the crack is would you happen to have more pictures of the inside of the rear end and a list of seals and gaskets thank you very much for the photos and your time I sure do appreciate it thank you TMIX
daveoman1966
This 'CRACK' is beyond repair...unless you can weld cast iron.  (WYSIWYG)What you see above is the extent of the internal gears.  I can send you a replacement trans case side...$60 + ship.
 The differential comes apart, of course.  The LEFT two gears just slide off/on the shaft.  The center gear is a welded/pressed assembly and doesn't come apart.  This all makes it very easy to swap over gears..
  • Excellent 1
tmix61
Would you happen to know the grease seals number for the axles and the gasket to put the transmission back together or where would I pick them up thank you very much for the help I will let you know if I need that side of the case
daveoman1966
Here is my Excel SS on the 'D' series Sundstrand Pump, Motor, and Manifold parts schematic and part #s.
Looking for the SS on the gearbox...
D SERIES ALL LIST.xlsx
daveoman1966
Gasket kit from L J Fluid power.  Google it and order for Sundstrand model 90-1173.  It'll look something like this:
tmix61
Sorry for being so dumb but don't I just need the transmission gasket where I split the cases?
tmix61
Oh I think I understand the axle seals will be in that kit and so will the old rings for the hydraulic where it mounts to the top of the rear end am I right? Thank you for your time
pacer
A reminder --- those 4 nuts exposed on the big gear in the pic are the ones that caused your problem, yours were probably 5/16 on about a 3-3 1/2" bolt and one of the nuts broke off. The ones in the pic appear to have the 3/8" pinch nuts/bolts. You'll want to either bore yours out to the 3/8 or get a gear that has them.
The big gasket is probably still NLA (no longer available)
That $60 case @daveoman1966 is offering is a good price, and he dont sell anything that isnt in excellent condition.
Edited by pacer
  • Thanks 1
stevasaurus
@daveoman1966 is the guru on the hydros.  I would listen to him on this case.  BTW, I know nothing about "D's".  :notworthy:
  • Thanks 1
tmix61
Does that kit give me all the o-rings for the hydraulic tubes on top of the transmission and the wheel seals?
Edited by tmix61
daveoman1966
I don't think the kit includes the 2 axle seals.  Seals are OEM #6449...find them on Ebay.
The OEM Trans Gasket is # 5999.  Ebay again...MAYBE.
You may find this gasket on-line, but not sure...may be outdated.  If so, one can be made using either case side as a template.
Get the GASKET 5999 and SEALS 6449 Here:  https://wheelhorsepartsandmore.com/product/wheel-horse-5999-transmission-gasket/
Edited by daveoman1966
