RED-Z06
I guess if you're going to blow up a Kohler..
RED-Z06
30 minutes ago, 953 nut said:
If it won't start without a squirt of whatever it is time to diagnose the problem and correct it.     :twocents-02cents:
Shot of fuel is a quick and dirty field diagnostic.  If it kicks on it, its got spark, compression, and both ignition and valves are in time...needs fuel.  If it doesn't hit on it..did it pop out either hole?  If not...probably missing spark.
