csvt99
K181 Swap
csvt99
I am finally getting around to swapping out the 8 hp K181 on my 877 and decided to start a new thread about it. I just haven't had the time to document everything, but am figuring I might need some help from all of you to get everything back up and running. Fortunately, my dad grew up with wheel horses and is able to help me some.
Here is a link to a previous thread of how I got here. I picked up the replacement motor from Squonk this summer. https://www.wheelhorseforum.com/topic/97285-k181-rebuild-or-replace/?tab=comments#comment-1041647
ebinmaine
Excellent.
I'll be looking forward to seeing your progress and the victory lap when it's running.
Take LOTS of pictures and post them here. We like to see them and you'll have them as a reference point.
If you mark the wires with tape there will be no questions as to where they went.
8ntruck
Good luck with the rebuild.
You might want to consider becoming a Red Square member.  Something like $25 per year.  One of the benefits is no limit on the number of pictures you can post.
csvt99
The only issue I'm having so far is hooking up the battery. I had taken it off to put on the charger before I got started on the motor, so I don't have pictures. I only have two wires that I can find that are to be hooked to the battery. One larger one and one smaller green wire that connects to the regulator. It seems these both would go to the positive terminal, but that leaves nothing for the ground. Any suggestions? I I might have to dig around some more to make sure there isn't one hiding somewhere.
squonk
Ground wire from battery connects to the engine block anywhere (preferred) or to the frame. My 857 goes to the engine / belt guard bolt above the pulley.
Edited by squonk
csvt99
Ah hah! Thanks so much. I checked the corner of my garage where I stashed the pulley guard and sure enough the ground strap was laying with the cover. Now I just have to get the battery connected, install the new nipple and muffler, and hope she starts!
csvt99
So I finally got everything set up, and last Saturday was nice so I fired her up and everything went well. However, I now have a strange problem. It is leaking gas through the carburetor somewhere/ somehow. It was pooling in the air cleaner cover, and the air cleaner was soaked with gas. I removed those pieces and set them outside to evaporate, and cleaned the remaining gas in the carb with a shop towel. I then stuffed a clean paper towel in the carb opening, and 24 hours later the towel is saturated in gas. But I can't see it leaking anywhere in the carb.
Any ideas as to what is going on? I guess it is time to turn off the gas...
Thanks!
wallfish
That's a typical condition of the float valve leaking.
ebinmaine
I'll second that.
Time for a carb clean out.
csvt99
I cleaned the carb when I switched it to the new motor. Is it possible I messed something up in the process?
wallfish
The float valve is leaking so that's where the gas is coming from if it's 100% dry on the outside of the carb.
Cleaning doesn't necessarily mean you messed something up but the valve isn't closing tight for some reason so it's leaking. You could try pulling it out and cleaning it. Or,  Order a rebuilt kit or just a float valve if all the gaskets are good
ineedanother
Not necessarily. If the carb is clean, the float and needle may just not playing nice or the needle might be rotated to a position it's not happy with. I would drop the bowl and work the float up and down a bit and try again before going much further. If you see crap in the bowl already you'll likely need to do a clean-out of your tank and lines but for some reason it sounds like your float isn't stopping fuel supply.
csvt99
Ok thanks. I did already clean out the tank and lines when I did the swap, but you never know, so I will give that a try.
ineedanother
Another thought, a lot of carbs will not prevent the float from being reinstalled upside down. They reassemble just fine but the float will not raise enough to completely seal off fuel flow. Just a thought.
pfrederi
Make sure there is no gas in the float body itself...
wallfish
:text-yeahthat:
Shake it. If you hear, feel gas inside it won't float as high and therefore not shut off the gas flow.
Adjusting the float may help too if it wasn't already done or checked. You will need to remove the entire carb, not just the bowl, to adjust the float because you need to turn it upside down. If you don't have one, search the files section for the manual. It will show the spec and how to adjust the float properly.
csvt99
It was fine previously on the other engine. All I did was remove it, spray it with carb cleaner and put it on the new motor. I guess I may have disturbed something internally while cleaning, or perhaps it stuck fast because it had been sitting for a year or so.
ebinmaine
Could be either one. No worries.
What exactly did you do as far as cleaning the fuel system?
New hoses?
Non-ethanol fuel?
Clean out the fuel pump?
Highly likely you could have dislodged a small piece of schmutz and it's stuck holding the float open.
squonk
If the needle is old it just may have been time for it to take a dump.
csvt99
I'm thinking I might just need to replace the carb instead of messing with it. I cleaned the gas tank, blew out the lines, replaced the inline fuel filter, and added fresh non ethanol fuel. I never use ethanol in my small gas equipment. Thanks.
squonk
Do not throw out the old one. You don't find them every day. If you find you don't need /want it I'll take it. :)
csvt99
Ok, I'll see what happens. I don't throw anything out and everyone yells at me for it.
  • Haha 1
Handy Don
No one on this forum will join that chorus!
csvt99
Somehow I believe that. If we did a genetic study of everyone on this forum I'm guessing many of us would have that gene. It just feels so good to use something today that you saved 15 years ago. This is how my ancestors survived the depression.
  • Heart 1
csvt99
I removed the carb and the bowl. The bowl did still have some gas in it. Any thoughts? Not quite sure where to start. Thanks!
