Bob Nakon
Engine rebuild
Bob Nakon
Hi guys,
   It has been quite a while since I have logged in. Every once in a while life kicks you in the a** and it takes a while to get up again. I am looking for a machine shop / engine rebuilder in my area. I live about 19 miles NW of Ann Arbor Michigan. I have 2 that need rebuilding, 12 hp in my C120 and 16 hp from my C160. That is what I need done, but since I have no Idea what a rebuild costs it is possible I may do them one at a time and stretch out the time in between. Both are K series Kohler engines of course. I wonder if they can be left in the tractor?  I watched a friend rebuild his engine and he left it in the tractor. Just wondering. Anyway, it's nice to be back and if you know of a good rebuilder I would appreciate hearing from you.
Thanks,  Bob
SylvanLakeWH
:text-welcomeconfetti: back!
I looked around 7 years ago and didn't find any near us... have not looked lately...
@Pullstart do you know of any???
Pullstart
Yes, :text-welcomeconfetti: back!  My local NAPA distribution hub has a good machine shop, and last time I used them had very fair prices.  It might be worth checking into locally.  The particular location I speak of is near the Grand Rapids airport… at 36th and Patterson.
Pullstart
I’m not sure what kind of tractor this was, but it’s not that challenging to pull a Kohler out of a Wheel Horse.  The oil pan is an integral part of the engine block and is sitting on the frame, or a shaker mount at that, and it needs to be removed.  No on frame rebuilds here…
  • Excellent 2
953 nut
About the only thing you can do while the engine is in the tractor is an ignition tune up. The base/oil-pan needs to come off to get at the rod bolts. You can save some money by doing the disassembly work yourself. Depending on your skill set and the tools you have. This thread will give you some idea of what needs to be done for a proper engine rebuild.
pacer
Your friend probably had one of the "Farm" type tractors - cubs, ford, massey, etc  lot of those can do an in place ... 'rebuild' (cant turn the crankshaft)
Aside from finding a shop to do a rebuild, which I dont have a place anywhere close either, you very possibly could get by with a 're-ring' type rebuild. (these Kohlers are known to be tough) consisting of new rings/piston/rod, clean up valves, gaskets, etc. Get on your friends and start asking if one of them might could help you assess what you need, The removal of the engine and getting into it is really not difficult and would have to be done anyway you go. Check out the post @953 nut shows and you might get a feel for what you need.
We have on the forum a member that will do the the rebuild - complete - in Virginia @richmondred01 (check in the 'for sale' section) Its not cheap but you'll have a 'like new' engine when done.
  • Excellent 3
moe1965
Unfortunately it seems to be a thing of the past to rebuild a small engine it's a throw away world . I had a hard time as well here in Ohio but it found one.  Check with a few motorcycle or places that sell four wheelers and dirt bikes in your area. Those engines are always in need of repair and if they can't do it I'm sure they use someone does.  Good luck
richmondred01
You can’t rebuild an engine without it being removed from the tractor.
To properly rebuild them they need to go down to the bare block and everything mic to spec.
Rebuilding an engine on the tractor is as ridiculous as getting a kidney transplant with your clothes on.
Edited by richmondred01
  • Haha 2
kpinnc
I'm using that one! :D
...and 100% agreed as well.
Most any engine shop can prep a Kohler block for you. Bore (if needed), hone, face valve seats and guides. Prices will vary of course.
Once you have that done- if you can read a manual and have torque wrenches and feeler guages, you're all set. Kohler engines are foolproof so long as you do what the service manual says. Don't cut corners and you'll get another 40-50 years out of that engine.
And assembly lube is your friend. You can't use too much.
Edited by kpinnc
  • Haha 1
oliver2-44
Older Wisconsin engines had a removable side plate where you could access the rod for removal. They also have a removable cylinder jug for boring and you can pull the crank out the side.
953 nut
12 hours ago, Wild Bill 633 said:
:confusion-confused:   Not sure what they would charge but something tells me it may be a bit higher than a new Kohler engine would be.  :confusion-shrug:
lynnmor
My thought is that they would hang up the phone because they couldn't stop laughing.
  • Haha 1
Bob Nakon
Thanks for the responses guys. I guess I'll keep looking in my area and I'll call the local auto parts (no NAPA here) and maybe they can steer me to someone.
Happy New Year to all.
