farmboy 0 #1 Posted July 20, 2009 When I let the clutch out no matter how hard or easy , the front tires leave the ground is there an adjustment I can make? Share this post Link to post Share on other sites
Duff 206 #2 Posted July 20, 2009 Hi, farmboy, and ! What model tractor are we talking here? Might help us to narrow down the problem a little for you! These beasts are torque monsters, so it's no surprise it can raise the front wheels. As to what the clutch is doing, we need a little more info..... Glad to have you aboard! Duff :thumbs2: Share this post Link to post Share on other sites
WheelHorse_of_course 99 #3 Posted July 20, 2009 :thumbs: I first learned to drive on a Suburban 550. The way I learned it learning to start without a wheely is just a matter of "lernin how to do it right". Best of luck! :thumbs2: Share this post Link to post Share on other sites
WHDan 0 #4 Posted July 23, 2009 According to my local Wheelhorse repair shop, a worn drive pully on the engine can also cause grabbing of the drive belt. Apparently, if the sides of the pully are worn, the belt can bottom-out in the pully reducing the ability of the belt to apply power to the transaxle gradually as the belt engages and tightens. Share this post Link to post Share on other sites
DrabHorse 2 #5 Posted July 23, 2009 Also, I don't know if this was brought up before, but there are different kinds of belts. Some are used where the drive would have a manually tightened tensioner or otherwise non adjustable. Those type belts may not work as well on applications where you need the belt to slip some for clutch engagements. Share this post Link to post Share on other sites
Red Iron 1 #6 Posted July 26, 2009 :thumbs2: How fast are you running engine when engaging clutch? Hello to farmboy and WHDan Share this post Link to post Share on other sites
Rollerman 290 #8 Posted July 26, 2009 Farmboy without knowing what model of tractor you have, but with the problems your describeing. Look at your drive belt, if it looks worn at all replace it with a new OEM peice. There is no adjustment on the drive belt. If it's worn & streched though it can be difficult to ease out. They will just grab & go. It would be a good idea to check the condition of the drive pullies, idler pulley & tensioner spring too. Share this post Link to post Share on other sites
wheel horse 1045 2 #9 Posted July 26, 2009 or maybe the belt is to short,i put a belt on that was to short on an 854 and it would jump every time i let out the clutch Share this post Link to post Share on other sites
