DNoland
Where to buy tires
DNoland
I’m looking to get a set of 23x9x12r for my 312-8 and am having trouble finding them anyone know where to get them for a affordable price?
Sparky
Your tires are probably 23-9.50-12. Maybe you’re searching for 9.00 by mistake?
:WRS:
ebinmaine
:text-welcomeconfetti:
I've been using Simple Tire or Wally world.
Avoid the Deestone brand because they tend to be very small.
CCW
Not sure if you Town Fair Tire in your area.  They had the same size as my original rear 312-8's.  Bought and mounted for less than $150.  In my mind having someone else mount them is a no brainer.
Horse Newbie
I use 23x10.50-12’s on the rear of my 1994 520H and 1984 Work Horse GT-1600. Hi-Run ags on the Work Horse and Turfs on the 520H…
Edited by Horse Newbie
  • Like 6
953 nut
:WRS:
That is a very nice looking 312-8 you have there. I have used TiresShipped2You and was pleased with the service and quick shipping. Carlisle tires are the best brand in my opinion.
https://tiresshipped2you.com/collections/carlisle-tires?filters=rim_diameter:12&page=1
SylvanLakeWH
The guys input above has it covered...
RandyLittrell
23x8.50-12's will work as well, here is some on my 310-8.
  • Excellent 2
Redav72
I feel like we need some sort of tire fashion show.  Various shots of aftermarket tires with sizes and part numbers so that those of us a little nervous about plunking down serious money on new shoes can get an idea of what works and what doesn't.  For my part I'm interested in seeing some skid steer tires on a mid-70s rear hub.
Snoopy11
20 hours ago, ebinmaine said:
Simple Tire
:text-yeahthat:
Depending on the tread that you want, also research SUNF.
10% off sale going now.
https://www.sunf.com
Don
Edited by Snoopy11
ebinmaine
13 minutes ago, Redav72 said:
skid steer tires
If you're interested in the industry standard R4 tires...
Be very cautious about your expectations.
We use both R1 and R4 at work on forklifts.
I'm..... Not impressed... With R4 for any off-road traction.
  • Like 4
SylvanLakeWH
@Pullstart has one... pic Kevin?
Lee1977
I went 24 x 950 x12 Carlise Turf Masters on my 1989 520 it has the same width wheels  ( 7" ) as your 312  and 18 x 650 x 8 on the front.
The Turf Masters have around three times more deap tread then the Turf Savers. The 24 x 950 are only about a 1/2" narror then the  23 x 1050 I have on my C-120'
I got mine a couple years back and tires are a lot higher then thay were then.  I got mine from Midwest Traction, I suggest you check every where on the enternet for the best price.
Sparky
@DNoland … are you looking for a new tire with the same or similar tread pattern, or AG style tires? Or something in- between?
  I have these on two of my rigs and anytime someone asks about tires I use the opportunity to brag about em!
  Carlisle All-Trails are the brand and type. 23x10.5 on the gray tractor and 23x8.00 on the red tractor.
  • Like 5
  • Heart 1
ebinmaine
28 minutes ago, Sparky said:
Carlisle All-Trails
If'n I had a hankerin' to buy some new tractor sneakers right now I'd be after these.
I REALLY like the fact that the traction is equal both forward and reverse.
The aggressive "Z" pattern is well known for excellent traction over many brands and a long proven history.
Lee1977
I like the All-Trails too. I have a set on my modified 312-8. Mine don't look as good as Sparky's 1050 but I went for height. mine are All-Trails II 25 x 900 x 12. With a round tread only the three center treads touch the grade on hard ground.
Sparky
33 minutes ago, Lee1977 said:
I like the All-Trails too. I have a set on my modified 312-8. I went for height. mine are All-Trails II 25 x 900 x 12. With a round tread only the three center treads touch the grade on hard ground.
I wonder if you reduced the air pressure that you might get more rubber on the road.
  • Like 5
ebinmaine
That would work unless the tires are a stiffer sidewall and main core.
Digger 66
Greater Cleveland Wholesale
No Problem at all with the Deestone V-Bars or Tri-Ribs .
Edited by Digger 66
Lee1977
No these were designed for UTV's, hard compound to last for running on hard pavement, dirt and gravel in an industral setting. I haven't had any trouble with traction.They were made rounded, I knew that when I ordered them.
I just think your 1050 look better. They work great for what I use this tractor for. only reason to let air out would be lose sand  and we don't have any, only hard red clay.
