857lover 291 #1 Posted December 26, 2022 so i have a d250 and i’ve been looking for a while for a resivour for it because mine seems to be missing one and when it’s running it just pushes the coolant out the top of the radiator so i was just looking to see if anyone could help me find one thanks and merry christmas in advance! Share this post Link to post Share on other sites
Snoopy11 5,717 #2 Posted December 26, 2022 So.... you are needing a coolant expansion tank? What about something like this to retrofit...? I put one of these on a SCAG... worked great... Don 1 1 Share this post Link to post Share on other sites
953 nut 57,932 #3 Posted December 26, 2022 Go to your local automotive parts recycling center (Junk yard). There will be a wide variety to select from, you may even luck out and find one from a Renault Dolphin. 1 Share this post Link to post Share on other sites
squonk 42,554 #4 Posted December 26, 2022 30 minutes ago, 953 nut said: Go to your local automotive parts recycling center (Junk yard). There will be a wide variety to select from, you may even luck out and find one from a Renault Dolphin. Any coolant jug from a Renault will probably be melted! Figure out how much room you got and find something of an econo box car. How much coolant is pushing out? If it's a lot you got bigger issues 3 1 Share this post Link to post Share on other sites
Pullstart 64,573 #5 Posted December 26, 2022 Could be a head gasket issue, instead of the need for an overflow. 2 Share this post Link to post Share on other sites
857lover 291 #6 Posted December 26, 2022 19 minutes ago, squonk said: Any coolant jug from a Renault will probably be melted! Figure out how much room you got and find something of an econo box car. How much coolant is pushing out? If it's a lot you got bigger issues no it’s dosent push any out until i’ve run the tractor for like 15-20 minutes and it’s just a little squirt here and there 2 Share this post Link to post Share on other sites
littleredrider 409 #7 Posted December 26, 2022 Mine looks like a fat mayonnaise jar. But any would work.... 2 Share this post Link to post Share on other sites
peter lena 9,088 #8 Posted December 26, 2022 @857lover , have an empty milk jug? just to put a stop to the mess , I also use front cut out milk jugs , for a parts holder on small areas , nuts/ bolts / fittings etc . never wait for the perfect part , you will be waiting a long time , thats only me , pete 1 Share this post Link to post Share on other sites
