Heatingman 971 #1 Posted December 24, 2022 Noticed when plowing in -10 degrees that the motor (kohler 8 hp) would want to die out if I did not have the choke part closed when the motor loaded up from releasing the clutch after a gear shift to change directions. Should I increase idle, adjust fuel jets, or just use the choke like I did? 1 Share this post Link to post Share on other sites
Red-Bovine 309 #2 Posted December 24, 2022 I would just keep the choke slightly pulled out. No need to mess up otherwise well set carb adjustments. 3 Share this post Link to post Share on other sites
lynnmor 7,305 #3 Posted December 24, 2022 If you have adjustable needles, by all means open them up a little at a time till it runs right. Do not use the choke, it can be just a guess that might make it seem to run OK at a particular speed and load. A choked carburetor cannot provide maximum power. If your adjustments don’t fix the problem, it’s time to clean the inside of the carburetor. 3 Share this post Link to post Share on other sites
rmaynard 15,454 #4 Posted December 24, 2022 Looks like there are two opinions here. Neither one is wrong. Both are right. That is my opinion. I have a Tecumseh on a snowblower. It always requires either a little choke or a needle adjustment. Both accomplish the same thing. It keeps the engine running and blowing snow. The next time that I start it, the same thing happens. In -10 degree weather, do whatever keeps you running. 9 Share this post Link to post Share on other sites
ebinmaine 67,466 #5 Posted December 24, 2022 D. All of the above. 2 Share this post Link to post Share on other sites
pfrederi 17,739 #6 Posted December 24, 2022 Just remember how far you turn the high speed needle so you can turn it back when it warms up 1 Share this post Link to post Share on other sites
rjg854 11,361 #7 Posted December 24, 2022 Generally speaking I usually have to adjust the carbs differently between summer and winter weather. Don't know why it makes a difference but it does for me anyway. 1 Share this post Link to post Share on other sites
ebinmaine 67,466 #8 Posted December 24, 2022 36 minutes ago, rjg854 said: Don't know why it makes a difference Colder air is a fair amount more dense. 2 Share this post Link to post Share on other sites
rjg854 11,361 #9 Posted December 25, 2022 And that may be my problem also Eric. 7 Share this post Link to post Share on other sites
ebinmaine 67,466 #10 Posted December 25, 2022 4 minutes ago, rjg854 said: And that may be my problem also Eric. Mine too brother man, now that ya bring it up. 1 2 Share this post Link to post Share on other sites
lynnmor 7,305 #11 Posted December 25, 2022 4 hours ago, rmaynard said: Looks like there are two opinions here. Neither one is wrong. Both are right. That is my opinion. I have a Tecumseh on a snowblower. It always requires either a little choke or a needle adjustment. Both accomplish the same thing. Partially closing the choke will limit the air flow thru the intake reducing engine power, adjusting the needle for the correct mixture will give the best performance. 4 Share this post Link to post Share on other sites
Heatingman 971 #12 Posted December 25, 2022 (edited) 29 minutes ago, lynnmor said: Partially closing the choke will limit the air flow thru the intake reducing engine power, adjusting the needle for the correct mixture will give the best performance. Assuming the same fuel is coming into play as during the summer, wouldn’t reducing the air volume to account for density maintain the same power as before? For what its worth, once slightly choked, the motor didn’t miss a beat. Plenty of power. I’ll try the main fuel adjustment and see how it does though. Edited December 25, 2022 by Heatingman 2 1 Share this post Link to post Share on other sites
ebinmaine 67,466 #13 Posted December 25, 2022 5 minutes ago, Heatingman said: wouldn’t reducing the air volume to account for density maintain the same power as before? By definition it corrects the air fuel ratio... But it reduces the possible air flow. 2 Share this post Link to post Share on other sites
Heatingman 971 #14 Posted December 25, 2022 15 minutes ago, ebinmaine said: By definition it corrects the air fuel ratio... But it reduces the possible air flow. Right. but if there is more air density, then it may be the same amount of air in the mix as when warm and choke removed. at -10 and 50% RH density is .088 lbs/ft3 at 70 and 50% RH density is .074 lbs/ft3 So if I needed more power I could up the fuel rate, bur if I Dont, then I could reduce the air. 3 1 Share this post Link to post Share on other sites
Pullstart 62,849 #15 Posted December 25, 2022 How often do you see yourself operating at -10? I totally agree with Lynn that you have a potential for more power, but I also agree that a little choke won’t hurt nothin’. Even the 8 hp has spare power… you likely won’t notice much difference. 4 Share this post Link to post Share on other sites
Heatingman 971 #16 Posted December 25, 2022 40 minutes ago, Pullstart said: How often do you see yourself operating at -10? I totally agree with Lynn that you have a potential for more power, but I also agree that a little choke won’t hurt nothin’. Even the 8 hp has spare power… you likely won’t notice much difference. Not often, hopefully. Guess it depends how cold this winter is. Usually only a couple days a year. And most often it doesn’t snow much when its that cold. It definitely had power to spare, probably quite a bit. When I think about how much work an actual horse can do, just one of them. If a horsepower in motor terms does truly equal that of a working horse, then I could probably plow with a 1/2 horse or less. 2 Share this post Link to post Share on other sites
Pullstart 62,849 #17 Posted December 25, 2022 You can do with 3.5 hp, I know for a fact! 2 Share this post Link to post Share on other sites
ebinmaine 67,466 #18 Posted December 25, 2022 10 minutes ago, Heatingman said: just one of them. If a horsepower in motor terms does truly equal that of a working horse Interesting search subject on the interwebs. It isn't equal. One healthy heavy draught horse can easily produce 15 HP or more for a short time. 2 1 1 Share this post Link to post Share on other sites
squonk 41,099 #19 Posted December 25, 2022 I'd run it with the choke. The little amount of time you're going to run it at minus 10 pales in comparison to the amount at 75° +++ . If this is a mowing machine that's when you need the torque and once it's dialed in for that, leave it. 3 Share this post Link to post Share on other sites
Horse Newbie 7,069 #20 Posted December 25, 2022 1 hour ago, Pullstart said: You can do with 3.5 hp, I know for a fact! What’s the hurry in the first video ?… you we’re flying ! 😆 1 1 Share this post Link to post Share on other sites
Pullstart 62,849 #21 Posted December 25, 2022 9 minutes ago, Horse Newbie said: What’s the hurry in the first video ?… you we’re flying ! 😆 1 Share this post Link to post Share on other sites
Horse Newbie 7,069 #22 Posted December 25, 2022 You are a Superman ! 1 1 Share this post Link to post Share on other sites
Heatingman 971 #23 Posted December 25, 2022 2 hours ago, Pullstart said: You can do with 3.5 hp, I know for a fact! motor didn’t even break a sweat. Really makes me wonder sometimes just how much my little 8HP could do. Betting mowing is a bit more power hungry. 2 1 Share this post Link to post Share on other sites
squonk 41,099 #24 Posted December 25, 2022 These little tractors will run out of traction way before engine power. 5 Share this post Link to post Share on other sites
