tractorhogg
D series tiller compatibility
tractorhogg
Can I use my 54" d series tiller on my 17 hp Kubota B7100 that runs 850 rpm on high speed? Thanks
pfrederi
D series PTOs were 2000 rpm.
Clockwise... many big tractors are ccw PTO do not know about Kubota
Tiller would be turning slowly
Edited by pfrederi
pacer
Also the D's 3 point is a category '0' where the kubota is cat '1', then there the compatibility of the drive shaft - Several reasons this wouldnt work.
tractorhogg
Thanks, I forgot about the drive shaft, but I have several non PTO driven Cat 0 implements I use on the Kubota, like the Brinly 3 point double disc, box blade, and plow, I just use bushings on the pins
tractorhogg
The Kubota is clockwise, yep half the speed, but then again a 540 Cat 1 tiller would be turning almost 1/4 of that speed and seems to till fine so I guess its better to go less than more...I wouldn't put a 540 tiller on a Wheel Horse, but the drive shaft alteration would be a expensive pain. Thanks
