peter lena 9,090 #1 Posted December 19, 2022 when installing fuel line , typically , the fuel filters , connections, barbs are same size , found using correct size spring clamps and square ended linemen's plyers make that easy, cut your line , slide on the clamp , back 3-4 " so its out of the way . regularly use a tiny amount of dielectric grease on the barb ends , makes the connection simple easy . once done squeeze plyer clips back to connection . no leaks easy , pete 6 1 Share this post Link to post Share on other sites
Snoopy11 5,717 #2 Posted December 19, 2022 Excellent write-up Pete. Spring clamps are better than regular hose clamps... mainly because typical worm screw hose clamps tension around the screw area while spring clamps tighten around the complete hose surface area. Performance radiator group taught me that. Don 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,199 #3 Posted December 19, 2022 19 minutes ago, Snoopy11 said: mainly because typical worm screw hose clamps tension around the screw area while spring clamps tighten around the complete hose surface area. But why wouldn’t equal pressure be put around the whole thing ? How does the clamp know where the screw is ? Has anyone done a lab test to verify ? 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #4 Posted December 19, 2022 (edited) 2 hours ago, Horse Newbie said: why wouldn’t equal pressure be put around the whole thing ? Not a 'perfect circle'. Almost... but not quite. On the smaller sizes, the problem becomes worse. They're 'generally' OK on big ole radiator hoses, but when you get down to the small sizes they can become problematic. I've taken to using the 'crimp type' past few years. Edited December 19, 2022 by Jeff-C175 4 Share this post Link to post Share on other sites
SylvanLakeWH 27,561 #5 Posted December 19, 2022 3 hours ago, peter lena said: found using correct size spring clamps and square ended linemen's plyers make that easy, 2 hours ago, Snoopy11 said: Spring clamps are better than regular hose clamps... 46 minutes ago, Jeff-C175 said: On the smaller sizes, the problem becomes worse. That's been my experience. 3 Share this post Link to post Share on other sites
Snoopy11 5,717 #6 Posted December 19, 2022 2 hours ago, Horse Newbie said: How does the clamp know where the screw is ? Has anyone done a lab test to verify ? With anything to do with plastic... the pressure exerted at the screw area can damage/deform plastics. I'll have time to actually watch this video later, but I think this video might clarify further... Maybe this one as well... Don 1 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #7 Posted December 19, 2022 28 minutes ago, Snoopy11 said: the pressure exerted Video brings up a point I had not considered... since it's a SPRING, it will adjust for temperature changes. Shrinkage in the cold, swellage in the heat. He said that the leak on his radiator hose didn't show up for a couple months after installing the worm drive clamp. I have heard that silicone hoses must NEVER use the worm drive clamps, ALWAYS the spring type. 2 Share this post Link to post Share on other sites
Snoopy11 5,717 #8 Posted December 19, 2022 @Jeff-C175... I have a 3 core radiator in the blue ranger... made out of aluminum. Regular worm style hose clamps will leak right off the bat... while spring style will seal right up... and if it's cold outside, even if it leaks a smidge at first upon initial hose install, it will adjust as soon as the hoses warm with the car running. I've never had an issue since installing stock type spring hose clamps. Same with fuel line... although I must admit, I have used worm style hose clamps on many a tractor fuel system... Don 2 Share this post Link to post Share on other sites
ri702bill 8,989 #9 Posted December 19, 2022 2 hours ago, Jeff-C175 said: I've taken to using the 'crimp type' past few years. One and done - not reusable, but they do work well.... 2 Share this post Link to post Share on other sites
peter lena 9,090 #10 Posted December 19, 2022 @Snoopy11 agree with the film , BTW the spring clamp I use on w/h fuel lines is the DARK GREEN size , its perfect on all my fuel lines , that dielectric grease just a tiny bit at fitting to hose , point makes a hose to stop very easy , then squeeze up the clamp , no leaks or issues . pete 3 1 Share this post Link to post Share on other sites
Horse Newbie 7,199 #11 Posted December 19, 2022 I’m sold !… learn something new everyday… 4 Share this post Link to post Share on other sites
peter lena 9,090 #12 Posted December 19, 2022 @Horse Newbie don't forget use SQUARE EDGE PLYER makes those clamps a non issue , wide end grips will not slip , pete 2 2 Share this post Link to post Share on other sites
Jeff-C175 7,203 #13 Posted December 20, 2022 1 hour ago, ri702bill said: One and done - not reusable, but they do work well.... Yes, fortunately they are cheap... buy big bagz ovem on Amazone for a few bucks. 2 1 Share this post Link to post Share on other sites
Snoopy11 5,717 #14 Posted December 20, 2022 6 minutes ago, Jeff-C175 said: Yes, fortunately they are cheap... buy big bagz ovem on Amazone for a few bucks. I really need to do that... I would only use about 3 out of the box before I lost the rest of them though... Small things disappear around the funny farm... Don 1 2 Share this post Link to post Share on other sites
lynnmor 7,567 #15 Posted December 20, 2022 1 hour ago, peter lena said: @Snoopy11 agree with the film , BTW the spring clamp I use on w/h fuel lines is the DARK GREEN size , its perfect on all my fuel lines , that dielectric grease just a tiny bit at fitting to hose , point makes a hose to stop very easy , then squeeze up the clamp , no leaks or issues . pete I’ve noticed in the past that you were using 5/16” barbed devices with 1/4” fuel line, that seems to be asking for trouble where the fuel line is bulging. Any comment? 1 Share this post Link to post Share on other sites
peter lena 9,090 #16 Posted December 20, 2022 @Snoopy11 actually its very close to size to size , bulging is very minimal , no leak's or stress cracks , using clear vinyl fuel rated line , have the same set up on my 3 horses , had more tinkering with the related linkage , fuel lines have been a non issue . had not really thought about the accuracy of fittings today , everything is china made , and sizes are not up to true specs . that linkage related detail , snugging up spring pull to linkage , super lubing related movement areas , has really made for not only quick starts , but almost immediate , zero choke use. very impressive , cold start in sheds , barely turns over / start , no smoke quickly settles down to a cold running speed . like the zone they are all in , regularly , start / run them , did a couple of miles with the c-85 the other day , cul de sac , ran like a bear , always tinkering around . pete 1 Share this post Link to post Share on other sites
