peter lena 8,461 #1 Posted December 15, 2022 often refer to aerosol lubrication on dry / faded / neglected paint , basically feeding / recovering that paint . let the oil soak do all the hard work, the related pictures , went thru a 2 day spray , soak wipe down , do it again phase. after 2 soaks , there was a definite color base , used a 6" palm buffer with cleaner wax , paint just came right out as you see it , typically just rub them down wit clean cloth , lubricant , thats what they look like . amazing to me how once recovered , how easy it is to keep it that way . also show a heim joint to plow blade lever rod, 3 7 Share this post Link to post Share on other sites
ri702bill 8,112 #2 Posted December 15, 2022 That's the one !! I did both ends on my 48" plow - very nice. 5 Share this post Link to post Share on other sites
peter lena 8,461 #3 Posted December 15, 2022 @ri702bill also note old type incandescent rough service bulb standing vertically under center frame mount , just gives off enough heat to make a quick start cold shed difference , pete 2 2 Share this post Link to post Share on other sites
SPINJIM 1,981 #4 Posted December 15, 2022 Which "spray lubricant" did you use, WD40 or other ? Nice clean up. 1 Share this post Link to post Share on other sites
8ntruck 6,874 #5 Posted December 15, 2022 (edited) WD-40 is more of a cleaner and water displacer than a lubricant. Yes, it does leave a bit of lube behind - but there are more effective lubes out there. For light duty linkages and such, I'm kind of partial to a drop of good 'ol 3 in 1. Edited December 15, 2022 by 8ntruck 5 Share this post Link to post Share on other sites
peter lena 8,461 #6 Posted December 15, 2022 @SPINJIM like Kroil , marvel mystery , also use 2 2-6 dielectric aerosol spray , won't harm plastic. once you start doing this easy , spray down , let sit a day , wipe down ,clean cloth , till dry . do it again next day , you start to see results , note , NEVER use a rough scrunge pad or sandpaper to remove paint , let the oil do the conversion , doing this in hot weather , with warmer metal , you can watch it change . also do your plow blade , that slick finish stops rust , and moves snow without effort . as said , once done , a simple oil lubricated cloth , freshens it right up , beads water like a duck , pete 3 1 Share this post Link to post Share on other sites
ebinmaine 66,582 #7 Posted May 8, 2023 On 12/15/2022 at 1:57 PM, peter lena said: freshens it right up , Pete, what's the "graphene" you mentioned at Zagray? Share this post Link to post Share on other sites
peter lena 8,461 #8 Posted May 9, 2023 @ebinmaine https://www.amazon.com/Black-Magic-120182SRP-Graphene-Detailer/dp/B09NMQ1T96/ref=asc_df_B09NMQ1T96?t got this at Walmart , end of isle sale , $ 7 , insane shine and smoothness , if you thought your paint was clean , wipe it down with this , your recent car pick up , would love it , go shinny , pete 1 Share this post Link to post Share on other sites
gwood 16 #9 Posted September 12, 2023 On 12/15/2022 at 1:34 PM, SPINJIM said: Which "spray lubricant" did you use, WD40 or other ? Nice clean up. WD40 Share this post Link to post Share on other sites
gwood 16 #10 Posted September 12, 2023 On 5/9/2023 at 8:24 AM, peter lena said: @ebinmaine https://www.amazon.com/Black-Magic-120182SRP-Graphene-Detailer/dp/B09NMQ1T96/ref=asc_df_B09NMQ1T96?t got this at Walmart , end of isle sale , $ 7 , insane shine and smoothness , if you thought your paint was clean , wipe it down with this , your recent car pick up , would love it , go shinny , pete Thanks Peter! 1 Share this post Link to post Share on other sites
peter lena 8,461 #11 Posted September 12, 2023 @gwood its so slick, that the regular dusty road pick up , on the trunk area , is not even there ! always trying something , also have a 6" electric palm buffer , that makes buffing very easy , used to detail cars , in my other life , Pete Share this post Link to post Share on other sites
gwood 16 #12 Posted September 26, 2023 On 9/12/2023 at 1:21 PM, peter lena said: @gwood its so slick, that the regular dusty road pick up , on the trunk area , is not even there ! always trying something , also have a 6" electric palm buffer , that makes buffing very easy , used to detail cars , in my other life , Pete On 9/12/2023 at 1:21 PM, peter lena said: @gwood its so slick, that the regular dusty road pick up , on the trunk area , is not even there ! always trying something , also have a 6" electric palm buffer , that makes buffing very easy , used to detail cars , in my other life , Pete On 12/15/2022 at 11:50 AM, peter lena said: often refer to aerosol lubrication on dry / faded / neglected paint , basically feeding / recovering that paint . let the oil soak do all the hard work, the related pictures , went thru a 2 day spray , soak wipe down , do it again phase. after 2 soaks , there was a definite color base , used a 6" palm buffer with cleaner wax , paint just came right out as you see it , typically just rub them down wit clean cloth , lubricant , thats what they look like . amazing to me how once recovered , how easy it is to keep it that way . also show a heim joint to plow blade lever rod, Pete, I am looking at photo #5 to find the bolt you told me to look at but l don't seem to see what your talking about,. Has it something to do with the center spring? Sorry to bug you on this! Share this post Link to post Share on other sites
ineedanother 1,369 #13 Posted September 26, 2023 On 5/9/2023 at 8:24 AM, peter lena said: @ebinmaine https://www.amazon.com/Black-Magic-120182SRP-Graphene-Detailer/dp/B09NMQ1T96/ref=asc_df_B09NMQ1T96?t got this at Walmart , end of isle sale , $ 7 , insane shine and smoothness , if you thought your paint was clean , wipe it down with this , your recent car pick up , would love it , go shinny , pete I agree with you on this @peter lena . My Yukon is getting up in years and miles and it's BLACK. I picked up some 303 graphine detailer last year and was impressed. It was a bit pricey so I might give the Black Magic a shot at 1/3 of the price. 1 Share this post Link to post Share on other sites
