case442
314 h snow blade lift bracket
case442
Hello all,
I have a 1997 314H that I’m looking for the lift arm or bracket to attach the snow blade to the rock shaft. I see that there are two different lengths available. Would anyone know which arm would be used on this tractor? I appreciate your help.
Thank you,
Mike
Achto
If you do not need down pressure you can use a chain. Down pressure is nice to have though.
953 nut
:confusion-confused:         If you want to go directly to the rock shaft the long link should be the one you want. If you want to connect to the mower lift arm so the blade has float and follows the couture of the driveway which I would advise then you want the short one or a chain.
  • Like 4
peter lena
 @case442  done an aerosol  lubrication spray / soak down to all bearing / bushing related end areas ? look up a breakdown drawing , especially end areas , make the rust run out , that will make all related movement area s  move as they should , pete
Racinbob
Here you go. :)
peter lena
@case442  also a very good opportunity to , lubrication detail in that steering quadrant , set up plow  on  a couple of milk crates , so its  supported  like under tractor , roller stool  around it  as you go , aerosol red grease , in the spring loaded slide pin , pop off top and bottom  push in covers for access. small  channel lock plyers , to snug up lever linkage sloppy / play areas. elastic lock nuts on bolt ends at lever bottom area , grease , dial in and secure consistent  smooth / easy lever squeeze and  plow swing . hair pin  clips 1/8"  on back axel  lever swing , push thru to last hole , they won't fall out . love doing those , easy  ,and so worth it , my plows swing with total ease , zero rust , spray blade face with lubricant , how easy does that work ?   don,t have a hydro  , so made up a  forward front end spring assist ,  love having easy to use anything , just me , pete
case442
Thank you all,
it’s much appreciated now I have a direction to go in.
mike
