John Rizzardi 70 #1 Posted December 12, 2022 Hello all, good morning! My 414-8 did not respond any differently to cleaning out crap in fuel tank ( loaded with debris ) and new fuel filter and fuel line!, going backwards it would seem now, since i finally realized to drill down farther with fuel pump investigation, 1st time around with no fuel in line and checking pump by turning key on i heard pump “clicking” i’ll say, thought that meant ok, oops not so much! Today with fuel pump discharge line disconnected and going into gas can i found no fuel coming out of discharge side while turning key “on” still clicking at pump but no fuel being sent out. Finally my question to all who have hung with this story this long! lol, Original Mechanical pump (?) still is on motor, would members recommend going back to original Pump (mechanical) or replace broken elec with new elec? Thanks agsin to all members who read snd respond. 1 Share this post Link to post Share on other sites
ebinmaine 70,761 #2 Posted December 12, 2022 IMHO. Replace broken electric with new electric and make sure you go to a quality type pump. Point being, they can be bought on the interwebs for under 20 bucks but you do get what you pay for..... 2 1 Share this post Link to post Share on other sites
Handy Don 13,340 #3 Posted December 12, 2022 My personal experience is that the stock pumps work fine. But I agree with @ebinmaine, in your case continue with a good electric. If you choose to remove your stock pump and cover the opening with a gasketed plate, don't discard the pump. Pass it on to a member here for rebuilding. 1 Share this post Link to post Share on other sites
pacer 3,175 #4 Posted December 12, 2022 Chasing this problem should be really basic -- start at tank, if fuel comes out move to next step - filter?, if fuel there then move to pump, if there (or not!) etc, etc. If you arent getting fuel from the pump, then it is the problem, either a bad unit or wiring to it wrong. At one of these points in the routing is where your problem is -- and as @ebinmaine points out there are some of the on line pumps that dont perform well. I had 3 of the most common type (read: cheap!), the round ones, that failed with in a very short time. 3 Share this post Link to post Share on other sites
Ed Kennell 40,500 #5 Posted December 12, 2022 The electric pumps must have a filter directly in front of the inlet. IMO, Any speck of dirt can lock up an electric pump. 1 3 1 Share this post Link to post Share on other sites
John Rizzardi 70 #6 Posted December 12, 2022 54 minutes ago, Ed Kennell said: The electric pumps must have a filter directly in front of the inlet. IMO, Any speck of dirt can lock up an electric pump. Thank you Ed, pump has filter upstream of pump, downstream might be another filter however i assumed it was a check vlv!, the tractor ran fine till it stopped!,( upstream one looked very old, replaced it with new one, but moved it to between tank petcock and check valve( if it is a check vlv, i mean who puts two filter’s on system, (upstream snd downstream?) thats why i thought i was looking at check vlv right b4 pump, actually its screwed into suction side of pump. 3 Share this post Link to post Share on other sites
squonk 42,560 #7 Posted December 12, 2022 I pay a bit more for an electric pump at Napa. # 610-1051, $79.00 now. But if it fails I can get another one in 15 minutes and be running again. 1 1 Share this post Link to post Share on other sites
John Rizzardi 70 #8 Posted December 12, 2022 31 minutes ago, squonk said: I pay a bit more for an electric pump at Napa. # 610-1051, $79.00 now. But if it fails I can get another one in 15 minutes and be running again. That is the exact one i took off my machine and replaced with exact same one at NAPA today, no idea how old the “old” one was, but that is the same pump now in a box on DR table till i go out later today and swap it out, there was a filter on discharge side of pump (‘tween pmp and Carburator, on the intake side of pmp was was what i thought had to be check vlv!, I mean who puts 2 fuel filters on gas line?, never got fuel THAT dirty, until in the box with new pmp was what is in lower right corner of your picture, fuel filter, old one ‘tween pmp outlet and Carb looked old and shot, its out and i put new fuel filter ‘tween suction side of pmp snd Petcock at tank, now located under seat, still not gonna use 2nd filter( new one that came with fuel pmp). Thanks for reaching out, and the pic of pump that i too purchased st NAPA (for $79 as well.) 3 Share this post Link to post Share on other sites
squonk 42,560 #9 Posted December 12, 2022 These electric pumps want to push not pull. Mount it as close to the tank as you can. 3 1 Share this post Link to post Share on other sites
Ed Kennell 40,500 #10 Posted December 12, 2022 6 minutes ago, squonk said: These electric pumps want to push not pull. True of nearly all pumps. Yes, mount as near the tank as possible and as far below the tank as possible. 1 1 Share this post Link to post Share on other sites
