peter lena
looking for lube , reference
peter lena
https://www.bing.com/search?q=lucas heavy equipment grease&qs=n&form=QBRE&=%eManage Your Search History%E&sp=-1&pq=lucas heavy equipment grease&sc=10-28&sk=&cvid=BEF9585E2B0044CF8338CA652118CC66&ghsh=0&ghacc=0&ghpl=   , just put this on line  for a search , apply it to your area , there has to be  possible hook up , another thing there is a grease called GREEN GREASE ,  that is not a hi temp  grease ,  you want lucas  for results . might also try getting a few similar  grease addicts , to get a case , each get 2/3 tubes , split up cost , easier availability , just an idea , pete
GAJoe
I looked and looked for this and called many stores checking stock. I finally called the local O'Riley's and asked if they could get it. They had it 8:00 the next morning. Got two cartridges. Just had to ask.
  • Excellent 1
peter lena
@GAJoe  months back did the same at a  local  stop,  got 4 tubes , once you start using that in a failure spot , you are hooked . it  just converts a  problem to a pleasure on smooth / easy / quiet operation , have this in every  bearing , and joint , greasy , pete
