John c 86 #1 Posted December 11, 2022 I can't find the Lucas X-tra HD grease anywhere Greasy Pete where are you ? @peter lena We need your knowledge of the green lucas 3 Share this post Link to post Share on other sites
RandyLittrell 3,894 #2 Posted December 11, 2022 33 minutes ago, John c said: I can't find the Lucas X-tra HD grease anywhere Greasy Pete where are you ? We need your knowledge of the green lucas Lucas just sold off there pulling series, hope they aren't going through hard times. Randy 2 Share this post Link to post Share on other sites
ri702bill 8,989 #3 Posted December 11, 2022 As I recall there was a "supply chain" issue getting at least 1 of the components... Bill 2 Share this post Link to post Share on other sites
peter lena 9,090 #4 Posted December 11, 2022 @John c @ RANDY LITTRELL , you can also use the lucas marine grease , very hi temp rated will stay with it , my local auto parts , auto zone has it . seen it in a number of related auto stops . I am in ledyard ct . typically shopping in groton ct , near the sub base . walmart might have it , pete 1 Share this post Link to post Share on other sites
John c 86 #5 Posted December 12, 2022 I've seen the marine grease while searching for the HD x-tra,, I thought maybe it was a newer version of it or something. So is there any indications if the HD will return or not ? 1 Share this post Link to post Share on other sites
peter lena 9,090 #6 Posted December 12, 2022 @John c seams to be erratic with availability and stores , you could check out your local auto supply stores , on line for stock , call ahead and get what you can , seen it in the small tubes , would like to have the answer , the marine grease has the high temp / stress rating you want , regularly cruse thru auto stores , for something , ask them if they can check other same brand stores for stock . they can probably get it thru them , was told the HD will be back , but with everything on a ship some ware. might try a heavy equipment site , hope you find some , pete Share this post Link to post Share on other sites
