t_furl43 78 #1 Posted December 9, 2022 Was wondering what your guy’s opinion is. is a series 1 kt19 worth rebuilding? A couple days ago mine locked up, it’s in my C195 I would like to keep it all original but if it’s not worth rushing into I would still do it in the future but I would just re-power it for now. Tia fellas 1 Share this post Link to post Share on other sites
953 nut 57,978 #2 Posted December 9, 2022 (edited) First I would suggest you do an autopsy and determine what made it lock up. A flywheel magnet coming loose would lock the flywheel and not require an engine rebuild. What was going on at the time it locked up? Was the oil level good? Will the crank shaft move at all? Start with removing the flywheel. If nothing looks out of place there then remove the heads and take a look at the cylinders. Edited December 9, 2022 by 953 nut fat finger 4 Share this post Link to post Share on other sites
t_furl43 78 #3 Posted December 9, 2022 4 hours ago, 953 nut said: First I would suggest you do an autopsy and determine what made it lock up. A flywheel magnet coming loose would lock the flywheel and not require an engine rebuild. What was going on at the time it locked up? Was the oil level good? Will the crank shaft move at all? Start with removing the flywheel. If nothing looks out of place there then remove the heads and take a look at the cylinders. I kind of made like her slight squealing noise and kinda started to slow down I shut it off immediately and when I went to go try it again no budge, There’s no oil leaking anywhere and it has oil in it 1 1 Share this post Link to post Share on other sites
953 nut 57,978 #4 Posted December 9, 2022 Well That kind of rules out the least expensive options, sounds more like connecting rod welded itself to the crankshaft, 2 Share this post Link to post Share on other sites
8ntruck 7,394 #5 Posted December 10, 2022 I'll be watching this with interest. The KT19 series 1 engine in my C-195 fires right up and runs well. But, it is smoking. I'm kind of wrestling with the same question. I need to take the heads off and take a look at the cylinders before making a decision. Koehler considers the KT19 to be obsolete, so OEM parts are getting rare. If you want to stay in the 20hp range, new and used engines typically have 4 figure price tags. Share this post Link to post Share on other sites
pfrederi 18,334 #6 Posted December 10, 2022 31 minutes ago, 8ntruck said: I'll be watching this with interest. The KT19 series 1 engine in my C-195 fires right up and runs well. But, it is smoking. I'm kind of wrestling with the same question. I need to take the heads off and take a look at the cylinders before making a decision. Koehler considers the KT19 to be obsolete, so OEM parts are getting rare. If you want to stay in the 20hp range, new and used engines typically have 4 figure price tags. A do it yourself overhauls with machine shop work is going to be right at 4 digits...if you can round up all the parts. Did my magnum 18 $900 almost 2 years ago. Parts prices are up and availability is down... 1 Share this post Link to post Share on other sites
Wild Bill 633 866 #7 Posted December 10, 2022 My understanding is the KT series 1 has a splash oil system and the series 2 has the improved pressurized oil system. https://madison.craigslist.org/grd/d/madison-kohler-kt-19-motor/7565358825.html Share this post Link to post Share on other sites
953 nut 57,978 #8 Posted December 10, 2022 55 minutes ago, Wild Bill 633 said: KT series 1 has a splash oil system Not a splash oil system, more of a drip oil to the connecting rods. It is a low pressure system with no direct pressurized oiling to the crank. Share this post Link to post Share on other sites
