ebinmaine 69,817 #1 Posted December 8, 2022 I need to make a gasket that goes between the case halves of a Sundstrand mid-70s transmission. Only reference point I have is a leftover piece from doing a manual transmission in the past. It's very thin. 1/16" thickness maybe? Maybe less? What say you folks? 2 Share this post Link to post Share on other sites
Horse Newbie 7,168 #2 Posted December 8, 2022 Yes… 2 Share this post Link to post Share on other sites
WHX?? 49,955 #3 Posted December 8, 2022 Get one from Loweĺl... 3 Share this post Link to post Share on other sites
ebinmaine 69,817 #4 Posted December 8, 2022 22 minutes ago, WHX?? said: Get one from Loweĺl... I didn't see them listed for a hydro... Share this post Link to post Share on other sites
WHX?? 49,955 #6 Posted December 8, 2022 Pretty sure he has them. Might want to give him a jingle. Didn't we get them from him when we did that Bronco refresh @Achto? 3 Share this post Link to post Share on other sites
ebinmaine 69,817 #7 Posted December 8, 2022 3 minutes ago, pfrederi said: Niiiiice Share this post Link to post Share on other sites
Pullstart 63,609 #8 Posted December 8, 2022 I am probably wrong… but aren’t they the same gasket hydro or stick shift? 3 1 Share this post Link to post Share on other sites
pfrederi 18,201 #9 Posted December 8, 2022 Just now, Pullstart said: I am probably wrong… but aren’t they the same gasket hydro or stick shift? Same thickness different patterm 5 1 Share this post Link to post Share on other sites
ebinmaine 69,817 #10 Posted December 8, 2022 9 minutes ago, Pullstart said: I am probably wrong… but aren’t they the same gasket hydro or stick shift? This hole is not in the gasket for a manual transmission. 3 Share this post Link to post Share on other sites
WHX?? 49,955 #11 Posted December 8, 2022 I think the sticks are a 3912. 3 1 Share this post Link to post Share on other sites
pfrederi 18,201 #12 Posted December 8, 2022 16 minutes ago, ebinmaine said: This hole is not in the gasket for a manual transmission. Fluid return line going to filter... 3 Share this post Link to post Share on other sites
pacer 3,174 #13 Posted December 8, 2022 I just make my own, preferring a cereal box, but anything similar will do - bout 10 min and I got it......... 2 2 Share this post Link to post Share on other sites
ebinmaine 69,817 #14 Posted December 8, 2022 1 minute ago, pacer said: I just make my own, I was gonna do that but I need to place an order with Lowell anyway. 2 Share this post Link to post Share on other sites
ebinmaine 69,817 #15 Posted December 8, 2022 20 minutes ago, WHX?? said: I think the sticks are a 3912. Correct. Those are still available from Toro. 1 Share this post Link to post Share on other sites
Ed Kennell 39,809 #16 Posted December 8, 2022 I never had one apart, but 1/16" seems too thick. I would have guessed 1/32". 1 1 1 Share this post Link to post Share on other sites
stevasaurus 22,972 #17 Posted December 8, 2022 Right Ed...1/32nd. You can buy 1/32nd material at Autozone in 1' x 3' pieces for about $6.00. Buy one and then use the material to make 3 more. It is nice to have a hole punch to make nice holes. 2 Share this post Link to post Share on other sites
Handy Don 13,114 #18 Posted December 8, 2022 2 hours ago, stevasaurus said: It is nice to have a hole punch to make nice holes Definitely works perfectly for bolt and screw holes! If the plier type isn't large enough, you can get individual punches in sets. I bought a cheap set of "cutter style" punches for leather working similar to this. Since I didn't need all the shapes as "closed" figures, I cut a couple of them open with the band saw, so I could do smooth outside and inside curves as well as short straight sections. 2 Share this post Link to post Share on other sites
ebinmaine 69,817 #19 Posted December 8, 2022 2 hours ago, stevasaurus said: Right Ed...1/32nd. You can buy 1/32nd material at Autozone in 1' x 3' pieces for about $6.00. Buy one and then use the material to make 3 more. It is nice to have a hole punch to make nice holes. I'd like to get this thing put back together this weekend so I decided to pick up a roll of sheet goods as suggested. What I ended up with is 1/32nd Felpro Karropak. 10 minutes ago, Handy Don said: set of "cutter style" punches @Oldskool Mike being as ornery as he is 🤪 was nice enough to send me a set of those. Should be a good experiment. 4 Share this post Link to post Share on other sites
WHX?? 49,955 #20 Posted December 8, 2022 2 minutes ago, ebinmaine said: put back together this weekend Nothin like planning ahead there guy. 'Sides yer supposed to have another project on the table while waitin for parts.... Can you say Molaasses!?!?! 6 hours ago, pacer said: I just make my own, Boy if that don't sound like @Achto ! 2 2 Share this post Link to post Share on other sites
stevasaurus 22,972 #21 Posted December 8, 2022 The Kero-Pac is the right stuff. Videos exist on you-tube that show how to use a Ball Peen hammer to peen the edges of the material on the casting and then punch the holes. 1 1 Share this post Link to post Share on other sites
ebinmaine 69,817 #22 Posted December 8, 2022 24 minutes ago, WHX?? said: Nothin like planning ahead there guy. 'Sides yer supposed to have another project on the table while waitin for parts.... Can you say Molaasses!?!?! Yyyeeeaaahhh.... Well I've pretty much always got about 372.4 projects going. Me n @19richie66 were blabbering about this earlier. 🤪 @WHX?? Jimbo I'm thinking this'll be the axle set I try to make a full groove keyway in using a 4" angle grinder. Got some junk axles to practice on. 2 Share this post Link to post Share on other sites
WHX?? 49,955 #23 Posted December 8, 2022 1 minute ago, ebinmaine said: make a full groove keyway in using a 4" angle grinder. Got some junk axles to practice on. Oooohhh good luck with that. Best have a wheel that is really square. Maybe try cutting the outside slots with a thin dremel cut off wheel?? Reminds me of Dan's lathe ... a grinder with the motor running! 1 2 Share this post Link to post Share on other sites
WHX?? 49,955 #24 Posted December 8, 2022 31 minutes ago, stevasaurus said: Ball Peen hammer to peen the edges of the material on the casting I think it was HS power mechanics we were taught to put oil on it, press it on the materials then trace and cut it out. 2 Share this post Link to post Share on other sites
ebinmaine 69,817 #25 Posted December 8, 2022 20 minutes ago, WHX?? said: a wheel that is really square I've got a selection of brand new cutoff wheels ¹/¹⁶, ⅛ and ¼ wide. Whatever works to get a nice sharp ¼ wide groove. 2 Share this post Link to post Share on other sites
