mike avad 44 #1 Posted December 6, 2022 I HAVE A 1988 OR 1989 252-H HYDRO WHEEL HORSE WITH A BRIGGS&STRATTON INTEK 17.5 HP. I HAVE TO FRONT OF THE FRONT ON THE TRACTOR UP ON A CHAIN FALL AND AM TRYING TO REMOVE THE CLUTCH I'V TAKEING THE BOLT OUT FROM THE PULLEY AND UN PLUG THE CLUTCH. NOW YOU I NEED TO USED A PULLER TO GET THE CLUTCH OFF THE SHAF OF THE ENG? OR LOWER IT SO AM ABLE TO PUT THE DRIVE BELT ON THERE? THANKS FOR ANY REPLYS OR INFO. 1 Share this post Link to post Share on other sites
mike avad 44 #2 Posted December 6, 2022 I HAVE A 1988 OR 1989 252-H HYDRO WHEEL HORSE I NEED SOME INFO ON THE CLUTCH ASSEEBY I HAVE THE FRONT ON THE TRACTOR UP ON A CHAIN FALL AND I'V ALSO UNPLUG THE CLUTCH IV TAKING THE BOLT OUT THE HOLDS THE PULLEY ON THE ENG SHAF THE TRACTOR HAS A BRIGGS & STRATTON INTEK 17.5 HP OHV ENG. I NEED TO KNOW IF I NEED TO USED A PULLEY PULLER TO REMOVE THAT CLUTCH ASSEEMBY SO AM ABLE TO PUT THE DRIVE BELT ON OR JUST LOWER THE PULLEY SO AM ABLE TO PUT THE BELT ON. THANKS AND ANY HELP AND INFO 1 Share this post Link to post Share on other sites
Lee1977 7,041 #3 Posted December 6, 2022 42 minutes ago, mike avad said: I HAVE A 1988 OR 1989 252-H HYDRO WHEEL HORSE I NEED SOME INFO ON THE CLUTCH ASSEEBY I HAVE THE FRONT ON THE TRACTOR UP ON A CHAIN FALL AND I'V ALSO UNPLUG THE CLUTCH IV TAKING THE BOLT OUT THE HOLDS THE PULLEY ON THE ENG SHAF THE TRACTOR HAS A BRIGGS & STRATTON INTEK 17.5 HP OHV ENG. I NEED TO KNOW IF I NEED TO USED A PULLEY PULLER TO REMOVE THAT CLUTCH ASSEEMBY SO AM ABLE TO PUT THE DRIVE BELT ON OR JUST LOWER THE PULLEY SO AM ABLE TO PUT THE BELT ON. THANKS AND ANY HELP AND INFO What belt are you replacing. It shouldn't require a clutch pulley removible to replace either belt. There may be belt guards in the way that need to be removed to get the belt in place. 1 Share this post Link to post Share on other sites
Achto 28,794 #4 Posted December 7, 2022 I don't have much knowledge about your model but I don't think that you should have to remove the clutch in order to change the belt. Here is a manual for you. Check the manuals section, there might be one with even better info. Share this post Link to post Share on other sites
953 nut 57,965 #5 Posted December 7, 2022 I have never owned a 200 series and the attached manual has no guidance on drive belt installation. My guess is that the mower deck belt will need to be removed first and then reinstalled after the new drive belt. All of the electric clutches I have dealt with needed to be removed with a large bolt threaded into the center of the clutch. It may be 5/8',3/4" or larger. The belt pushes the clutch off the shaft. This may or may not be the same as your clutch but look inside to see if there are threads in there. 1 1 Share this post Link to post Share on other sites
