oker 12 #1 Posted December 6, 2022 Hi ! i´m having some troubles with my toro 523 dxi , engine runs rough and hard to start .....and finally engine does not start . I have found that one of the distribution ports of the diesel pump is clogged so there is no fuel in one of the cylinders. So i decided to disasembly the diesel pump ......but i need some advice how to do it . I have repair manual from toro ( https://www.toro.com/getpub/13225 ) .....But there is no info about diesel pump rebuild Anybody has rebuild manual for the diesel pump? Regards. 1 Share this post Link to post Share on other sites
Achto 30,189 #2 Posted December 6, 2022 (edited) Diesel pumps are not for the novice to tear into. I will tear apart & repair almost any thing on an engine. But, I myself would take the injector pump and injectors to a professional to have them serviced. If you do wish to tackle it yourself then you will need the service manual from Briggs & Stratton to get your engine information. Edited December 6, 2022 by Achto 2 1 Share this post Link to post Share on other sites
Handy Don 15,169 #3 Posted December 6, 2022 9 minutes ago, Achto said: Diesel pumps are not for the novice Seconded. 2 Share this post Link to post Share on other sites
shallowwatersailor 3,216 #4 Posted December 7, 2022 See if you can find a shop that could provide a rebuilt unit or even rebuild yours. Maybe in Bilbao? The fuel pump is unfortunately the "heart" of this engine, and a very complicated one. 2 Share this post Link to post Share on other sites
oker 12 #5 Posted December 7, 2022 (edited) yes guys i know diesel pumps are not for newbies , but i have been dealing with cars , motorbikes , or anything with wheels and engine since i was 18....so i´m not afraid about diesel pumps . i have found that all the fuel system on this engines ( DM 850 D) is provided by denso , the pump is VE type and luckily i was able to found a DENSO for VE pumps , that covers service and manteinace .( this manual is in spanish) MANUAL+DE+SERVICIO+BOMBA+VE+DENSO.PDF Edited December 7, 2022 by oker 1 1 Share this post Link to post Share on other sites
