screech
Engine swapping??
screech
Will the engines from "H, hydralic" tractors swap into "8 speed" tractors?
Thank You!!!
WHGuy413
If you are talking will the engines from an automatic wheel horse say a c-160 hydro then yes that is the same engine that would be in a c-160 8 speed. Just using those as an example. The engines were the same the transmissions were different.
  • Like 4
screech
Exactly, I am thinking an engine from a 416H, 418H or a 520H and putting it into a c-105 or a 312-8.
Thank you.
BESTDOGEVER
Usually the main engine pulley is ddifferent which will change the drive belt size. Using the original pulley should keep everything the same
  • Like 6
Lee1977
if you are replacing a Kohler with a Onan the wireing may be different. The c-105 and early 312 had a K-series, the later 312's had Magnums.
screech
My 314-8 with a 48" deck does not have the power I need for mowing. I see many hydraulic tractors for sale, but few bigger HP 8 speeds. So I thought about buying one of these "H" tractors for the engine. Thank You
953 nut
:WRS:
If the ignition systems are both battery powered with points and a coil there will be some slight wiring and choke/throttle cable changes, As already mentioned the pulley on the engine of a Hydro tractor is larger than on an 8 eight speed. You would be able to use your pulley from the present engine on the replacement.
Sailman
Not sure if I followed the thread right but it sounds like the 14 HP does not have enough power so you are looking at 16 or bigger. I have a 416-8, C-160 and a GT 14 (14 HP). I can tell little difference between the 16 and 14 HP tractors so you might need to go bigger than the 16 if you are looking for more power. Just my $.02 worth.
ebinmaine
I agree.
Whether an engine is in a hydro or manual has no bearing on power.
A 14 is a 14.
A 20 is a 20 etc.
A 14 HP in an 8 speed tractor should be able to cut "most" things.
Have you done a proper tuneup?
Maintenance?
Non ethanol gas?
New fuel lines?
Mower deck proper maintenance?
Are you in too high of a gear?
Just some food for thought...
Racinbob
:text-yeahthat:I agree with Eric. A 14hp should be plenty. I've mowed for years using 11hp and 12hp tractors with 48's. Something must not be right. :)
pacer
I agree, a 14hp in good condition should handle a 48" deck with relative ease.
HP can, of course be a factor -- I had a 10hp kohler (241) trying to drive a 48" and it struggled.
Course depends on what your cutting too - I've got a 20hp twin on my D200 and if I get into some heavy stuff even it will have to take it slower.
Pullstart
Thank you.
It looks like we are talking about 10 or 12 hp machines.  Maybe rollers?
oldlineman
Yes I am turning a 48 " deck with a 1989 414-8 and it has plenty of power even in higher grass. You may not be getting the HP out of your engine because of engine wear or other engine problems. Bob
Pullstart
But we don’t know if the 8 speed tractors even have engines to start.. we need a little more info from @screech :handgestures-thumbupright:
lynnmor
Are you running the engine at full throttle?  It needs 3600 RPM to develop maximum horsepower.  Are the blades sharpened correctly?
Pullstart
I didn’t see the mention of running a different 14 horse, my apologies.
Alex175
16 hours ago, BESTDOGEVER said:
Usually the main engine pulley is different
This is correct, I just recently took a KT17 out of a 417-8 to replace the KT17 in my C-175 Hydro, got really confused when the belt looked way too long after the swap, turned out it was all in the size of the pulley.
rick
My 700 hour 1997 314-8 with a 48" deck works fine.  I do cut in 1st gear full throttle because my improved pasture lawn is a little rough.  I am retired so it isn't a problem to cut it when the grass is an inch or more above cut length.  I sharpen and balance the blades every three cuttings, which adds up to 9 hours of steady cutting.
SylvanLakeWH
10 hp cuts through this no problem... 1st gear high.
Just my :twocents-twocents:
  • Like 5
Blasterdad
I run a 48" deck on my C-120 no problem, never had it bog down, but the tractor & deck are both very well maintained.
  • Like 4
clueless
If the 14hp is not smoking or burning oil I think your grass cutting problem may not be the engine. What are you cutting, 14hp with a 8sp is plenty of hp even with a 48" deck. My old 8hp B-80 with a 42" beck cut thick patches of grass for many years as long as it wasn't higher than 3.5 inches.
ranger
If it’s a Magnum engine I believe the max rpm is 3200 as opposed to 3600 on the earlier versions. With the non adjustable version of the Walbro carb, I don’t think you’re supposed to increase the max rpm, due to the risk of engine damage caused by a too lean mixture, unless you change the carb to the older style with adjustable high speed mixture screw?
BESTDOGEVER
Just a thought if the hydro tractor is in working condition Just put the deck on it and save all that extra work, a half hour deck install vs all the stuff to change over electrical and then fabricate mount plates ect.
Tuneup
My old 12 before the rebuild would struggle with the 48 (the 516 was being rebuilt) so I had no choice). These engines are dated to say the least and my initial piston replacement on the 12 included roughing the cylinder with stones. It made a minor dent only and she never really came to her potential. After an .020 bore and a real honing, it's a beast. I would argue a well-tuned and fresh K301 or 321 would be up to the job. I mow in 2nd, albeit over a mixture of fescue and dirt. Heavier, healthy lawns, well, that would be different. All that said, a twin's torque would give you what you want. My Onan doesn't care, and it helps that those stones set-up those aluminum cylinders quite well.
