screech 16 #1 Posted November 30, 2022 Will the engines from "H, hydralic" tractors swap into "8 speed" tractors? Thank You!!! 3 Share this post Link to post Share on other sites
WHGuy413 2,769 #2 Posted November 30, 2022 If you are talking will the engines from an automatic wheel horse say a c-160 hydro then yes that is the same engine that would be in a c-160 8 speed. Just using those as an example. The engines were the same the transmissions were different. 4 1 Share this post Link to post Share on other sites
screech 16 #3 Posted November 30, 2022 29 minutes ago, WHGuy413 said: If you are talking will the engines from an automatic wheel horse say a c-160 hydro then yes that is the same engine that would be in a c-160 8 speed. Just using those as an example. The engines were the same the transmissions were different. Exactly, I am thinking an engine from a 416H, 418H or a 520H and putting it into a c-105 or a 312-8. Thank you. 2 Share this post Link to post Share on other sites
BESTDOGEVER 218 #4 Posted November 30, 2022 Usually the main engine pulley is ddifferent which will change the drive belt size. Using the original pulley should keep everything the same 6 Share this post Link to post Share on other sites
Lee1977 6,917 #5 Posted November 30, 2022 if you are replacing a Kohler with a Onan the wireing may be different. The c-105 and early 312 had a K-series, the later 312's had Magnums. 3 Share this post Link to post Share on other sites
screech 16 #6 Posted November 30, 2022 My 314-8 with a 48" deck does not have the power I need for mowing. I see many hydraulic tractors for sale, but few bigger HP 8 speeds. So I thought about buying one of these "H" tractors for the engine. Thank You 2 Share this post Link to post Share on other sites
953 nut 56,715 #7 Posted November 30, 2022 If the ignition systems are both battery powered with points and a coil there will be some slight wiring and choke/throttle cable changes, As already mentioned the pulley on the engine of a Hydro tractor is larger than on an 8 eight speed. You would be able to use your pulley from the present engine on the replacement. 1 Share this post Link to post Share on other sites
Sailman 1,299 #8 Posted November 30, 2022 Not sure if I followed the thread right but it sounds like the 14 HP does not have enough power so you are looking at 16 or bigger. I have a 416-8, C-160 and a GT 14 (14 HP). I can tell little difference between the 16 and 14 HP tractors so you might need to go bigger than the 16 if you are looking for more power. Just my $.02 worth. 3 Share this post Link to post Share on other sites
ebinmaine 69,684 #9 Posted November 30, 2022 31 minutes ago, Sailman said: Not sure if I followed the thread right but it sounds like the 14 HP does not have enough power so you are looking at 16 or bigger. I have a 416-8, C-160 and a GT 14 (14 HP). I can tell little difference between the 16 and 14 HP tractors so you might need to go bigger than the 16 if you are looking for more power. Just my $.02 worth. I agree. Whether an engine is in a hydro or manual has no bearing on power. A 14 is a 14. A 20 is a 20 etc. A 14 HP in an 8 speed tractor should be able to cut "most" things. Have you done a proper tuneup? Maintenance? Non ethanol gas? New fuel lines? Mower deck proper maintenance? Are you in too high of a gear? Just some food for thought... 3 1 Share this post Link to post Share on other sites
Racinbob 11,431 #10 Posted November 30, 2022 I agree with Eric. A 14hp should be plenty. I've mowed for years using 11hp and 12hp tractors with 48's. Something must not be right. 3 Share this post Link to post Share on other sites
pacer 3,174 #11 Posted November 30, 2022 I agree, a 14hp in good condition should handle a 48" deck with relative ease. HP can, of course be a factor -- I had a 10hp kohler (241) trying to drive a 48" and it struggled. Course depends on what your cutting too - I've got a 20hp twin on my D200 and if I get into some heavy stuff even it will have to take it slower. 1 Share this post Link to post Share on other sites
Pullstart 63,503 #12 Posted November 30, 2022 12 hours ago, screech said: Exactly, I am thinking an engine from a 416H, 418H or a 520H and putting it into a c-105 or a 312-8. Thank you. 1 hour ago, Sailman said: Not sure if I followed the thread right but it sounds like the 14 HP does not have enough power so you are looking at 16 or bigger. I have a 416-8, C-160 and a GT 14 (14 HP). I can tell little difference between the 16 and 14 HP tractors so you might need to go bigger than the 16 if you are looking for more power. Just my $.02 worth. It looks like we are talking about 10 or 12 hp machines. Maybe rollers? 2 Share this post Link to post Share on other sites
oldlineman 1,489 #13 Posted November 30, 2022 Yes I am turning a 48 " deck with a 1989 414-8 and it has plenty of power even in higher grass. You may not be getting the HP out of your engine because of engine wear or other engine problems. Bob 2 Share this post Link to post Share on other sites
Pullstart 63,503 #14 Posted November 30, 2022 9 minutes ago, oldlineman said: You may not be getting the HP out of your engine because of engine wear or other engine problems. But we don’t know if the 8 speed tractors even have engines to start.. we need a little more info from @screech 1 Share this post Link to post Share on other sites
lynnmor 7,471 #15 Posted November 30, 2022 12 hours ago, screech said: My 314-8 with a 48" deck does not have the power I need for mowing. Are you running the engine at full throttle? It needs 3600 RPM to develop maximum horsepower. Are the blades sharpened correctly? 3 Share this post Link to post Share on other sites
Pullstart 63,503 #16 Posted November 30, 2022 I didn’t see the mention of running a different 14 horse, my apologies. 1 Share this post Link to post Share on other sites
Alex175 784 #17 Posted November 30, 2022 16 hours ago, BESTDOGEVER said: Usually the main engine pulley is different This is correct, I just recently took a KT17 out of a 417-8 to replace the KT17 in my C-175 Hydro, got really confused when the belt looked way too long after the swap, turned out it was all in the size of the pulley. 2 Share this post Link to post Share on other sites
rick 238 #18 Posted November 30, 2022 15 hours ago, screech said: My 314-8 with a 48" deck does not have the power I need for mowing. I see many hydraulic tractors for sale, but few bigger HP 8 speeds. So I thought about buying one of these "H" tractors for the engine. Thank You My 700 hour 1997 314-8 with a 48" deck works fine. I do cut in 1st gear full throttle because my improved pasture lawn is a little rough. I am retired so it isn't a problem to cut it when the grass is an inch or more above cut length. I sharpen and balance the blades every three cuttings, which adds up to 9 hours of steady cutting. 3 Share this post Link to post Share on other sites
SylvanLakeWH 26,556 #19 Posted November 30, 2022 10 hp cuts through this no problem... 1st gear high. Just my 5 1 Share this post Link to post Share on other sites
Blasterdad 2,779 #20 Posted November 30, 2022 I run a 48" deck on my C-120 no problem, never had it bog down, but the tractor & deck are both very well maintained. 4 Share this post Link to post Share on other sites
clueless 3,071 #21 Posted November 30, 2022 15 hours ago, screech said: My 314-8 with a 48" deck does not have the power I need for mowing. I see many hydraulic tractors for sale, but few bigger HP 8 speeds. So I thought about buying one of these "H" tractors for the engine. Thank You If the 14hp is not smoking or burning oil I think your grass cutting problem may not be the engine. What are you cutting, 14hp with a 8sp is plenty of hp even with a 48" deck. My old 8hp B-80 with a 42" beck cut thick patches of grass for many years as long as it wasn't higher than 3.5 inches. 3 Share this post Link to post Share on other sites
ranger 1,770 #22 Posted December 1, 2022 If it’s a Magnum engine I believe the max rpm is 3200 as opposed to 3600 on the earlier versions. With the non adjustable version of the Walbro carb, I don’t think you’re supposed to increase the max rpm, due to the risk of engine damage caused by a too lean mixture, unless you change the carb to the older style with adjustable high speed mixture screw? 2 Share this post Link to post Share on other sites
BESTDOGEVER 218 #23 Posted December 1, 2022 Just a thought if the hydro tractor is in working condition Just put the deck on it and save all that extra work, a half hour deck install vs all the stuff to change over electrical and then fabricate mount plates ect. Share this post Link to post Share on other sites
Tuneup 1,433 #24 Posted December 4, 2022 My old 12 before the rebuild would struggle with the 48 (the 516 was being rebuilt) so I had no choice). These engines are dated to say the least and my initial piston replacement on the 12 included roughing the cylinder with stones. It made a minor dent only and she never really came to her potential. After an .020 bore and a real honing, it's a beast. I would argue a well-tuned and fresh K301 or 321 would be up to the job. I mow in 2nd, albeit over a mixture of fescue and dirt. Heavier, healthy lawns, well, that would be different. All that said, a twin's torque would give you what you want. My Onan doesn't care, and it helps that those stones set-up those aluminum cylinders quite well. Share this post Link to post Share on other sites
