uglyblue66 114 #1 Posted November 29, 2022 I took my wheels from my E 141 to have a couple good tires put on, the clic came un done and the front wheel tried to come off, in doing so,the inner wheel bearing came apart. It appears to be a roller bearing as there were a few of the balls in there. Where can i get a a replacement bearing? I can't find a part number on the bearing to interchange with. 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,210 #2 Posted November 29, 2022 Is the spindle 3/4" diameter? Is the inside diameter of the tube where the bearing goes in the wheel 1-3/8" diameter? Original part number 107124 and no longer available from Toro 1 Share this post Link to post Share on other sites
SylvanLakeWH 27,214 #3 Posted November 30, 2022 (edited) Bummer... I haven't had mine apart so I don't know, but i'm following along to learn... Edited November 30, 2022 by SylvanLakeWH Share this post Link to post Share on other sites
953 nut 57,538 #4 Posted November 30, 2022 (edited) If your bearings are as described by Garry here you go! https://www.ebay.com/itm/283048785612?hash=item41e705b6cc:g:WekAAOSwA-Vds6Vd&amdata=enc%3AAQAHAAAAsEAkzy5cwt2j5Ezt8PwZjgc5zJKQ%2F%2F%2B8ZYAjDU%2FJhVhSkqjrQSWEh15fckY5JLGGFN%2FukX7oDVLAdOeCKt46aDrBtJFxLcMgntV9J0UQMUYBjFGqFwwyh%2BgCIM8W1v4PekL4YWgEeIpRSGW6HBqm6RiiftbrY3BEBpN5JaluKmzrEo47FczuBm7NC3lsJXQH9uYhZn95C1Sr9nsDl8Qk%2FI%2Fy5uaHChboxarBWY1On5ts|tkp%3ABk9SR7TOst6YYQ Edited November 30, 2022 by 953 nut fat finger 2 Share this post Link to post Share on other sites
uglyblue66 114 #5 Posted November 30, 2022 OK, I will have to measure the hub after I knock out the piece still in it. Share this post Link to post Share on other sites
Achto 28,593 #6 Posted November 30, 2022 Here is another source. https://www.amazon.com/Marathon-Replacement-Precision-Ball-Bearings/dp/B002Y289VO/ref=asc_df_B002Y289VO/?tag=hyprod-20&linkCode=df0&hvadid=167133658256&hvpos=&hvnetw=g&hvrand=1065576667384654961&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1028137&hvtargid=pla-307376699206&psc=1 My local Ace Hardware carries these bearings as well. Usually find them in the plastic drawers in the hardware section. The ones at Ace are not sealed bearings like the ones above so they will need to be greased just like the originals. 1 1 1 Share this post Link to post Share on other sites
ri702bill 8,914 #7 Posted November 30, 2022 On 11/30/2022 at 11:33 AM, Achto said: The ones at Ace are not sealed bearings like the ones above so they will need to be greased just like the originals. The sealed ones are the way to go - no more grease stains on the wheels.... 2 1 Share this post Link to post Share on other sites
Handy Don 13,260 #8 Posted November 30, 2022 Just to clarify, these are ball bearings. Roller bearings ride on cylinders instead of balls (and if the cylinders are really small, they are called needle bearings). If you go with sealed bearings (I concur with @ri702bill that these are way to go), @peter lena will advise you to open them and replace the "stock" lube with something like Lucas Red or Green before installing them. Be sure to replace both bearings in each wheel at the same time! I've done this to four tractors now with no issues and I was able to really degrease the wheels in the process so things are a lot cleaner. I even changed the bushing-style bearings on my garden cart over to sealed ball bearings. 4 1 Share this post Link to post Share on other sites
uglyblue66 114 #9 Posted December 1, 2022 thanks folks, I was really annoyed and concerned it would be a real issue to try to deal with. the tractor has had a flat for a month and I finally got it fixed and was going to haul some fire wood out of the woods with it and didn't make it very far . Maby next week! 2 Share this post Link to post Share on other sites
uglyblue66 114 #10 Posted December 3, 2022 (edited) Ok, the inside of the wheel is 1 3/4 inch, the spindle is 3/4 After some research, I found this page, https://www.myelec-traks.com/810007R1.pdf Along with alot of other info but the wheel bearing part number it shows for the E141 is 107124. Edited December 3, 2022 by uglyblue66 2 Share this post Link to post Share on other sites
953 nut 57,538 #11 Posted December 3, 2022 @gwest_ca, do we have this manual in our reference section? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,210 #12 Posted December 3, 2022 On 12/3/2022 at 12:21 PM, 953 nut said: @gwest_ca, do we have this manual in our reference section? Yes we do. 2 1 Share this post Link to post Share on other sites
peter lena 9,061 #13 Posted December 3, 2022 @uglyblue66 have also firmed up those bearings , with additional washers , that detailing also eliminates the play issue . its a regular thing for me to look at the INTENDED FUNCTION . of wheel horse anything , and detail in it working better . thin washers are available for that set up , that firming hold of the bearings prevents the horizontal shucking side to side play that starts bearing destruction . the pictures above , which I can relate too , are what made me look for a change , since stopping wheel , side play , there is no bearing issues at all .road tested it , and applied it to my other horses , so I know it works . make a change on a problem area, just my own experience, pete 1 Share this post Link to post Share on other sites
uglyblue66 114 #14 Posted December 3, 2022 (edited) Well. I will get these spaced up good once I figure out what bearing to get, I had already bookmarked that manual location before a friend told me about this site, but it is good that it is on here as well. Edit,I went by Ace hardware and sure enough they had the 1 3/8ths bearings in a box! BUT to itsybitsy to fit my application. Thanks for the help. I found some on ebay,and sent a message to see if they combine shipping. when they let me know if they do I will buy 4 and just replace all 4 at the same time. May not need them but I don't want this issue again. This tractor is not light! and jacking it up out in the yard is not fun https://www.ebay.com/itm/204160343890 Edited December 3, 2022 by uglyblue66 3 Share this post Link to post Share on other sites
uglyblue66 114 #15 Posted December 10, 2022 fed ex brought the bearings this afternoon.so to get them in tomorrow. The above ebay link ,they do combine shipping so it was 43.77 total for the 4 bearings and shipping. I just went ahead and bought 4 because the shipping was the same for 4 as it was 2. and all are the same age and use. 3 Share this post Link to post Share on other sites
uglyblue66 114 #16 Posted December 11, 2022 Well exact fit,worked great. I took out the inner seal and left the outer 1 in so I can grease the wheels with the fitting. I got 4,and just about cheated and just put the other 2 on the shelf for later but went ahead and checked and I am glad i did. The tire guys had ruined the other inner bearing to.it came all to pieces when I messed with it just a bit.So all new,and I took it on a night time run.glad to have it going .It had sat a while because of a flat bad tire then the bearing screwed up. 3 Share this post Link to post Share on other sites
