manant 57 #1 Posted November 22, 2022 One front wheel on my c160 has failed. The sleeve of the hub must have had a fatigue failure. When I took the wheel off, the bearing came off with a "ring" around it (part of the hub). I have searched for a replacement wheel to no avail. The closest I get is a wheel with a 3" offset hub, but my wheel hub measures 3.5". I guess I could add shims, or a bushing, to get the width I need but was wondering where you guys get replacements. Also, my wheels are held on with a heavy-duty split ring. I broke one when I took the wheel off. Where can you get them or is using a e clip just as good? Share this post Link to post Share on other sites
953 nut 57,965 #2 Posted November 23, 2022 Your local ACE hardware or NAPA will have the snap ring on hand. For a good used replacement wheel you can call Lincoln at A to Z used tractor parts, anything you buy from him has been inspected and is the correct part. https://www.a-ztractor.com/ 2 1 Share this post Link to post Share on other sites
