tractorhogg
Picture of D-160 Kohler PTO Clutch Brake
tractorhogg
I really need to see a picture of the PTO clutch brake on someones D-160 Kohler single. I cant figure out where it is supposed to rub? Thanks
pfrederi
Sorry I have D200.  I think D-160 Kohlers are not that common
tractorhogg
If you would be so kind as to show a picture of your D200 clutch  and PTO brake, it may help me, thanks
pfrederi
She is down in the barn. This is an old pic i had on computer.  Does it help?
pfrederi
If not I can go down later see if I can get a better one
tractorhogg
Does the brake pad face the block, and which side is the brake bolted to the bracket, the inner side or the outer side. Thanks
Edited by tractorhogg
pfrederi
I will have to go look....later ... 29 degrees and windy...
pacer
IIRC the brake is mounted with the pad facing the inside grove of the PTO pulley in about the .... 7 oclock position?
The couple I have had with the brake still on was worn and looked like a pain to keep adjusted so I just removed them and I did away with them. My blades will stop spinning within 5-10 seconds so I didnt really see the need for one.
pfrederi
Friction Pad faces forward.
pacer
Well thankfully I havent lost ALL my brain  -- thats exactly where I thought it was mounted, but was a bit unsure about how the pad was facing and guessed wrong on that part :eusa-think:
tractorhogg
Thank you so much!! the pictures are perfect, 31 and windy here
tractorhogg
Thanks, I bought a reproduction clutch brake from a member here and I was going to return it. I may just keep it even if I'm not going to install it. I thought it might have been the wrong part or that my PTO was missing a piece or bracket for it, but all is good now
tractorhogg
Your preachin to the choir, I couldn't even figure it out without pictures
