tractorhogg 612 #1 Posted November 17, 2022 Many D series and Wheel Horse fans may know this, but not only are there major differences in the first year D series, called the 18 Automatic and the later D-160 (both Kohler and Onan), D-180, and D-200, but also, there were differences in the first year (1974) D-160 and D-180 and 1975 and later D series. Unfortunately I have yet to find any 1974 D series parts manuals or service manuals. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #2 Posted November 17, 2022 4 Share this post Link to post Share on other sites
tractorhogg 612 #3 Posted November 17, 2022 14 minutes ago, gwest_ca said: Thanks a bunch, I was under the impression that files like this didn't contain any illustrations. I found my part number for my PTO clutch brake and it is different than the 1975 K341 D-160 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #4 Posted November 17, 2022 As time goes on many online Toro illustrations are disappearing. Probably so new content can be added. When this started to happen I grabbed any we did not have an original of. These are identified by TIPL in the title. (Toro illustrated parts list) An original is identified by IPL Where Toro has eliminated the illustrations but left the parts list those are TPL Keep in mind the TIPL's cover more than one model in most cases but fail to identify what model uses what. A hint of the included models can be seen if you look at the engine page. If a part item number appears in the list of parts more than once the part numbers for that item will be different and is usually near the bottom of the list along with some other parts for the extra tractor models. And mistakes do happen. There is a Lawn Ranger parts list that includes the part numbers for a D-Series tractor but can not find it at the moment. 2 Share this post Link to post Share on other sites
tractorhogg 612 #5 Posted November 18, 2022 11 hours ago, gwest_ca said: As time goes on many online Toro illustrations are disappearing. Probably so new content can be added. When this started to happen I grabbed any we did not have an original of. These are identified by TIPL in the title. (Toro illustrated parts list) An original is identified by IPL Where Toro has eliminated the illustrations but left the parts list those are TPL Keep in mind the TIPL's cover more than one model in most cases but fail to identify what model uses what. A hint of the included models can be seen if you look at the engine page. If a part item number appears in the list of parts more than once the part numbers for that item will be different and is usually near the bottom of the list along with some other parts for the extra tractor models. And mistakes do happen. There is a Lawn Ranger parts list that includes the part numbers for a D-Series tractor but can not find it at the moment. So the 1974 TIPL uses part number 103313 for the PTO clutch brake, but it is exactly the same as the 1975 PTO clutch brake part number 104694. I was hoping someone had a picture of a Kohler single D-160 with a PTO clutch brake attached Share this post Link to post Share on other sites
