Sparky-(Admin) 22,129 #51 Posted January 6, 2023 1 hour ago, Ed Kennell said: 46% increase in one year. 27% drop in one month. Still up 36% from one year ago. So your oil guy came out for a 24.5 gallon fill-up? All your fill-ups seem small? Or do you just have a small tank? When my tank gets just below half we call and end up with a 130+ gallon fill-up. 1 Share this post Link to post Share on other sites
lynnmor 7,572 #52 Posted January 6, 2023 17 minutes ago, Sparky said: So your oil guy came out for a 24.5 gallon fill-up? All your fill-ups seem small? Or do you just have a small tank? When my tank gets just below half we call and end up with a 130+ gallon fill-up. I burn a lot of wood and use a heat pump during mild temperatures, my last fill was 27 gallons in the house for a year. I haven't used more than 50 gallons in the house in recent years. Since i use oil in the shop and my other house, the supplier will come out and top them off if takes 150 gallon minimum for the three. 1 Share this post Link to post Share on other sites
ebinmaine 70,788 #53 Posted January 6, 2023 Around here the Industry Standard is 100 gallon minimum to get delivery without a surcharge. ... UNLESS you have Automatic Delivery. Then it's up to the company. Share this post Link to post Share on other sites
Ed Kennell 40,500 #54 Posted January 6, 2023 26 minutes ago, Sparky said: So your oil guy came out for a 24.5 gallon fill-up? All your fill-ups seem small? Or do you just have a small tank? When my tank gets just below half we call and end up with a 130+ gallon fill-up. I have a 250 gallon tank. He is a local one man dealer that tops mine off when he's in the neighborhood. I heat with wood when the outside temps are below 40F but the oil boiler is still heating my domestic hot water. When oil price is below $2.50/gallon, don't use the wood stove. 1 1 Share this post Link to post Share on other sites
