Dennis C. 142 #1 Posted November 14, 2022 (edited) I've owned this 314 Hydro two seasons now and I have a puzzling issue. The tractor is a 1996 with 540hrs. Machine is in excellent condition. I change the oil each Spring and oil usage is nil. During the cooler months and winter the tractor is stored in a new storage shed. Every Spring when I go to start the tractor for the first time the oil is contaminated with water. (condensation) I used the tractor all summer and the oil is clean. Today I went out to move the tractor after sitting for two weeks in the cold storage shed and after the engine warmed up I checked the oil and it was all milky. What's causing this and how to I stop this from happening? I've owned several WH tractors with Kohlers and this is the first time I've had this issue. Thanks in advance for any input. Edited November 14, 2022 by Dennis C. 1 Share this post Link to post Share on other sites
peter lena 9,556 #2 Posted November 14, 2022 @Dennis C. just a guess , how long was your warm up ? did you run it around , engage your pto lever ? sounds like not enough engine heat to evaporate the cold to hot change over , this is only my take on this , not had a milky oil issue , what are you using for oil ? went over to Castrol magnatec oil for winter , 5-30 , no moisture issues at all , also use rislone zinc in all my oils , have you changed anything that might have caused this ? pete 2 1 Share this post Link to post Share on other sites
Dennis C. 142 #3 Posted November 14, 2022 4 minutes ago, peter lena said: @Dennis C. just a guess , how long was your warm up ? did you run it around , engage your pto lever ? sounds like not enough engine heat to evaporate the cold to hot change over , this is only my take on this , not had a milky oil issue , what are you using for oil ? went over to Castrol magnatec oil for winter , 5-30 , no moisture issues at all , also use rislone zinc in all my oils , have you changed anything that might have caused this ? pete Pete, this issue is only in the cooler months, not Summer or Spring. I never start and stop the tractor, I warm it up and and usually mow or use it around the yard. This only happens when the temps are 30 degrees or lower. I'm using Kawasaki straight 30 wt with zinc but I'm open to other oils. Today when I return the mower to the shed I will let it run for a bit and then remove the dip stick and see what happens when the engine sit over night. 3 Share this post Link to post Share on other sites
peter lena 9,556 #4 Posted November 14, 2022 @Dennis C. thats what I was thinking , the colder temps , is not letting the oil totally heat up , that would give you the condensation issue . yup your warmer weather mower deck use , eliminates all the moisture issues . I use rotella # 30 spring thru fall , think a multi weight oil , like 10-30 or 5-30 , check your oil temp recommendations , would be the answer, the lower weight , would quickly heat up and transition to higher weight heat change over . have any place nearby where you can drive the tractor ? like a cull de sac ? that idling is zero stress / heat , think thats your issue. multi wt. oil , pete 2 1 Share this post Link to post Share on other sites
Snoopy11 5,723 #5 Posted November 14, 2022 Sometimes the dipstick doesn't seal causing atmosphere to enter crankcase... I would check that and possibly put a new o-ring on it if possible. You are just going to want to make sure that everything on the engine is sealing up good... gaskets and such... Just an idea... Don 2 Share this post Link to post Share on other sites
Dennis C. 142 #6 Posted November 14, 2022 34 minutes ago, peter lena said: @Dennis C. thats what I was thinking , the colder temps , is not letting the oil totally heat up , that would give you the condensation issue . yup your warmer weather mower deck use , eliminates all the moisture issues . I use rotella # 30 spring thru fall , think a multi weight oil , like 10-30 or 5-30 , check your oil temp recommendations , would be the answer, the lower weight , would quickly heat up and transition to higher weight heat change over . have any place nearby where you can drive the tractor ? like a cull de sac ? that idling is zero stress / heat , think thats your issue. multi wt. oil , pete I never just start and stop the tractor. Minimum use is 30 minutes and yes I drive around the neighborhood with bit if i'm not mowing. My daughters dog LOVES riding on the tractor so we go for at least 30 minutes. I just let the engine run at 1/2 throttle for 35 minutes and the block is stone cold. During the summer, it's just the opposite. I'll try the Castrol Magnatec 5-30 and see what happens. 2 Share this post Link to post Share on other sites
Dennis C. 142 #7 Posted November 14, 2022 1 hour ago, peter lena said: @Dennis C. just a guess , how long was your warm up ? did you run it around , engage your pto lever ? sounds like not enough engine heat to evaporate the cold to hot change over , this is only my take on this , not had a milky oil issue , what are you using for oil ? went over to Castrol magnatec oil for winter , 5-30 , no moisture issues at all , also use rislone zinc in all my oils , have you changed anything that might have caused this ? pete Where do you buy the Castrol Magnatec 5-30.? No one stocks that here in Coventry or close by. 1 Share this post Link to post Share on other sites
peter lena 9,556 #8 Posted November 14, 2022 @Dennis C. got it a Walmart , just like everything else , the prices are nuts , good luck , pete 1 1 Share this post Link to post Share on other sites
peter lena 9,556 #9 Posted November 14, 2022 @Dennis C. https://www.walmart.com/ip/Castrol-GTX-MAGNATEC-5W-30-Full-Synthetic-Motor-Oil-5-Quarts/44580669 , pretty good pricing , pete 1 1 Share this post Link to post Share on other sites
stevasaurus 23,515 #10 Posted November 14, 2022 Just a question...Are you getting moisture or is it maybe what I would call frothing?? I remember frothing would occur in car engines sometimes with Pennsoil in the late 60's. 2 Share this post Link to post Share on other sites
stevasaurus 23,515 #11 Posted November 14, 2022 Is your Kawasaki oil a detergent oil ?? If so, maybe a non-detergent oil might be the answer. 3 Share this post Link to post Share on other sites
Snoopy11 5,723 #12 Posted November 14, 2022 @stevasaurus excellent recommendations. My only thought though... he doesn't have the problem with his other engines... Don 3 Share this post Link to post Share on other sites
stevasaurus 23,515 #13 Posted November 14, 2022 Understood Don. Just thinking when you pull out a dipstick and it has white junk on it...could be froth. A suggestion that Dennis has to think about and let us know. I know there is a lot of times, we all miss the issue because of not enough information, or discussion. 2 1 Share this post Link to post Share on other sites
Snoopy11 5,723 #14 Posted November 14, 2022 Just now, stevasaurus said: Understood Don. Just thinking when you pull out a dipstick and it has white junk on it...could be froth. A suggestion that Dennis has to think about and let us know. I know there is a lot of times, we all miss the issue because of not enough information, or discussion. Absolutely. To your point... we don't know that what is in the engine is water... I'd be interested to know how the spark plug looks when it comes out... if this engine is burning any oil... any excessive oil or hints of smoke coming from the exhaust or breather. I have seen some engines that... when the rings and cylinder walls are well worn... combustion gets by the rings, making the oil milky as well. Does the oil have a fuel fragrance... things like that... Don 3 1 Share this post Link to post Share on other sites
Snoopy11 5,723 #15 Posted November 14, 2022 Hey Steve, just read this on another forum about milky oil... "Did you take the hose to it or leave it out in the rain? Roof leak?....not likely, unless you left the cover off of the crankcase....sabotage? Got problem with your neighbor, wife jealous of your mower?" Don 1 1 Share this post Link to post Share on other sites
stevasaurus 23,515 #16 Posted November 14, 2022 Excellent Don !! A picture of what is on the dip stick might go a long way ?? I'm just thinking, you don't usually get moisture in an engine without a radiator. Then, you think about the oil?? 2 Share this post Link to post Share on other sites
Dennis C. 142 #17 Posted November 14, 2022 1 hour ago, peter lena said: @Dennis C. https://www.walmart.com/ip/Castrol-GTX-MAGNATEC-5W-30-Full-Synthetic-Motor-Oil-5-Quarts/44580669 , pretty good pricing , pete Says not available in my location 1 Share this post Link to post Share on other sites
Dennis C. 142 #18 Posted November 14, 2022 1 hour ago, stevasaurus said: Just a question...Are you getting moisture or is it maybe what I would call frothing?? I remember frothing would occur in car engines sometimes with Pennsoil in the late 60's. Dipestick is all white and the oil on the dipstick. 2 Share this post Link to post Share on other sites
Dennis C. 142 #19 Posted November 14, 2022 (edited) 1 hour ago, stevasaurus said: Is your Kawasaki oil a detergent oil ?? If so, maybe a non-detergent oil might be the answer. Not sure, I bought it because it is recommended for older engines and has a zinc additive. Edited November 14, 2022 by Dennis C. 1 Share this post Link to post Share on other sites
Dennis C. 142 #20 Posted November 14, 2022 41 minutes ago, Snoopy11 said: Absolutely. To your point... we don't know that what is in the engine is water... I'd be interested to know how the spark plug looks when it comes out... if this engine is burning any oil... any excessive oil or hints of smoke coming from the exhaust or breather. I have seen some engines that... when the rings and cylinder walls are well worn... combustion gets by the rings, making the oil milky as well. Does the oil have a fuel fragrance... things like that... Don I changed the oil each Spring and i have only owned this tractor 2 seasons. Engine has 540 hours and the oil is clean. I check the oil before every use and in the warmer months the oil is nice and clean, not dirty or burnt looking. Plug is fresh with 10 hours on it. I'll pull it tomorrow and see what it looks like. 1 Share this post Link to post Share on other sites
stevasaurus 23,515 #21 Posted November 14, 2022 Get us a picture...sounds like frothing. Don't get excited here, we are only trying to figure out and help. Let us see what is on the dip stick. 2 1 Share this post Link to post Share on other sites
Dennis C. 142 #22 Posted November 14, 2022 28 minutes ago, Snoopy11 said: Hey Steve, just read this on another forum about milky oil... "Did you take the hose to it or leave it out in the rain? Roof leak?....not likely, unless you left the cover off of the crankcase....sabotage? Got problem with your neighbor, wife jealous of your mower?" Don Never use the hose on any of my Wheel Horse tractors and all are stored inside. After every use, I use my electric leaf blower to clean the tractor and blow out the cooling fins on the engine. Storage shed is brand new but both storage sheds have a moisture problem in the cooler months and winter. Even all my tools are wet. 2 Share this post Link to post Share on other sites
Dennis C. 142 #23 Posted November 14, 2022 2 minutes ago, stevasaurus said: Get us a picture...sounds like frothing. Don't get excited here, we are only trying to figure out and help. Let us see what is on the dip stick. I'll take pictures tomorrow. It's not frothing, the dip stick has water droplets on it when i btake it out. 3 Share this post Link to post Share on other sites
stevasaurus 23,515 #24 Posted November 14, 2022 OK, but we may want to talk about your shed. My Dad's pole barn had a condensation problem. He insulated the roof and it had heat if he ran it. When he did not run it, especially in the late winter into spring, the insulation would get wet and drip. After he passed, I ended up ripping out all of that fiberglass insulation. There were vents in the ridge of the roof, but not enough to take care of that moisture. Once that insulation was wet, it was going to ruin the sheeting on the roof. The insulation has been gone for 20 years now and we have no moisture issues since then. It was like being in a sauna in the spring. Maybe, that is what you have going on??? 2 Share this post Link to post Share on other sites
Dennis C. 142 #25 Posted November 14, 2022 4 minutes ago, stevasaurus said: OK, but we may want to talk about your shed. My Dad's pole barn had a condensation problem. He insulated the roof and it had heat if he ran it. When he did not run it, especially in the late winter into spring, the insulation would get wet and drip. After he passed, I ended up ripping out all of that fiberglass insulation. There were vents in the ridge of the roof, but not enough to take care of that moisture. Once that insulation was wet, it was going to ruin the sheeting on the roof. The insulation has been gone for 20 years now and we have no moisture issues since then. It was like being in a sauna in the spring. Maybe, that is what you have going on??? It has more to do with the property, my house is the same way. WET. Neither shed is insulated and both have vents. The land is very damp . In the winter the tools and mowers all have water droplets on them. Not much I can do about that. Share this post Link to post Share on other sites
