Brockport Bill 2,122 #1 Posted November 14, 2022 i posted a thread a couple weeks ago about a lift valve leak on a C175, Series 2 -- but i have a different related question? I have replaced the O rings inside the lift valve unit as well as replacing the O rings on all the respective hose fitting ends - I am assuming and hopeful that i have now "repaired" the leak from the lift valve itself or a hose coupling thats been causing the oil dripping from the lift valve unit area? - it was impossible to determine where exactly the leak was coming from????? Here's my new question since this is a new venture to me ------------ how do i know its NOT the fitting itself on the end of the hose that is leaking at its own joint???????? The fittings or couplings have a swivel and therefore a joint - so how can i determine it isnt the fitting itself leaking ? Sure don't want to re-assemble the tractor only to learn the new O rings did not correct the leak????? And certainly I want to avoid expense of new hoses, fittings etc unless necessary. Is there such a thing as a vendor/store/repairshop that somehow does pressure tests? Is it common, or not common, for the fitting/coupling itself other - than worn O rings - to leak -- after all the hoses and the fittings are likely original from 1980? thanks for any insights!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Share this post Link to post Share on other sites
Pullstart 68,521 #2 Posted November 14, 2022 Get you some cheap electric tape. Wrap all suspected fittings / hose ends. See what bubbles. That’s what I’d do 3 Share this post Link to post Share on other sites
Brockport Bill 2,122 #3 Posted November 14, 2022 the valve and hoses are out of the tractor - so i am not sure what you are suggesting with the electric tape??????? 2 minutes ago, Pullstart said: Get you some cheap electric tape. Wrap all suspected fittings / hose ends. See what bubbles. That’s what I’d do Share this post Link to post Share on other sites
Brockport Bill 2,122 #4 Posted November 14, 2022 some lift valve photos and hoses attached 1 Share this post Link to post Share on other sites
Pullstart 68,521 #5 Posted November 14, 2022 26 minutes ago, Brockport Bill said: the valve and hoses are out of the tractor - so i am not sure what you are suggesting with the electric tape??????? oh, I thought it was still under pressure / leaking. 1 Share this post Link to post Share on other sites
Brockport Bill 2,122 #6 Posted November 14, 2022 below is photo of the internal lift valve piston shaft Share this post Link to post Share on other sites
Joe Shmo 158 #7 Posted November 14, 2022 I have a C125(1981) and the hoses were wore out and leaking. I replaced all of them and no more leaks 3 Share this post Link to post Share on other sites
953 nut 63,003 #8 Posted November 14, 2022 Your ORB "O" ring fittings should be torqued to about 225 inch pounds when installed. I guess you could fabricate a cap for one end of the hose and an adapter to connect to an air hose fitting to the other end to give them a pressure test. 1 Share this post Link to post Share on other sites
JPWH 6,542 #9 Posted November 14, 2022 A hydraulic repair shop should be able to test your hoses but you can replace them for what the test would cost 1 Share this post Link to post Share on other sites
peter lena 9,556 #10 Posted November 14, 2022 @Brockport Bill https://products.swagelok.com/en/all-products/fittings/c/100? we used these every where , hose make up shop probably has them in stock , so you could connect with hose or tube , no failures . plan on " working areas " for no stress operation . bombproof operation , pete 1 Share this post Link to post Share on other sites
pfrederi 19,264 #11 Posted November 14, 2022 Old swivel fittings will eventually leak The more they swivel/move the sooner they wear out and leak Repair by replacement ... or unless it is a big leak I live with it it is a form of corrosion control 1 Share this post Link to post Share on other sites
Brockport Bill 2,122 #12 Posted November 14, 2022 6 hours ago, peter lena said: @Brockport Bill https://products.swagelok.com/en/all-products/fittings/c/100? we used these every where , hose make up shop probably has them in stock , so you could connect with hose or tube , no failures . plan on " working areas " for no stress operation . bombproof operation , pete 2 hours ago, pfrederi said: Old swivel fittings will eventually leak The more they swivel/move the sooner they wear out and leak Repair by replacement ... or unless it is a big leak I live with it it is a form of corrosion control i am taking old hydraulic hoses to a shop tomorrow --- will see if they can pressure test the 4 hoses to identify which fitting is leaking - and get quotes to replace either leaky one or all 4 2 Share this post Link to post Share on other sites
